    MMM-AQI
    Scheduled Pinned Locked Moved Health
    61 Posts 14 Posters 77.5k Views 15 Watching
      ryck Module Developer
      Description
      I was looking for a nice and simple module to display the air quality index (AQI), but all the modules I found were not really updated, or not using an API, or you couldn’t have several instances of it, or were not international, etc, so… I created my own.
      This module gets the Air Quality Index (AQI) using the World Air Quality Index project API.
      Screenshots:
      MMM-AQI
      Download:
      [card:ryck/MMM-AQI]
      Mykle1M F N 3 Replies Last reply Reply Quote 7
      • Mykle1M
        Mykle1 Project Sponsor Module Developer @ryck
        @ryck
        Nice!
        • F
          Freebond @ryck
          @ryck Great module.
          One question: in your config.section, you wrote that is possible to insert the city_ID instead of the city_name. Where can I find the ID list?
          • E
            E3V3A
            Yes, looks very nice. I love the minimalist presentation.
            Was browsing over China… OMG! The sensors were overloaded showing 999 and far above 200 otehrwise. crazy!
            “Everything I do (here) is for free – altruism is the way!”
            • F
              Fonfon
              Hi great module !
              But i have another city !!! when i write my city name i have another result “barrie in ontario” ???
              where to find city ID ?
              thanks
                To find the city id you can search for it using the API itself: http://aqicn.org/json-api/doc/#api-Search-SearchByName
                The API is quite picky with the names, so in my experience is always better to use the id or just the keyword here
                • E
                  E3V3A @ryck
                  @ryck AFAICT you can’t even search without an API key.
                    ryck Module Developer @E3V3A
                    @E3V3A Yep, but you can use the same token you are using for the module, ie:
                    https://api.waqi.info/search/?token=TOKEN&keyword=croydon
                    (you can just type that URL in your browser)
                    • F
                      Fonfon
                      Sorry but geoloc “here” is so bad !
                      name of city don’t work
                      and don’t understand how find @id …
                        ryck Module Developer @Fonfon
                        @Fonfon I added more info in the README, but is basically enter the URL above in your browser (using your token and your city, of course) an then just look for your city in the response and write down the “uid” value, that’s the id you are looking for.
                        F 1 Reply Last reply Reply Quote 1
                        • F
                          Fonfon @ryck
                          @ryck ahh ok i understand…Thanks a lot ;)
                          • E
                            E3V3A
                            Would you be willing to have/make an option to make the items horizontal instead of vertical? So to save space, since they are only numbers?
                              @E3V3A Yes, that’s a good idea, I’ll try to implement it as soon as I have some spare time!
                                maydaymiao
                                Hi, nice module. One question, is it possible to filter some of the pollutants that I want to see? Right now, it just displays all of them.
                                  rvanuden
                                  i am a late comer, just starting to learn about the magicmirror
                                  i do have a question about this nice module
                                  is there a way to display tresholds?
                                  for most people numbers say nothing, or you work with colors or display tresholds, how else can you know which pollutant is good or bad?
                                    Smotx
                                    Thx, very good, but why the ‘header’ is not visible ?
                                    • Mykle1M
                                      Mykle1 Project Sponsor Module Developer @Smotx
                                      @Smotx said in MMM-AQI:
                                      Post your config entry for this module in a code block
                                        Smotx @Mykle1
                                        @Mykle1
                                        			module: 'MMM-AQI',
                                        			position: 'top_left',
                                        			header: 'Polution',
                                        				token: "99860xxxxxxx",
                                        				city: "@8xxx",
                                        				iaqi: false,
                                        				updateInterval: 30 * 60 * 1000, // Every half hour.
                                        				initialLoadDelay: 0,
                                        				animationSpeed: 1000,
                                        				debug: false
                                        • Mykle1M
                                          @Smotx
                                          Hmm, odd. Your config looks good. Header SHOULD be showing. I just installed and ran it and my header appears as expected. Not sure why yours isn’t. My config:
                                                  module: 'MMM-AQI',
                                                  position: 'top center',
                                                  header: 'This header is working',
                                                    token: "exxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx3",
                                                    city: "here",
                                                    iaqi: true,
                                                    debug: false
                                          Try using my config with your apiToken as a test.
                                            Smotx @Mykle1
                                            @Mykle1
                                            The same, it’s stange, on others module, header are ok on screen…
                                            • 1 / 4
