    MMM-MyWastePickup (Toronto waste collection schedule)
    69 Posts 16 Posters 67.7k Views 17 Watching
      j.e.f.f Project Sponsor Module Developer @kruemel
      @kruemel I honestly have no idea why yours isn’t working. I thought it might be because you used a collection day name that’s not valid, but Thursday1 is in the list. I also thought maybe your date format didn’t match, but that seems to be fine too.
      Just to be sure, are you fully restarting Magic Mirror after these changes? The module only loads the schedule once at startup. Refreshing the browser won’t reload the schedule.
      • kruemelK
        kruemel
        Yes i did.
        Now i git pulled your latest relase.
        Also tried npm install and got this:
        pi@mm:~/MagicMirror/modules/MMM-MyWastePickup $ npm install
        npm WARN mmmmywastepickup@1.0.0 No repository field.
        But, with your 2018, its working.
        I will try again after this update and will report to you :-)
        J 1 Reply Last reply
          @kruemel You can ignore that error message. It just means I’ve omitted some information from the package.json file, but none of what I’ve left out is critical to the operation of this module.
          • kruemelK
            kruemel
            it works now.
            Just your update and my svg file, and now it works…
            i dont know why :D
              @kruemel For what it’s worth, I’ve just added official support for a custom schedule file. Check the README for instructions to do so. What you’ve done should and does work, but you risk having your schedule file overwritten if you update the module. With a quick tweak, you can have your schedule work within the new system and it won’t get overwritten when you update the module.
              I just pushed v1.3 to GitHub a few moments ago, so you’ll need to pull again.
              Reply Quote 2
              • kruemelK
                kruemel
                @j.e.f.f works as usual, thanks for your quick work :-)
                • kruemelK
                  kruemel
                  @j.e.f.f i have one more thing (just a detail):
                  Week day shown correctly in german like “Donnerstag” but it shows “Tomorrow” instead of “Morgen”.
                  Maybe this will also be “Today” instead of “Heute” but that i will know tomorrow ;-)
                  Regards
                    @kruemel This should be fixed now. Do a pull for v1.4. Also run npm install as I updated Moment.js to resolve a security vulnerability.
                    • twosquirrelsT
                      twosquirrels
                      Yesterday, my pickup schedule looked like this:
                      alt text
                      Today, it looks like this:
                      alt text
                      Is there a way to have it always display the next 3 events? My waste pickup is weekly, but recycling is every 2 weeks and I’d like to always see when the next recycling pickup is.
                      Thanks for another great module!
                        j.e.f.f Project Sponsor Module Developer @twosquirrels
                        @twosquirrels Sure. I added a config parameter weeksToDisplay. Do a git pull to update. Set it to 3 for your use.
                        twosquirrelsT 1 Reply Last reply
                        • twosquirrelsT
                          twosquirrels @j.e.f.f
                          @j.e.f.f
                          Wow, that was fast! Thanks!
                          I believe I have it setup right, but it looks like it’s giving me +1 than what I’m asking for, perhaps because it’s not including tomorrow?:
                          Setting ‘2’ gives me 3 total:
                          alt text
                          Setting ‘3’ gives me 4 total:
                          alt text
                            @twosquirrels No it’s correct. It’s 3 weeks by date – this will show any and all pickup dates between now and three weeks from now. Three weeks from today is April 18, which is why you’re seeing all pickup days between now and April 18.
                            • twosquirrelsT
                              @j.e.f.f
                              Ohh right, number of weeks. I was thinking it was number of events. Makes sense!
                              • WayneRigleyW
                                WayneRigley
                                OK, First off Jeff, thank you for this. i cloned and installed and ran the test file you had and everything is working perfectly. So i started to make my own Custom file exactly how you said and no matter what i still continue to get a “loading” so i switch back to your file and it works. I have no idea what im doing wrong.!0_1527603197851_Custom.jpg
                                Wayne R
                                • twosquirrelsT
                                  twosquirrels @WayneRigley
                                  @waynerigley The screenshot of your google drive isn’t helpful, because the final result likely has leading/trailing blank spaces, or some other issue that prevents it from parsing correctly. Edit schedule_custom.csv directly at the command line on your raspberry pi.
                                  WayneRigleyW 1 Reply Last reply
                                  • WayneRigleyW
                                    WayneRigley @twosquirrels
                                    @twosquirrels Thank you for the FAST reply… as im new to this please bare with me. im using putty and VNC and FIleZilla while using this. I made the excel on google and downloaded it to my laptop in CSV with the correct name. then filezilla to get it to the folder. can you give me a command to check what you need me to do. thanks in advance !
                                    Wayne R
                                    • twosquirrelsT
                                      @waynerigley
                                      In putty, once you ssh into your raspberry pi, do:
                                      cd /home/pi/MagicMirror/modules/MMM-MyWastePickup
                                      Then:
                                      sudo nano schedule_custom.csv
                                      You’re now viewing the contents of schedule_custom.csv. I don’t remember if it included a sample or not, but just edit/type/paste your data here. When done, press Control X to exit. It will ask to save, and say “Y” for yes. The contents of the file should look like my post above from 2 months ago.
                                      • WayneRigleyW
                                        @twosquirrels said in MMM-MyWastePickup (Toronto waste collection schedule):
                                        Thank you for that, new tool for me to remember ! well take a look, it all looks ok to me…0_1527608436847_edit.png
                                        Wayne R
                                        • twosquirrelsT
                                          @waynerigley Remove the double quotes from your entire file. For example, it should look like this:
                                          Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree
                                          Not this:
                                          "Calendar,WeekStarting,GreenBin,Garbage,Recycling,YardWaste,ChristmasTree"
                                          Also, remove them from the beginning and end of all following lines.
                                          • WayneRigleyW
                                            @twosquirrels HA guess what ! IT WORKED ! omg thank you so much ! Thank you Thank You Thank You.
                                            Wayne R
                                            • 2 / 4
