What is the difference between require() and getScripts()?
7 Posts 4 Posters 3.2k Views 3 Watching
  • E Offline
    E3V3A
    I’ve been trying to implement the jquery dependent package (Tabulator) on my mirror. What it does is, convert JSON data into a nice dynamic HTML table.
    In the working HTML version, I just the script tag, to include everything, but in a Node MMM, we can either use require("blablah") in the node_helper.js file, or use getScripts("blablah.js") in the MMM-MyModule.js file.
    1. What is the difference?
    2. When to use what?
    Right now I’m using the 2nd option, and it loads, but the table is never shown… I’m thinking I’m missing something.
    "Everything I do (here) is for free – altruism is the way!"
    N 1 Reply Last reply Feb 20, 2018, 12:59 AM Reply Quote 0
    • N Offline
      ninjabreadman @E3V3A
      @E3V3A
      require() is for when you mean “I’m going to use this code somewhere else in this script I am writing right now” — i.e. somewhere on the server-side.
      getScripts() is for when you mean “my client-facing/browser code will need this loaded to perform some operation” — i.e. somewhere on the client-side.
      (As always, this is what I understand and hope someone will correct me if I’m wrong.)
      E 1 Reply Last reply Feb 20, 2018, 10:30 AM Reply Quote 3
      • E Offline
        E3V3A @ninjabreadman
        @ninjabreadman Aah! Finally. Thank you. That is the most sensible explanation I’ve seen.
        (If you’re a moderator, please mark this as closed/solved.)
          Well you really shouldn’t mark this as closed or solved because I’m sure others will have questions too :)
          It’s a GREAT explanation… and it’s also a GREAT question!!! I’m sure others have wondered and I know people don’t usually ask for fear they’ll look ‘not smart’…but NO question is a dumb question!!
          The worst question in history? The one that never got asked! :)
          M 1 Reply Last reply Feb 20, 2018, 1:34 PM Reply Quote 0
            @cowboysdude said in What is the difference between require() and getScripts()?:
            I don’t have this problem. ;-)
            C 1 Reply Last reply Feb 21, 2018, 2:19 AM Reply Quote 0
              @Mykle1 said in What is the difference between require() and getScripts()?:
              Which one? Asking or not being smart LOL
              M 1 Reply Last reply Feb 21, 2018, 2:24 AM Reply Quote 1
                @cowboysdude
                Both? ;-)
