    Slim, Frameless Bathroom Mirror with a 27" Display
    42 Posts 15 Posters 61.7k Views 24 Watching
      doubleT Module Developer
      Wow, that looks classy, nice job!
      @reaper81 said in Slim, Frameless Bathroom Mirror with a 27" Display:
      As I later discovered, neither the PIR sensor nor the radar sensor detects through a mirror. But since the radar sensor does not need a Fresnel cover to detect at wide angle, I kept using it. So that anything can be detected, I had to drill a hole in the mirror.
      Too late now, but I’d have suggested using only two of the three power sockets and building a cover with the PIR sensor for the socket in the middle. You probably get your power for the mirror from a hidden cable in the wall from there anyway? Or under the counter?
        MyMirror
        @reaper81:
        What kind of PIR do you use? Maybe a HC-SR501?
        And what happens, if the screen comes back from standby? Did a message e. g. “HDMI” or similar appear on the screen?
          reaper81
          @doubleT
          During the bathroom planning was only a backlit mirror planned with cable for light.
          This we have reconnected to continuous current. An surface-mounted shaft would never be an option.
            reaper81
            @MyMirror
            I do not use a PIR sensor. I use the RCWL-0516 radar sensor. It is PIN compatible too the standard PIR sensors and cheap. However, if you connect it upside down, it burns immediately. That happened to me twice.
              bhepler Module Developer
              Fantastic job, @reaper81. That looks like a professional installation.
                schlachtkreuzer6
                Looks great! :)
                For attachment to the wall without columns but with adjustment I have made hanging bars. Alternatively, there are now IKEA rails with adjustment options.
                What rails do you use (link)? That seems to be a really nice idea!
                  reaper81
                  @schlachtkreuzer6
                  if you mean the aluminum profile, they are from led-konzept. A realy nice shop, with lots of ideas all around led.
                    schlachtkreuzer6 @reaper81
                    @schlachtkreuzer6
                    No^^the parts for hanging, with the adjustment option from ikea :)
                      reaper81
                      @schlachtkreuzer6
                      the conzept is called frence cleat. if they are well done, you can hang your mirror on the wall whitout any gap.
                      alt text
                      my rails are handcrafted and not so good.
                      alt text
                      alt text
                      My timber was too thick for the circular saw. If you use the ikea besta rails it is much easier and you get probably better results.
                        @reaper81
                        Ah I see. Thanks!
                          Relic
                          This looks like exactly what I want to do! I have one question though, how did you attach the wood frame to the glass? Looks great btw:)
                            MyMirror
                            Hi reaper81,
                            same question from my site:
                            how did you attach the mirror to the wooden frame to make it look frameless? Can you provide us some pictures and tipps?
                              MyMirror
                              One more :-)
                              Can you explain the first picture a bit more? What are the individual boxes and connections that can be seen in the picture?
                                reaper81
                                @Relic
                                The wood frame ist glued with the strongest intallation glue i could find. in my case it was soudal fix all high track.
                                The consistency of this glue is very tough, so i had to spread it with a spatula on the frame. Before this i had roughen the foil on the glas with sandpaperfor more gluegrip.
                                alt text
                                alt text
                                After one day with a lot of weight on the frame the glue was harden.
                                  reaper81
                                  @ MyMirror
                                  Before finishing the project, i had to rearange some prarts a little bit of the mirror, because i needed some space for the hanging rails. So don’t wonder.
                                  alt text
                                  1. 220V AC Connection
                                  2. 220V AC Mainswitch
                                  3. 220V AC branching dose
                                  4. 24V LED-power adapter
                                  5. LED-Controller with radioreceiver
                                  6. LED-stripes
                                  7. monitor-power adapter mit HDMI-connection
                                  8. monitor
                                  9. 5V power adapter for Raspberry Pi und Bluetooth-Speaker
                                  10. raspberry Pi
                                  11. networkcable for Raspberry Pi
                                  12. cameramodul for useridentification
                                  13. radarsensor zur userdetection
                                  14. voltage converter für Bluetooth-speaker from 5V to 3.3V
                                  15. bluetoothreceiver/ -amplifier für exciter
                                  16. button zur connect Bluetoothreceiver und smartphone
                                  17. volumen Up Button for the Bluetoothreceiver
                                  18. volumen Down Button for the Bluetoothreceiver
                                  19. exciter (speaker)
                                  20. memorycard for the raspi with a backupimage
                                  • V
                                    Vancete
                                    WOW. It look georgeous.
                                      MyMirror
                                      Very good - thanks for sharing!
                                        schlachtkreuzer6
                                        Thank you for all your informations! So last question ^^ how is the sound with the exciters? Maybe we need here a YouTube video 😁😁
                                          MyMirror
                                          … and a few more from my site :-)
                                          • Can you show us, how do you dismantled the foot
                                            and how do you attach the power cable on the screen?
                                          • What about the temperature of the monitor? Will not be too hot in the tight construction?
                                          • Do you apply black foil on the back side of the mirror to improve the mirror effect?
                                          Thanks for all your tips and pictures!
                                            MyMirror
                                            and did you get that:
                                            –> recall off PDS241/271
                                            R 1 Reply Last reply
