    Motion Detector
    213 Posts 38 Posters 579.0k Views 39 Watching
    • A
      alexyak
      I’ve published the Motion detector module that I’ve been using for a while. It uses a web camera connected to a Raspberry Pi.
      You can find it here:
      https://github.com/alexyak/motiondetector
      The configuration should be pretty straightforward.
      mickyasM 1 Reply Last reply Reply Quote 2
        plumcraft
        Thanks for your module, that’s a great idea to use the Pi camera for that.
        I’ve tried your module and it looks like it does not work for me. My screen stay black even if i’m in the front of the camera, it is compatible with Paviro’s facial recognition module ?
          Cato Module Developer
          @alexyak Same here, blank screen.
          I notice that Chrome debugger complains that “Uncaught ReferenceError: MotionDetector is not defined” on this line in motiondetector.js:
          var core = new MotionDetector.Core(function (detected) {
          Something missing?
          • A
            alexyak
            Sorry, guys, the problem should be fixed now. Just pull the latest.
              Cato Module Developer @alexyak
              @alexyak Thanks, works now!
                plumcraft
                Works for me too, thanks :)
                Is there a way to wake up faster the screen ? On my RPI it tooks around 30 secondes to turn back on, i might have a configuration issue…
                • A
                  alexyak @plumcraft
                  @plumcraft which RPI you have?
                    plumcraft
                    The latest, RPI 3.
                    • A
                      alexyak @plumcraft
                      @plumcraft strange, I’ve RPI 3 as well and I don’t see this problem … This may be related to which monitor/TV your RPI is connected.
                        I assume too that the behaviour is different between TV’s. On my LG the screen turns blue with a big message of lost signal on HDMI after 10 seconds after the screen turns off. Not so nice - but then again, nobody should be in the room anyway…? ;-)
                        • cowboysdudeC
                          I installed it… it turns off the monitor but won’t turn it back on… suggestions?
                          • cowboysdudeC
                            cowboysdude Module Developer @plumcraft
                            @plumcraft Yeah there doesn’t seem to be an answer for the blank screen issue…
                            • A
                              alexyak
                              I am sorry to hear about your issues. Trying to think of the best way to troubleshoot that. The module doesn’t do anything fancy. It just executes these in the node_helper to switch on/of the output on HDMI:
                              Switch off:
                              /opt/vc/bin/tvservice -o
                              Switch-on:
                              /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
                              As a first step, could you please try to execute these commands in the ssh terminal?
                              • T
                                trividar
                                Hi alexyak
                                I try it with the commands an it works, it switch off and on.
                                • A
                                  alexyak
                                  Ok, the next step let’s check whether the off state is detected correctly. After you switched off the monitor with the first command try to execute this in the ssh term:
                                  /opt/vc/bin/tvservice -s
                                  and let me know which output you see.
                                  • T
                                    trividar
                                    output is:
                                    state 0x120002 [TV is off]
                                    • strawberry 3.141S
                                      strawberry 3.141 Project Sponsor Module Developer @trividar
                                      @trividar @cowboysdude paviro is also using the same code lines in his pir sensor module and a user had similar issues, maybe his solution also work for you
                                      https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/43
                                      https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/64
                                      • cowboysdudeC
                                        Thanks everyone I will look into this later today!
                                        • T
                                          trividar
                                          @strawberry-3-141 unfortunately it didn’t work for me;0( but thanks for your input.
                                          • strawberry 3.141S
                                            @trividar I thought the commands are working for you, as you pointed out 2 hours ago? I was struggling with this myself for a seperate module, it didn’t work in the terminal i had to login at tty6 or with the solution I posted I got weird colors and a zoom effect on my screen, but in the node_helper it worked at least for me.
                                            • 10
                                            • 11
                                            • 1 / 11
