    Motion Detector
    213 Posts 38 Posters 519.8k Views 39 Watching
      plumcraft
      Works for me too, thanks :)
      Is there a way to wake up faster the screen ? On my RPI it tooks around 30 secondes to turn back on, i might have a configuration issue…
        alexyak @plumcraft
        @plumcraft which RPI you have?
          plumcraft
          The latest, RPI 3.
            alexyak @plumcraft
            @plumcraft strange, I’ve RPI 3 as well and I don’t see this problem … This may be related to which monitor/TV your RPI is connected.
            • CatoC Offline
              Cato Module Developer
              I assume too that the behaviour is different between TV’s. On my LG the screen turns blue with a big message of lost signal on HDMI after 10 seconds after the screen turns off. Not so nice - but then again, nobody should be in the room anyway…? ;-)
              • cowboysdudeC Offline
                I installed it… it turns off the monitor but won’t turn it back on… suggestions?
                  cowboysdude Module Developer @plumcraft
                  @plumcraft Yeah there doesn’t seem to be an answer for the blank screen issue…
                    alexyak
                    I am sorry to hear about your issues. Trying to think of the best way to troubleshoot that. The module doesn’t do anything fancy. It just executes these in the node_helper to switch on/of the output on HDMI:
                    Switch off:
                    /opt/vc/bin/tvservice -o
                    Switch-on:
                    /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
                    As a first step, could you please try to execute these commands in the ssh terminal?
                    • T Offline
                      trividar
                      Hi alexyak
                      I try it with the commands an it works, it switch off and on.
                        alexyak
                        Ok, the next step let’s check whether the off state is detected correctly. After you switched off the monitor with the first command try to execute this in the ssh term:
                        /opt/vc/bin/tvservice -s
                        and let me know which output you see.
                        • 21
                        • 22
                        • 1 / 22
