    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 52.3k Views 10 Watching
      Charley Module Developer
      Just updated the new repo.
      It’s alive again.
      Thanks great job
      MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
        chef @MichMich
        @MichMich Thanks very much for the easter gift!
          Richard238
          Installed MM2.3.1, still got black screen
          Installed earlier version electron, still got black screen.
          Shutdown and restarted.
          Now nothing on :8080 either :(
          MichMichM S 2 Replies Last reply Reply Quote 0
          • MichMichM
            MichMich @Richard238
            @Richard238 Please share the steps you took to upgrade and the log files which shows errors.
              surger13 Project Sponsor @Richard238
              @Richard238 said in So ... to update MagicMirror I would ... ??:
              Same with me. I was not at home over Easter, had switched off the raspberry 3 days. Launched yesterday and just a black screen. :(
              After that I read this with the new update and executed it, unfortunately without any changes. The downgrade of electron described above also brought no change. Still a black screen and no display via ip:8080.
                Richard238 @MichMich
                @MichMich said in So ... to update MagicMirror I would ... ??:
                I followed the usual update routine.
                I don’t have any logs, as I’ve restored MM from an earlier SD card backup.
                MM working OK everywhere, it’s just telling me I’m 150 commits out-of-date.
                I’ll live with that until the electron black screen issue is resolved.
                MichMichM R 2 Replies Last reply Reply Quote 0
                • MichMichM
                  It is resolved in V2.3.1
                    I can’t get it to work anymore. :-(
                    have meanwhile updated the Raspi including firmware. MagicMirror directory renamed and reinstalled.
                    After booting only a black screen.
                    Does that mean anything to anyone?
                    pi@ftpi:~/MagicMirror $ npm start
                    > magicmirror@2.3.1 start /home/pi/MagicMirror
                    > sh run-start.sh
                    npm ERR! Linux 4.14.32-v7+
                    npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                    npm ERR! node v6.14.1
                    npm ERR! npm  v3.10.10
                    npm ERR! code ELIFECYCLE
                    npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                    npm ERR! Exit status 1
                    npm ERR!
                    npm ERR! Failed at the magicmirror@2.3.1 start script 'sh run-start.sh'.
                    npm ERR! If you do, this is most likely a problem with the magicmirror package,
                    npm ERR! not with npm itself.
                    npm ERR!     sh run-start.sh
                    npm ERR!     npm bugs magicmirror
                    npm ERR! Or if that isn't available, you can get their info via:
                    npm ERR!     npm owner ls magicmirror
                    npm ERR!     /home/pi/MagicMirror/npm-debug.log
                    • E
                      E3V3A @surger13
                      @surger13 Did you read the text?
                      – That’s exactly what it means.
                      “Everything I do (here) is for free – altruism is the way!”
                        surger13 Project Sponsor @E3V3A
                        @E3V3A
                        I thought I tried both. But it doesn’t matter now, I’ve redone everything. It’s back on now. Thanks for your help.
                          Richard238 @Richard238
                          @richard238 said in So ... to update MagicMirror I would ... ??:
                          Found the error logs from a backup I forgot I’d taken:
                          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                          /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
                          0|mm       |     at Function.Module._load (module.js:424:3)
                          0|mm       |     at Module.require (module.js:483:17)
                          0|mm       |     at require (internal/module.js:20:19)
                          0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:81:44)
                          0|mm       | Error: Module version mismatch. Expected 50, got 57.
                          0|mm       |     at Error (native)
                          0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                          0|mm       |     at Object.Module._extensions..node (module.js:583:18)
                          0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                          0|mm       |     at Module.load (module.js:473:32)
                          0|mm       |     at tryModuleLoad (module.js:432:12)
                          /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
                          0|mm       | Initializing new module helper ...
                          0|mm       | Module helper loaded: MMM-MyTemps
                          0|mm       | Module helper loaded: updatenotification
                          0|mm       | No helper found for module: clock.
                          0|mm       | Module helper loaded: calendar
                          0|mm       | No helper found for module: compliments.
                          0|mm       | No helper found for module: currentweather.
                          0|mm       | No helper found for module: weatherforecast.
                          0|mm       | No helper found for module: MMM-doomsDay.
                          0|mm       | Whoops! There was an uncaught exception...
                          0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                          0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                          0|mm       | Launching application.
                          I hope that helps find what’s wrong, and how to fix it.
                          Thanks!
                            bitfit2020
                            Dude -
                            My magicmirrior is DEAD !!! HELP !!! HELP !!!
                            This is STILL an issue … had the BLACK SCREEN after the npm pull && install npm
                            Now the mirror does not even start and I get a Javascript error !!!
                            I also got the 4 vulnerabilities (1 low, 2 high, 1 critical) after the install
                              sdetweil @chef
                              @chef use my upgrade script
                              see here
                                bitfit2020
                                U da man!!! I’m back on the playground :) Thanks.
                                  bitfit2020
                                  Must be some of my modules but with your default config mirror works but with my config I get a BLACK SCREEN.
                                  BTW, I did not upgrade (was a bit worried)… not sure if should do that !
                                    sdetweil @bitfit2020
                                    @bitfit2020 it gives u that control
                                    but glad u got it working
                                      @bitfit2020 i dont have a config in any of my scripts
                                      i used the sample doing install,
                                      config.js for upgrade
                                      and no confug for the screen saver and pm2 scripts at the end
                                      upgrade does what u are supposed to do manually, but breaks running systems with lots of none-base modules
                                      upgrade tries to detect and fix the breakage
                                      run 1st time it will just check if its possible upgrade would work
                                      second time with ‘apply’ parm will do the upgrade process. a log is kept of the process
                                      • 3 / 3
