    Any MMM-Hive Users that can help, please?
    34 Posts 4 Posters 23.3k Views 4 Watching
      mongo116 Module Developer
      The last screenshot shows Frost Protect Enabled. Is this actually active on your hive?
      D 1 Reply Last reply
        Damian @mongo116
        @mongo116
        Yeah, by default… I thought this was normal as the only other setting on thermostat is child lock… or lower/raise the frost protect. I took that screenshot when heating was on, but mirror shows it when on and off.
          Damian @Damian
          You have this too in your post of 7 months ago …
          M 1 Reply Last reply
            mongo116 Module Developer @Damian
            @Damian Hi, yeah the frost protect should only show when the target temperature is below a certain value. I would guess the issue here is the data being received from Hive. I won’t ask you to paste the data here (which should show up under the browser’s developer console, when debug is enabled) as it contains data related to your account (from what I remember anyway). The most likely issue is that the receiver name is incorrect or that the relevant data relating to temperature etc is not where the module is expecting it to be. Unfortunately now I no longer have access to Hive there’s not much I can do to look into this. Sorry…
            D 2 Replies Last reply
              Damian @mongo116
              @cowboysdude
                Damian @mongo116
                @mongo116
                Sorry… I know you no longer have Hive, and unable to help, but I found this and wondered if this could have any bearing on it?
                https://community.smartthings.com/t/release-hive-connect-v3-0-british-gas-hive/103473
                  @Damian Hi. I will give it a read and check the code. I just had a quick look and I may just be able to update the requests etc. Might be a bugger to test, but leave this with me and I will take a look.
                  Thanks…
                    Damian @mongo116
                    @mongo116
                    Thanks very much … I realise you do not use Hive now, so it will be hard for you to test out changes, but I will try out everything you suggest and report back so you will know if they work or not.
                    Agree it will be tough this way, but if this is what your module needs in order to function, then it may be the only way to keep your module alive for Hive users eh?
                      @Damian I think I am making some headway into this issue. I will spend a bit of time when I can and hopefully get a new version out soonish
                      Cheers
                        I have got the temperature showing now (borrowed a hive login for testing) and I am looking at now adding whether hot water is on or off, and also a battery icon for the thermstat. I cannot for the life of me remember how to use github, but I will get these changes made, tested and update the module. No telling how long I will take, but it shouldn’t take too long - just need to find some time to finish coding and tidying it up.
                          Damian @mongo116
                          @mongo116
                          Thanks very much for fixing it… look forward to getting it working on my mirror. Was it a simple fix, of sorts? I couldn’t fathom out how others got it working okay if there is/was a problem? Was it the change in the smartthings link I gave you?
                            Looks like British Gas have just changed the way the api works, so there are changes to be made, not loads, but will take a bit of time. Got to fit it around DIY!
                              Damian @mongo116
                              @mongo116
                              Thanks for your time o this. Glad I did indeed do the instal right and did everything as stated, as I did spend a lot of time going round and round with this on 2 seperate machines, thinking I did something wrong or missed something.
                                @Damian Hi, I’ve updated https://github.com/flick116/MMM-Hive, do you want to try it and let me know. I’ve added some test bits and bobs, but if you haven’t got the settings then these shouldn’t show up.
                                  I was just testing and realised that when I was seeing the target temperature, it was when the system was in boost mode. So when not in boost mode, but the heating on, it’s not the same as previously, so it won’t show it’s heating. I need to look at how this is now working and update. You should see current temperature correctly using he updated code, but not target unless boost is on.
                                    Damian @mongo116
                                    @mongo116
                                    Thanks… but unfortunatly inside temp remains 0 :-(
                                    I do now see battery icon, although Red… but would expect that seeing as it cannot access my thermostat ( Named as Hive, and put Hive as nodename into config )
                                    Battery is good, only less than 6 months.
                                      Damian @mongo116
                                      @mongo116
                                      Just on the off chance I am missing the blatant obvious… can you please paste your full settings here that you made on yours? Obviously not your personal ones :-)
                                      And your config to see what you put in there. … it’s always the smallest things that trip us up, so want to check everything 100% before I just give up on it.
                                        @Damian I didn’t make any changes to the config really, apart from adding some other settings, but these default to false if not defined.
                                        Could you enable debug in the config for MMM-Hive (debug: true,) and then load the magic mirror in a browser and enable developer tools (F12). In this window, ensure Console is the selected tab and then refresh the page (it’s easier to remove all other modules). When refreshed, you should then see a load of text when the hive module loads, something like the following:
                                        Tue, 10 Apr 2018 14:45:16 GMT MMM-Hive received notification: INSIDE - Payload: [{“id”:“xxx”,“type”:“heating”,“sortOrder”:1,“created”:1521812393853,“parent”:“xxx”,“props”:
                                        If you could copy / paste the text into notepad and then search for “type”
                                        The bit I am interested in, is the text straight after “type” - so in the above example it’s “heating”
                                        I am using the “type” to determine whether to pull back data for heating or hot water so if yours is named differently that is probably the issue. There might be more than one instance of “type”, so if you could let me know all.
                                        Hopefully it’s just that and I can then add a new setting so you can choose the name.
                                          The config I have just tested with:
                                          			module: "MMM-Hive",
                                          			header: "Hive",
                                          				username: '',
                                          				password: '',
                                          				postcode: '',
                                          				updateInterval: 10 * 60000,
                                          				outsideUrl: 'http://weather-prod.bgchprod.info/weather?postcode=',
                                          				temperatureSuffix: ' °C',
                                          				showNext: true,
                                          				highestTemp: '30',
                                          				highTemp: '25',
                                          				lowTemp: '20',
                                          				lowestTemp: '15',
                                          				animatedLoading: true,
                                          				debug: true,
                                            maccy99
                                            Had the same issue then restarted rpi then suddenly it appeared :-)
                                            Thank you so much…
