    Motion Detector
    213 Posts 38 Posters 524.8k Views 39 Watching
      alexyak
      Sorry, guys, the problem should be fixed now. Just pull the latest.
      CatoC 1 Reply Last reply Reply Quote 1
      • CatoC Offline
        Cato Module Developer @alexyak
        @alexyak Thanks, works now!
          plumcraft
          Works for me too, thanks :)
          Is there a way to wake up faster the screen ? On my RPI it tooks around 30 secondes to turn back on, i might have a configuration issue…
            alexyak @plumcraft
            @plumcraft which RPI you have?
              plumcraft
              The latest, RPI 3.
                alexyak @plumcraft
                @plumcraft strange, I’ve RPI 3 as well and I don’t see this problem … This may be related to which monitor/TV your RPI is connected.
                • CatoC Offline
                  I assume too that the behaviour is different between TV’s. On my LG the screen turns blue with a big message of lost signal on HDMI after 10 seconds after the screen turns off. Not so nice - but then again, nobody should be in the room anyway…? ;-)
                  • cowboysdudeC Offline
                    I installed it… it turns off the monitor but won’t turn it back on… suggestions?
                      cowboysdude Module Developer @plumcraft
                      @plumcraft Yeah there doesn’t seem to be an answer for the blank screen issue…
                        alexyak
                        I am sorry to hear about your issues. Trying to think of the best way to troubleshoot that. The module doesn’t do anything fancy. It just executes these in the node_helper to switch on/of the output on HDMI:
                        Switch off:
                        /opt/vc/bin/tvservice -o
                        Switch-on:
                        /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
                        As a first step, could you please try to execute these commands in the ssh terminal?
                        • 21
                        • 22
                        • 1 / 22
