    Problem updating to v2.3.1
    17 Posts 6 Posters 10.9k Views 6 Watching
    • K Offline
      Kristianson
      No, tried that and a bit more info:
      pi@raspberrypi_7:~/MagicMirror $ git reset
      Unstaged changes after reset:
      M .eslintrc.json
      M .travis.yml
      M CHANGELOG.md
      M README.md
      M installers/raspberry.sh
      M js/class.js
      M js/main.js
      M js/module.js
      M js/translator.js
      M modules/README.md
      M modules/default/alert/README.md
      M modules/default/calendar/README.md
      M modules/default/calendar/calendarfetcher.js
      M modules/default/calendar/vendor/ical.js/test/test.js
      M modules/default/compliments/README.md
      M modules/default/compliments/compliments.js
      M modules/default/currentweather/README.md
      M modules/default/currentweather/currentweather.js
      M modules/default/newsfeed/README.md
      M modules/default/newsfeed/fetcher.js
      M modules/default/newsfeed/newsfeed.js
      M modules/default/updatenotification/updatenotification.js
      M modules/default/weatherforecast/weatherforecast.js
      M package-lock.json
      M package.json
      M tests/configs/check_config.js
      D tests/unit/functions/class_spec.js
      M tests/unit/functions/cmp_versions_spec.js
      D tests/unit/translations/same_keys.js
      M translations/af.json
      M translations/bg.json
      M translations/ca.json
      M translations/cs.json
      M translations/cy.json
      M translations/da.json
      M translations/de.json
      M translations/en.json
      M translations/es.json
      M translations/et.json
      M translations/fi.json
      M translations/fr.json
      M translations/hu.json
      M translations/id.json
      M translations/is.json
      M translations/kr.json
      M translations/nb.json
      M translations/nl.json
      M translations/nn.json
      M translations/pl.json
      M translations/pt.json
      M translations/ro.json
      M translations/ru.json
      M translations/sv.json
      M translations/zh_cn.json
      pi@raspberrypi_7:~/MagicMirror $ git pull && npm install
      error: Your local changes to the following files would be overwritten by merge:
      .eslintrc.json
      .travis.yml
      CHANGELOG.md
      README.md
      js/class.js
      js/main.js
      js/module.js
      js/translator.js
      modules/README.md
      package-lock.json
      package.json
      Please commit your changes or stash them before you merge.
      error: The following untracked working tree files would be overwritten by merge:
      dangerfile.js
      fonts/yarn.lock
      module-types.ts
      tests/configs/data/StripComments.json
      tests/configs/data/TranslationTest.json
      tests/configs/data/en.json
      tests/e2e/translations_spec.js
      tests/unit/classes/class_spec.js
      tests/unit/classes/deprecated_spec.js
      tests/unit/classes/translator_spec.js
      tests/unit/classes/utils_spec.js
      vendor/yarn.lock
      yarn.lock
      Please move or remove them before you merge.
      Aborting
      Where are these files? Should I just remove them?
      • N Offline
        NoNameRo @Kristianson
        @Kristianson
        Did you solve the problem, have you run
        git reset --hard
        • K Offline
          Kristianson
          Hi! Thank you for checking… I ran the git reset --hard and then the git pull && npm install but shorter error now… not sure if I should just remove the files? Never had this problem before:
          pi@raspberrypi_7:~/MagicMirror $ sudo git reset --hard
          HEAD is now at 532143c Merge pull request #1149 from bonaime/patch-1
          pi@raspberrypi_7:~/MagicMirror $ sudo git pull && npm install
          dangerfile.js
          fonts/yarn.lock
          module-types.ts
          vendor/yarn.lock
          yarn.lock
          Aborting
            Bob
            Not sure what I’ve done but when I run a git pull I now have a message that says I need to run “git commit -a” to fix the issues.
            What would happen if I did that ? Would it overwrite the main branch, or just create my own version of that branch ? I don’t have a git account, so would that cause issues as well ?
            • N Offline
              @Kristianson
              move or remove the files below
              dangerfile.js
              fonts/yarn.lock
              module-types.ts
              vendor/yarn.lock
              yarn.lock
              and then run
              • K Offline
                Kristianson
                removed those and now:
                Removing tests/unit/translations/same_keys.js
                Removing tests/unit/functions/class_spec.js
                Auto-merging modules/default/currentweather/README.md
                CONFLICT (content): Merge conflict in modules/default/currentweather/README.md
                Automatic merge failed; fix conflicts and then commit the result.
                Perhaps I should just re-install it? I even removed the currentweather default module (directory and the files)…
                • justjim1220J Offline
                  justjim1220 Module Developer
                  With any of the default modules… If you made any changes to the .js files or the README.md files, AND, you would like to keep those changes… TRY THIS:
                  cut and paste any of the default modules from the MagicMirror directory to any other directory.
                  You also need to do the same for the package.json, package-lock.json, and your config.js file if there are any additional modules that have been added.
                  then do the ‘git pull $$ npm install’
                  when it is done, replace those files in the new MagicMirror that just got installed with the ones you saved from your old MagicMirror.
                  then do ‘npm rebuild’
                  It took a couple of times starting the MagicMirror to get all the changes to take…
                  this also fixes the currentweather module problem…
                  and the blank screen problem…
                  Jim Hallock - 1995
                  • K Offline
                    Kristianson
                    Thank your for the reply. I will give that a try… failing that I am going to re-install it…
                      Bob
                      Well, I couldn’t get it to work, so I just did a rebuild of the 2 mirrors. I keep a base build of the MM image anyway, so it only took an hour to recreate them both from scratch.
                      • K Offline
                        Kristianson
                        So I reinstalled it, however now when the MagicMirror starts the screen is just black…
                          crowbar @Bob
                          @Bob said in Problem updating to v2.3.1:
                          I ran the “git commit -a”, exited that screen, then ran sudo git pull & npm install and it worked for me then…Had the same issues above before that
