    Looking for Beta-testers!
    Scheduled Pinned Locked Moved MagicMirror
    56 Posts 17 Posters 69.2k Views 18 Watching
    • KirAsh4K
      KirAsh4 Moderator @pigreco
      @pigreco, feel free to post your ideas in the various sections they might pertain to, modules, core system, or a general topic.
      • K
        kckndrgn
        Cool, I’m in, I like breaking things LOL :D
        As a noob to the MM project I’m really fascinated by it and eager to start writing my own modules (though I keep finding modules that suit my purpose).
        • pigrecoP
          pigreco
          Hello guys,
          i have tried to pass to development branch but i got this error
          error: Your local changes to the following files would be overwritten by checkout:
          modules/default/clock/clock.js
          Please, commit your changes or stash them before you can switch branches.
          Aborting
          I suppose that was due to my code change on the second colour of the analog clock in the module clock.js…i had just put the red colour #FF0000…i have retested with the @ #888888 one but still the same error…
          A possible bug?
          Cheers
          Pi
          KirAsh4K 1 Reply Last reply
          • MichMichM
            MichMich
            @pigreco, no this is the expected result. GIT doesn’t want to overwrite your changes. This is why you should never make ani modifications to the modules or the core files. If you want to modify the design, you can use the css/custom.css file (this file will be ignored by git).
            To remove your changes so that you can update continue, please use: git stash
            • pigrecoP
              pigreco
              Hello @MichMich thanks for the suggestion…not very familiar with stash, i need to authenticate ?
              PI
              MichMichM 1 Reply Last reply
              • MichMichM
                MichMich @pigreco
                @pigreco You could also try:
                git fetch origin
                git reset --hard origin/develop
                git clean -f
                • pigrecoP
                  pigreco
                  Thanks @MichMich …the issue is solved…i am on the develop branch :-)
                    dejayou
                    • KirAsh4K
                      @pigreco, I didn’t expose the other clock hands to be easily accessible to change the colors on. I’ll have to add that in in a later update. As @MichMich said, making changes to those core files will cause git to start complaining at you.
                      • bscaranoB
                        bscarano
                        I’m now on Develop. Will this update automatically or will I need to run something periodically?
                        KirAsh4K MichMichM 2 Replies Last reply
                        • KirAsh4K
                          KirAsh4 Moderator @bscarano
                          @bscarano, regardless of which branch you are on, you are in charge of your mirror, including updating the code.
                          • MichMichM
                            MichMich @bscarano
                            @bscarano To update to the latest version, you’ll need to pull the latest changes. This can be done using: git pull (from the command line within your MagicMirror² folder).
                            • K
                              kckndrgn
                              I am now on the development branch.
                              I have verified that the changes fixed my “blank screen” with the language set in the config file.
                              Thanks!
                              • MichMichM
                                MichMich
                                Update: More detailed error message in case config file couldn’t be loaded.
                                Please let me know if this works for you.
                                PR: https://github.com/MichMich/MagicMirror/pull/391#issuecomment-237919625
                                • MichMichM
                                  MichMich
                                  Please test the following PR:
                                  https://github.com/MichMich/MagicMirror/pull/416
                                  It’s merged into the current develop branch. If you are on the develop branch, please use git pull to update to the latest version.
                                  Thanks!
                                  • BangeeB
                                    Bangee Module Developer
                                    I’m now on the latest DEV version.
                                    I had some problems to run it with my PIR Sensor.
                                    this command helps to run it:
                                    npm rebuild --runtime=electron-prebuilt --target=0.37.8 --disturl=https://atom.io/download/atom-shell --build-from-source
                                    IpWithelist:
                                    I’ve added my Subnet to de Withelist, but I can’t access my MagicMirror using a browser:
                                    This device is not allowed to access your mirror.
                                    Please check your config.js or config.js.sample to change this.
                                    Would it be possible to add something like “Your IP-Adress: 192.168.0.99”?
                                    ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", ["192.168.0.99", "192.168.0.254"]],
                                    This sould add a range from 192.168.0.99-192.168.0.254, or am I wrong?
                                    Thanks for your help.
                                    • MichMichM
                                      MichMich
                                      @bangee: Check your node log. It should tell you which IP is trying to access the server. Good idea to add it to the “access denied” message. Will put it on my todo list. (PR is welcome!)
                                      J 1 Reply Last reply
                                      • BangeeB
                                        @MichMich Thank you. I’ve had to update my config:
                                        the Log told me:
                                        Access denied to IP address: ::ffff:192.168.0.99
                                        It works with this:
                                        ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.0.1/24", "192.168.0.1/24"],
                                          Jopyth Moderator @MichMich
                                          My mirror is now also running the development version, and I am experiencing restarts more often than before. I guess it is related to # 150 since there is no error in the log. Anyway I saw this twice yesterday, but this might just be something with a newer electron version, so maybe nothing we can fix. It is still a little bit annoying.
                                          @MichMich By the way, do you have any particular date in mind for the release?
                                          • MichMichM
                                            MichMich
                                            No, can’t give you an ETA.
                                            Keep me posted on the restart issue.
