    Problem updating to v2.3.1
    17 Posts 6 Posters 10.8k Views 6 Watching
    • N Offline
      NoNameRo @Kristianson
      @Kristianson
      did you run git reset --hard and then git pull && npm install
      • K Offline
        Kristianson
        No, tried that and a bit more info:
        pi@raspberrypi_7:~/MagicMirror $ git reset
        Unstaged changes after reset:
        M .eslintrc.json
        M .travis.yml
        M CHANGELOG.md
        M README.md
        M installers/raspberry.sh
        M js/class.js
        M js/main.js
        M js/module.js
        M js/translator.js
        M modules/README.md
        M modules/default/alert/README.md
        M modules/default/calendar/README.md
        M modules/default/calendar/calendarfetcher.js
        M modules/default/calendar/vendor/ical.js/test/test.js
        M modules/default/compliments/README.md
        M modules/default/compliments/compliments.js
        M modules/default/currentweather/README.md
        M modules/default/currentweather/currentweather.js
        M modules/default/newsfeed/README.md
        M modules/default/newsfeed/fetcher.js
        M modules/default/newsfeed/newsfeed.js
        M modules/default/updatenotification/updatenotification.js
        M modules/default/weatherforecast/weatherforecast.js
        M package-lock.json
        M package.json
        M tests/configs/check_config.js
        D tests/unit/functions/class_spec.js
        M tests/unit/functions/cmp_versions_spec.js
        D tests/unit/translations/same_keys.js
        M translations/af.json
        M translations/bg.json
        M translations/ca.json
        M translations/cs.json
        M translations/cy.json
        M translations/da.json
        M translations/de.json
        M translations/en.json
        M translations/es.json
        M translations/et.json
        M translations/fi.json
        M translations/fr.json
        M translations/hu.json
        M translations/id.json
        M translations/is.json
        M translations/kr.json
        M translations/nb.json
        M translations/nl.json
        M translations/nn.json
        M translations/pl.json
        M translations/pt.json
        M translations/ro.json
        M translations/ru.json
        M translations/sv.json
        M translations/zh_cn.json
        pi@raspberrypi_7:~/MagicMirror $ git pull && npm install
        error: Your local changes to the following files would be overwritten by merge:
        .eslintrc.json
        .travis.yml
        CHANGELOG.md
        README.md
        js/class.js
        js/main.js
        js/module.js
        js/translator.js
        modules/README.md
        package-lock.json
        package.json
        Please commit your changes or stash them before you merge.
        error: The following untracked working tree files would be overwritten by merge:
        dangerfile.js
        fonts/yarn.lock
        module-types.ts
        tests/configs/data/StripComments.json
        tests/configs/data/TranslationTest.json
        tests/configs/data/en.json
        tests/e2e/translations_spec.js
        tests/unit/classes/class_spec.js
        tests/unit/classes/deprecated_spec.js
        tests/unit/classes/translator_spec.js
        tests/unit/classes/utils_spec.js
        vendor/yarn.lock
        yarn.lock
        Please move or remove them before you merge.
        Aborting
        Where are these files? Should I just remove them?
        • N Offline
          @Kristianson
          Did you solve the problem, have you run
          git reset --hard
          • K Offline
            Kristianson
            Hi! Thank you for checking… I ran the git reset --hard and then the git pull && npm install but shorter error now… not sure if I should just remove the files? Never had this problem before:
            pi@raspberrypi_7:~/MagicMirror $ sudo git reset --hard
            HEAD is now at 532143c Merge pull request #1149 from bonaime/patch-1
            pi@raspberrypi_7:~/MagicMirror $ sudo git pull && npm install
            dangerfile.js
            fonts/yarn.lock
            module-types.ts
            vendor/yarn.lock
            yarn.lock
            Aborting
              Bob
              Not sure what I’ve done but when I run a git pull I now have a message that says I need to run “git commit -a” to fix the issues.
              What would happen if I did that ? Would it overwrite the main branch, or just create my own version of that branch ? I don’t have a git account, so would that cause issues as well ?
              • N Offline
                @Kristianson
                move or remove the files below
                dangerfile.js
                fonts/yarn.lock
                module-types.ts
                vendor/yarn.lock
                yarn.lock
                and then run
                • K Offline
                  Kristianson
                  removed those and now:
                  Removing tests/unit/translations/same_keys.js
                  Removing tests/unit/functions/class_spec.js
                  Auto-merging modules/default/currentweather/README.md
                  CONFLICT (content): Merge conflict in modules/default/currentweather/README.md
                  Automatic merge failed; fix conflicts and then commit the result.
                  Perhaps I should just re-install it? I even removed the currentweather default module (directory and the files)…
                  • justjim1220J Offline
                    justjim1220 Module Developer
                    With any of the default modules… If you made any changes to the .js files or the README.md files, AND, you would like to keep those changes… TRY THIS:
                    cut and paste any of the default modules from the MagicMirror directory to any other directory.
                    You also need to do the same for the package.json, package-lock.json, and your config.js file if there are any additional modules that have been added.
                    then do the ‘git pull $$ npm install’
                    when it is done, replace those files in the new MagicMirror that just got installed with the ones you saved from your old MagicMirror.
                    then do ‘npm rebuild’
                    It took a couple of times starting the MagicMirror to get all the changes to take…
                    this also fixes the currentweather module problem…
                    and the blank screen problem…
                    Jim Hallock - 1995
                    • K Offline
                      Kristianson
                      Thank your for the reply. I will give that a try… failing that I am going to re-install it…
                        Bob
                        Well, I couldn’t get it to work, so I just did a rebuild of the 2 mirrors. I keep a base build of the MM image anyway, so it only took an hour to recreate them both from scratch.
                        • K Offline
                          Kristianson
                          So I reinstalled it, however now when the MagicMirror starts the screen is just black…
                            crowbar @Bob
                            @Bob said in Problem updating to v2.3.1:
                            I ran the “git commit -a”, exited that screen, then ran sudo git pull & npm install and it worked for me then…Had the same issues above before that
