the top
What is covered behind the mirror?
mdf?
How many millimeters is it? -
Hi guys
here is the list of my modules
MMM-iframe
MMM-Wunderground
MMM-Snow for the winter
MMM-traficfor the wooden plate under the glass I put the medium (mdf)
of 10mm then stick the double-sided glass on top! -
@frankoucth
Is mdf visible in the mirror?
Have you painted mdf black? -
Nice work !!
I see that you are french. Where did you buy the mirror? -
bonjour
je suis de Grenoble et j’ai acheter le miroir dans une miroiterie
voici leur site https://miroiterie-sogemi.com/ -
@adadws
Hello
no mdf did not show (it’s really like a mirror) I painted the glass and not the mdf. -
I’m from Grenoble too! What a small world!
Nice! I’ll take a look to this shop! Thank you so much.
You should add this shop to other thread that talk about finding a mirror provider. Could be useful for other french guys.Thanks again !
look good!
What is the mirror transmittance and reflectance? -
Very nice. Looks like the bathroom i would worry a bit about the humidity you dont think that the technic stuff could make problems later because of that?
@adadws
Hello
I can not tell you for the choice I made tests for a better rendering -
@svenr
no … after the tests, I have everything placed in a waterproof resin.
good ventilation of room water and it’s the ok ! -
Such a great work!
magic mirror devient de plus en plus connu par chez nous :p
Quick question, what kind of screen did you use, and which size is it? I would like to find a screen as slim as yours. -
Hello
my screen is a lcd of 80 cm of diagonal to take a minimum of thickness. -
hi frank
very good work !
witch modules do you use for your ip camera ?
please -
Beau boulot !
Quels sont les caractéristiques de ton miroir ? épaisseur ? transparence ? reflexion ?.. -
@frankoucth said in the top:
slt svp jai un probleme de geolocalisation weather . ca veu dire que le api ne detecte pas ma region pour afficher le meteo (afrique du nord )
Hello
to answer Simplearetenir
the thickness of my magic mirror is 5 cm transparency is like a glass when the reflection I made tests to choose the one that suited me the best.and to answer calypsou1
the best is to ask the question at https://github.com/RedNax67
I’m in trouble to make A2DP on my magic mirror
good week-end -
Salut @frankoucth !
Super boulot, ça donne envie d’avoir ça dans sa salle de bain !
Je suis à la recherche d’un miroir sur Nantes mais je ne sais pas trop quoi demander aux artisans du coin. Est-ce qu’il faut que je demande un “miroir sans tain” ou est-ce une autre sorte de verre/miroir ?
Je suis tombé sur ce site qui propose du 6mm pour 275€/m2, ça me paraît raisonnable vu l’écran que j’ai (15" pour un petit miroir donc) : https://www.toutverre.com
Merci pour ton aide !
Clément -
@frankoucth Hi, is this touch screen? Do you guys know how to install android system? So can install many funny apps.
@ctessier
J’ai payé le mien 150€ avec finition. Sans finition (coupe brute) il était à 94€. Les dimensions sont 900 x 600 avec 6 mm d’epaisseur. Coupe brute est nickel si tu veux avoir un cadre. Je suis allé chez le miroitier du coin. Tu peux appeler mirroir sans tain ou mirroir espion. Ils connaissentI bought mine 150€ with finishing. W/o finishing the amount was 94€. The sizes are 900 x 600 with 6 mm of thickness. W/o finishing is enough if you want a frame with border. I bought it to the mirror maker in my small city.
