    Display Help
    25 Posts 3 Posters 11.7k Views 3 Watching
    • H Offline
      hnperkins
      Im sure this has been posted before and i have tried a few of the suggestions but Im at a loss atm as to how to use the entire screen. any help would be much appreciated
        Mykle1 Project Sponsor Module Developer @hnperkins
        @hnperkins
        Are you using a Pi?
        What resolution are you set to?
        Have you made any changes to any MM system files?
        • H Offline
          hnperkins
          yes i am using a pi2b i’ve tried the custom css with
          body {
             margin: 1px;
            height: calc(100% - 1px);
            width: calc(100% - 1px);
          i tried multiple margin sizes and height and width but it never comes down any further than what is in that screen shot
          i have
          disable_overscan=1
          hdmi_group=1
          hdmi_mode=16
          and my resolution is forced set to 1920x1080 60hz 16:9 after doing a
          tvservice -d edid
            @hnperkins said in Display Help:
            body {
            margin: 1px;
            I believe this should be
            body {
              margin: 1px;
              height: calc(100% - 2px);
              width: calc(100% - 2px);
            I don’t know about the other.
            • H Offline
              hnperkins @Mykle1
              @Mykle1 ok i will try that and see if it makes a difference. Could it be in the main.css? i just dont under stand why it wants to stay in the upper 1/4 of the monitor
                @hnperkins
                No, that belongs in the custom.css file. You should not be editing the main.css file unless you absolutely know what you are doing. That’s why I asked if you made any changes to the MM system files.
                • H Offline
                  hnperkins @Mykle1
                  @Mykle1 ok i see what you are saying. no i’ve not edited it. looked at it but not made changes. just the custom
                    @hnperkins
                    Someone will know how to solve your issue. I’m sure of it.
                    • H Offline
                      hnperkins @Mykle1
                      @Mykle1 hah i hope so, i’ve been going at this for about 3 hours now. not just the resolution issue but configuring modules and what not.
                        @hnperkins
                        Be patient. Someone will help you when they find this topic. Take your time with the modules. It gets easier with time
