    Project overview - 09.02.2018 - revisited
    16 Posts 5 Posters 13.0k Views 4 Watching
      barnosch
      a bit offtopic:
      Have you really compared the two AMPs?
      i am using a Hifiberry Amp2 (not at the mirror) and they are only talking about 60Watts (no RMS) to fire up my Klipsch Speakers.
      The same as i could read has the Justboom Amp 2x30RMS (but only at 8ohm speakers), so why you choosed this (more expensive one) for this tiny looking speakers? ;)
      I also have a PiZeroW with a Justboom Amp (30W RMS). So small, and so powerfull, thats really nice.
      ontopic: Please post some more pictures. Looks interesting.
      schlachtkreuzer6S 1 Reply Last reply Reply Quote 0
      • schlachtkreuzer6S Offline
        schlachtkreuzer6 @barnosch
        @barnosch
        I do. I didn’t tried them, but I did a comparison.
        Hifiberry Amp2 (65,64€ Amazon):
        https://www.hifiberry.com/shop/boards/hifiberry-amp2/
        Justboom Amp HAT (69,6€ Amazon):
        https://www.justboom.co/product/justboom-amp-hat/
        Basically they are the same. Both using the same Texas Instruments Chip (TAS5756M) . So the specs are identically (2x30W) so I think electronics around the chip are probably also the same.
        And cost almost the same 🙈 the Justboom has more features. Like Softmute, Hardware mute, IR control, etc. etc. etc. eeeetc.
        The JB HAT has spaces for the camera cable and display cable. None of the hifiberry have them. So big minus for the hifiberrys. And pins for the Rpidisplay (what ever).
        The speakers aren’t so small (https://www.neuhold-elektronik.at/catshop/product_info.php?cPath=242_253&products_id=6537) but they are quite flat.
        And flat speakers are what I’m looking for. They are designed for TVs so they are quite good for higher Hz (voice and music) but due the small cones, the don’t have much Bass (Deep Hz lower than 110Hz are missing) and so you will hear that (I play with the idea to add an crossover with a pair of exciters for the bass, said in an other thread here).
        One speaker 10W RMS/20W peak @4Ohm. I’m using two per side, so ~20W RMS @8Ohm left and right. It’s not perfect but with the exciters I think it will be almost perfect for me.
        Next step, add the Flick HAT to control the volume :
        https://www.pi-supply.com/make/justboom-volume-control-with-flick/
        I don’t know if the flick works with the hifiberry amp2 also (I do not really care cause I have the JB)
        Pictures, yeah sure! I will post more till the end of the project :) next steps will be the flick and the frame, … the LEDs (indirect RGBs around the mirror) direct above (1m CW/WW Led strip like this: https://www.lampenwelt.at/100-cm-breite-led-spiegellampe-esther.html? ) and so on… and on and on ^^
          barnosch
          Thanks for you reply.
          Take a look at this
          https://shop.max2play.com/de/audio-boards/by-type/amp.html
          in this case the hifiberry is way cheaper. i guess the postage to Austria would kill it again ;)
          The more features should make the difference. Good point.
          I am using a pi3 with the Amp2 and the original 7" Rasp Display. Thats working without issues. If you use third party or HDMI it might be tight.
          The Flick is a interesting little thing :)
          Pretty sure it will work on the Hifiberry too, since you only need to plug it on the GPIO pins.
          How do you want to use the Amp on your mirror?
          How do you want to stream the sound to the pi?
            @barnosch
            Max2play is the shop that sells it on Amazon too. Postage is 13,99€ to Austria via DHL Express. There aren’t many shops selling amps for the pi.
            Yeah the flick will be great, I want an easy contactless way to change volume when I’m in the bathroom (for the first). So any button or rotary switch with wet hands could be problematic, so I searched for an contactless way. I’ll try the flick and will inform you about the performance.
            Streaming:
            I use spotify (https://github.com/dtcooper/raspotify). Raspotify is great cause it is easy to use and runs stable. The advantage of raspotify is everyone can stream on it (not only one account). Like Amazon Alexa when you say: “Alexa spotify connect”, everybody can connect to the echo.
              barnosch
              Alright. nice.
              I am using two “max2play” Speaker combinations, to have a Multiroom System. Music is streamed from a Fritzbox attached harddisk.
              The mirror has’nt got to do something with it, yet.
              Still searching for a MM module that implements the current playing song on each player.
              Like the Sonos module.
              I am pretty sure, i will find soon something where i can use the Flick thing aswell ;)
              So i am looking forward to hear, how good it is actually working.
                schlachtkreuzer6
                The Flick HAT arrived today, freshly from the UK 😁
                Two pics added:
                https://drive.google.com/file/d/1m5q29musCxpbcteoCT_oVEkI1ybnOefM/view?usp=drivesdk
                I thought it would be a bit bigger. Can’t wait to test it after work 🤗
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @schlachtkreuzer6
                  @schlachtkreuzer6 looks like the same technology as the skywriter hat that i bought a while ago, there is also a larger version of both.
                    schlachtkreuzer6 @strawberry 3.141
                    @strawberry-3.141
                    Yep you are right. Same PCB layout and Chip. So there are the same.
                      schlachtkreuzer6
                      Updated the main post, added some media :)
                        @schlachtkreuzer6 I was a bit shocked by the amount of cables :D
                        schlachtkreuzer6S 1 Reply Last reply Reply Quote 1
