    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 52.3k Views 10 Watching
      chef @MichMich
      @MichMich well-done.
        Montanaro
        Solution in this thread https://github.com/MichMich/MagicMirror/issues/1243
        in MagicMirror Folder
        npm install electron@1.4.15
        • E
          E3V3A @NoNameRo
          @NoNameRo
          You guys should probaly do pm2 stop mm; pm2 kill to make sure it’s not running in the background.
          Also, AFAIK, I think if you do git reset --hard you’d loose all your old config settings and other changes you’ve made?
          “Everything I do (here) is for free – altruism is the way!”
          MichMichM 1 Reply Last reply Reply Quote 1
          • MichMichM
            MichMich @E3V3A
            @E3V3A The Config & Modules folder are not part of the Git repro. All other changes are overwritten.
            • MichMichM
              MichMich
              I’ve released an update: https://github.com/MichMich/MagicMirror/releases/tag/v2.3.1
              • E
                E3V3A
                Just to say it…
                It seem that many people having problems, are running something out dated.
                Either: nodejs, npm, or pm2.
                Because of the incredible dependency chain involved for node packages, I can only assume that using a newer versions of one package, will also require a newer version of the package depending on it, and possibly vice versa. Of course when things are working, it all beautiful, but it seem very easy that it doesn’t.
                  Charley Module Developer
                  Just updated the new repo.
                  It’s alive again.
                  Thanks great job
                  MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
                    chef @MichMich
                    @MichMich Thanks very much for the easter gift!
                      Richard238
                      Installed MM2.3.1, still got black screen
                      Installed earlier version electron, still got black screen.
                      Shutdown and restarted.
                      Now nothing on :8080 either :(
                      MichMichM S 2 Replies Last reply Reply Quote 0
                      • MichMichM
                        MichMich @Richard238
                        @Richard238 Please share the steps you took to upgrade and the log files which shows errors.
                          surger13 Project Sponsor @Richard238
                          @Richard238 said in So ... to update MagicMirror I would ... ??:
                          Same with me. I was not at home over Easter, had switched off the raspberry 3 days. Launched yesterday and just a black screen. :(
                          After that I read this with the new update and executed it, unfortunately without any changes. The downgrade of electron described above also brought no change. Still a black screen and no display via ip:8080.
                            Richard238 @MichMich
                            @MichMich said in So ... to update MagicMirror I would ... ??:
                            I followed the usual update routine.
                            I don’t have any logs, as I’ve restored MM from an earlier SD card backup.
                            MM working OK everywhere, it’s just telling me I’m 150 commits out-of-date.
                            I’ll live with that until the electron black screen issue is resolved.
                            MichMichM R 2 Replies Last reply Reply Quote 0
                            • MichMichM
                              It is resolved in V2.3.1
                                I can’t get it to work anymore. :-(
                                have meanwhile updated the Raspi including firmware. MagicMirror directory renamed and reinstalled.
                                After booting only a black screen.
                                Does that mean anything to anyone?
                                pi@ftpi:~/MagicMirror $ npm start
                                > magicmirror@2.3.1 start /home/pi/MagicMirror
                                > sh run-start.sh
                                npm ERR! Linux 4.14.32-v7+
                                npm ERR! argv "/usr/bin/node" "/usr/bin/npm" "start"
                                npm ERR! node v6.14.1
                                npm ERR! npm  v3.10.10
                                npm ERR! code ELIFECYCLE
                                npm ERR! magicmirror@2.3.1 start: `sh run-start.sh`
                                npm ERR! Exit status 1
                                npm ERR!
                                npm ERR! Failed at the magicmirror@2.3.1 start script 'sh run-start.sh'.
                                npm ERR! If you do, this is most likely a problem with the magicmirror package,
                                npm ERR! not with npm itself.
                                npm ERR!     sh run-start.sh
                                npm ERR!     npm bugs magicmirror
                                npm ERR! Or if that isn't available, you can get their info via:
                                npm ERR!     npm owner ls magicmirror
                                npm ERR!     /home/pi/MagicMirror/npm-debug.log
                                • E
                                  E3V3A @surger13
                                  @surger13 Did you read the text?
                                  – That’s exactly what it means.
                                    surger13 Project Sponsor @E3V3A
                                    @E3V3A
                                    I thought I tried both. But it doesn’t matter now, I’ve redone everything. It’s back on now. Thanks for your help.
                                      Richard238 @Richard238
                                      @richard238 said in So ... to update MagicMirror I would ... ??:
                                      Found the error logs from a backup I forgot I’d taken:
                                      [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                                      /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
                                      0|mm       |     at Function.Module._load (module.js:424:3)
                                      0|mm       |     at Module.require (module.js:483:17)
                                      0|mm       |     at require (internal/module.js:20:19)
                                      0|mm       |     at bindings (/home/pi/MagicMirror/modules/MMM-PIR-Sensor/node_modules/bindings/bindings.js:81:44)
                                      0|mm       | Error: Module version mismatch. Expected 50, got 57.
                                      0|mm       |     at Error (native)
                                      0|mm       |     at process.module.(anonymous function) [as dlopen] (ELECTRON_ASAR.js:173:20)
                                      0|mm       |     at Object.Module._extensions..node (module.js:583:18)
                                      0|mm       |     at Object.module.(anonymous function) [as .node] (ELECTRON_ASAR.js:173:20)
                                      0|mm       |     at Module.load (module.js:473:32)
                                      0|mm       |     at tryModuleLoad (module.js:432:12)
                                      /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
                                      0|mm       | Initializing new module helper ...
                                      0|mm       | Module helper loaded: MMM-MyTemps
                                      0|mm       | Module helper loaded: updatenotification
                                      0|mm       | No helper found for module: clock.
                                      0|mm       | Module helper loaded: calendar
                                      0|mm       | No helper found for module: compliments.
                                      0|mm       | No helper found for module: currentweather.
                                      0|mm       | No helper found for module: weatherforecast.
                                      0|mm       | No helper found for module: MMM-doomsDay.
                                      0|mm       | Whoops! There was an uncaught exception...
                                      0|mm       | MagicMirror will not quit, but it might be a good idea to check why this happened. Maybe no internet connection?
                                      0|mm       | If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues
                                      0|mm       | Launching application.
                                      I hope that helps find what’s wrong, and how to fix it.
                                      Thanks!
                                        bitfit2020
                                        Dude -
                                        My magicmirrior is DEAD !!! HELP !!! HELP !!!
                                        This is STILL an issue … had the BLACK SCREEN after the npm pull && install npm
                                        Now the mirror does not even start and I get a Javascript error !!!
                                        I also got the 4 vulnerabilities (1 low, 2 high, 1 critical) after the install
                                          sdetweil @chef
                                          @chef use my upgrade script
                                          see here
                                            bitfit2020
                                            U da man!!! I’m back on the playground :) Thanks.
                                            • 3 / 3
