    Rpi3 freezes after a few houres
    8 Posts 3 Posters 3.9k Views 3 Watching
      Mykle1 Project Sponsor Module Developer @Albert2002
      @Albert2002
      You may have more than one instance of MM running. That seems to be common recently. Please see the instructions here to check and correct. 7th, 8th and 9th post
      https://forum.magicmirror.builders/topic/6249/something-is-wrong/7
        Albert2002
        I checked this, unfortunately I’m not running two instances. The second one is a service needed by the Sonos Module.
        It seams to me that there a few people which having problems since 2.2.2?
        pi@MagicMirror:~ $ pm2 status
        ? Name  ? mode ? status ? ? ? cpu ? memory   ?
        ? mm    ? fork ? online ? 0 ? 0%  ? 1.3 MB   ?
        ? sonos ? fork ? online ? 0 ? 0%  ? 1.3 MB   ?
         Use `pm2 show ` to get more details about an app
        pi@MagicMirror:~ $
          @Albert2002
          Indeed, but not all users have the same troubles, and not for the same reasons. Anyway . . .
          Have you tried running only the default modules to see if the problem still occurs? If it does not, add them one by one, or in pairs, until you experience a problem so you can isolate the issue.
          If you are unfortunate and the problem arises before the addition of 3rd party modules then that is another matter altogether.
            barrysmallgoods @Mykle1
            @Mykle1 said in Rpi3 freezes after a few houres:
            This is what I did recently. It wasn’t the pi freezing but the browser on the pi, I am running the mirror on a server. It turned out to be a pi-hole module for me.
              Mykle1 Project Sponsor Module Developer @barrysmallgoods
              @barrysmallgoods said in Rpi3 freezes after a few houres:
              Well done, mate! :-)
                Albert2002
                Ok, this is what I try now. Thank you for your help!
                  Albert2002
                  Just to let you know: In my case it was the MMM-iHaveBeenThere module which caused the trouble.
