    My in-wall mirror version 2.0
    11 Posts 5 Posters 15.5k Views 4 Watching
      planet4
      Just wanted to share my mirror. The original guide (in Swedish) is available at www.planet4.se. More details written there.
      The things I have done is to:
      • Build the frame
      • Mount it in the wall
      • Added better cooling
      • Changed to real Mirrorpane glass
      • Sprayed the frame instead of the initial paint and 3d printed a raspberry case
      • Connected it with Home Assistant and Alexa
      THE FINAL RESULT
      alt text
      FRAME
      First I built the frame. I used a 24" monitor. I used a slightly bigger glass. My frame is 43*20 mm. Something like in the images below. I was worried about the heat so I took an image with my heat cam.
      alt text
      alt text
      alt text
      alt text
      In wall mount
      We just changed our kitchen and removed all walls. I got the idéa that maybe it was possible to mount the mirror in the wall. I also noticed the vent was just beside the hole and after some tweaking I was able to connect the vent coming from outside to the mirror frame.
      alt text
      alt text
      alt text
      alt text
      Mirrorpane glass
      I had film before and the difference is amazing. The glass is 6 mm thick. It costed me 60€. It is 40*56 cm. The negative things are:
      It is thicker
      It has a slightly red tone
      More light is shining through
      My mirror is larger than the monitor. This means light may shine through at the sides. I have put a black paper at the sides. In total darkness the screen is a little bit gray and the sides are black.
      Changed the contrast and brightness of the screen to fix this.
      alt text
      Sprayed the frame instead of using paint and printed a raspberry case. Used my ANET A8 3d printer to make a case.
      alt text
      alt text
      Connected it with Home Assistant och Alexa
      I am using the MMM-Remote Control. Maybe there are better solutions. I can now say Alexa, Reboot my magic Mirror or Alexa, Shutdown Magic Mirror. Or if none is home the monitor will be turned off. The code is found on my site.
      Mykle1M 1 Reply Last reply
      Reply Quote 3
        Charley Module Developer
        Really nice, like the in wall idea
        MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
        • brobergB
          broberg Project Sponsor
          Nice work, what brand of mirror did you get? Mirroview?
          And Btw… DeWalt, bra skit! ^_^
          • Mykle1M
            Mykle1 Project Sponsor Module Developer @planet4
            @planet4
            Excellent! I love the venting! Is it active or passive? In any case, a fantastic idea!
              planet4
              @broberg It is the Mirroview from Pilkington. Was able to get it from a local dealer here in Gothenburg. @Mykle1 It is the passive venting for the house. Not sure how well this actual works but it seems cool so far.
              • O
                ostfilinchen
                Hi @planet4
                really nice work.
                Can u explain what u do, that u work with alexa and the mirror? My swedish is very bad ;-)
                Regards
                Daniel
                P 1 Reply Last reply
                  planet4 @ostfilinchen
                  @ostfilinchen Thanks. Short version is that I have made a commandline switch in Home Assistant. In that way I can control everything in HA that is found in MMM- remote. Home Assistant is connected to Alexa and at the moment I can run commands like, Alexa, restart Magic Mirror. Or Alexa, Shutdown Magic mirror monitor. I am planning to make it work like Alexa, Show module X etc. In alexa I have created routines connected to smart devices. So the main setup is Echo plus, Home Assistant and cloud. Maybe you can to a translate of www.planet4.se where it is more in detail.
                  • O
                    ostfilinchen
                    okay thanks. is it right, that u installed the home assistant on a other pi or do u install it on the mirror pi?
                      @ostfilinchen I have one Pi for magicMirror, One for Home Assistant, One for Grafana and Influx (I show info from HA like temperature, internet speed etc on my mirror) and also one running kodi and one for Retropie. I like to keep them separated to keep things simple in case of a crash. I could install HA on the mirror PI as well if I wanted to.
                      O 1 Reply Last reply
                      • O
                        ostfilinchen @planet4
                        @planet4
                        is there an installscript or have i to intall via hassbian?
                          @ostfilinchen Use the image installing hass.io
