    Getting the MagicMirror full-screen resolution
    9 Posts 5 Posters 11.8k Views 4 Watching
      doubleT Module Developer
      Does your monitor itself allow adjustment?
      • cruunnerrC Offline
        cruunnerr
        have u tried sudo raspi-config ?
        Go to advanced and then to resolution.
          petrpls @doubleT
          @doubleT said in Getting the MagicMirror full-screen resolution:
          There’s just one option for “resolution” on the physical monitor settings, and that is to move the “frame”. i.e i can make the white drawed surface move around, but i can’t reduce the black frame… :(
            petrpls @cruunnerr
            @cruunnerr said in Getting the MagicMirror full-screen resolution:
            I tried but it didnt make a difference… i guess its like setting the mode and stuff in the boot/config but through the interface instead ? :|
            • pjkoelemanP Offline
              pjkoeleman
              Otherwise first connect directly via HDMI and see what kind of image this gives.
                dxfan227 @petrpls
                @petrpls I know this is old but did you ever find a solution?
                Looking at the config you posted…it looks like you have removed the # signs to uncomment you code?
