    Display Help
    25 Posts 3 Posters 12.5k Views 3 Watching
    • H Offline
      hnperkins
      yes i am using a pi2b i’ve tried the custom css with
      body {
         margin: 1px;
        height: calc(100% - 1px);
        width: calc(100% - 1px);
      i tried multiple margin sizes and height and width but it never comes down any further than what is in that screen shot
      i have
      disable_overscan=1
      hdmi_group=1
      hdmi_mode=16
      and my resolution is forced set to 1920x1080 60hz 16:9 after doing a
      tvservice -d edid
        Mykle1 Project Sponsor Module Developer @hnperkins
        @hnperkins said in Display Help:
        body {
        margin: 1px;
        I believe this should be
        body {
          margin: 1px;
          height: calc(100% - 2px);
          width: calc(100% - 2px);
        I don’t know about the other.
        • H Offline
          hnperkins @Mykle1
          @Mykle1 ok i will try that and see if it makes a difference. Could it be in the main.css? i just dont under stand why it wants to stay in the upper 1/4 of the monitor
            @hnperkins
            No, that belongs in the custom.css file. You should not be editing the main.css file unless you absolutely know what you are doing. That’s why I asked if you made any changes to the MM system files.
            • H Offline
              hnperkins @Mykle1
              @Mykle1 ok i see what you are saying. no i’ve not edited it. looked at it but not made changes. just the custom
                @hnperkins
                Someone will know how to solve your issue. I’m sure of it.
                • H Offline
                  hnperkins @Mykle1
                  @Mykle1 hah i hope so, i’ve been going at this for about 3 hours now. not just the resolution issue but configuring modules and what not.
                    @hnperkins
                    Be patient. Someone will help you when they find this topic. Take your time with the modules. It gets easier with time
                      disable_overscan=1
                      hdmi_group=1
                      hdmi_mode=16
                      Just curious. Have you tried without this?
                      • H Offline
                        hnperkins @Mykle1
                        @Mykle1 yeah originally i just a clean boot and left everything stock from the install of noobs, that was just one of the things i had found to try via searching the forums and google
