    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 48.7k Views 10 Watching
      chef @Cyberwrights
      @Cyberwrights said in So ... to update MagicMirror I would ... ??:
      v6.12.3
      Not working
      btw that command if anyone else needs to look it up is just
      $ node -v
      @Cyberwrights thanks for that … I just used ‘dpkg -l | grep ii | less’, and that took forever to find node … lol
      • MichMichM Offline
        MichMich
        My first thought there is an issue with electron. Looking into it.
        • MichMichM Offline
          MichMich
          Could someone try the following in the MagicMirror folder:
          npm install electron@1.4.15
          If this works, please state your Node version as well. (node -v)
          • H Offline
            Harry @MichMich
            @MichMich said in So ... to update MagicMirror I would ... ??:
            pi@ham-raspi:~/MagicMirror $ npm install electron@1.4.15
            electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
            node install.js
            • @types/node@8.10.1 node_modules/@types/node
              magicmirror@2.3.0 /home/pi/MagicMirror
              └── electron@1.4.15 invalid
            Node v6.12.3
            • MichMichM Offline
              MichMich
              Uhhmm… thats odd. It’s just a command to downgrade electron.
              • MichMichM Offline
                MichMich
                It seems to fix the issue for others. Not sure why you are unable to downgrade electron.
                https://github.com/MichMich/MagicMirror/issues/1243
                Could you reboot and try again @harry?
                H C 2 Replies Last reply Reply Quote 1
                • H Offline
                  Harry @MichMich
                  Yep. Reboot helped.
                  Rebooted, stopped MagicMirror and then the downgrade worked.
                  MagicMirror is up and running again!
                  Thanks a lot!
                    chef @MichMich
                    @MichMich well-done.
                      Montanaro
                      Solution in this thread https://github.com/MichMich/MagicMirror/issues/1243
                      in MagicMirror Folder
                      • E Offline
                        E3V3A @NoNameRo
                        @NoNameRo
                        You guys should probaly do pm2 stop mm; pm2 kill to make sure it’s not running in the background.
                        Also, AFAIK, I think if you do git reset --hard you’d loose all your old config settings and other changes you’ve made?
                        "Everything I do (here) is for free – altruism is the way!"
                        MichMichM 1 Reply Last reply Reply Quote 1
                        • MichMichM Offline
                          MichMich @E3V3A
                          @E3V3A The Config & Modules folder are not part of the Git repro. All other changes are overwritten.
                          • MichMichM Offline
                            MichMich
                            I’ve released an update: https://github.com/MichMich/MagicMirror/releases/tag/v2.3.1
                            • E Offline
                              E3V3A
                              Just to say it…
                              It seem that many people having problems, are running something out dated.
                              Either: nodejs, npm, or pm2.
                              Because of the incredible dependency chain involved for node packages, I can only assume that using a newer versions of one package, will also require a newer version of the package depending on it, and possibly vice versa. Of course when things are working, it all beautiful, but it seem very easy that it doesn’t.
                                Charley Module Developer
                                Just updated the new repo.
                                It’s alive again.
                                Thanks great job
                                MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
                                  chef @MichMich
                                  @MichMich Thanks very much for the easter gift!
                                    Richard238
                                    Installed MM2.3.1, still got black screen
                                    Installed earlier version electron, still got black screen.
                                    Shutdown and restarted.
                                    Now nothing on :8080 either :(
                                    MichMichM S 2 Replies Last reply Reply Quote 0
                                    • MichMichM Offline
                                      MichMich @Richard238
                                      @Richard238 Please share the steps you took to upgrade and the log files which shows errors.
                                        surger13 Project Sponsor @Richard238
                                        @Richard238 said in So ... to update MagicMirror I would ... ??:
                                        Same with me. I was not at home over Easter, had switched off the raspberry 3 days. Launched yesterday and just a black screen. :(
                                        After that I read this with the new update and executed it, unfortunately without any changes. The downgrade of electron described above also brought no change. Still a black screen and no display via ip:8080.
                                          Richard238 @MichMich
                                          I followed the usual update routine.
                                          I don’t have any logs, as I’ve restored MM from an earlier SD card backup.
                                          MM working OK everywhere, it’s just telling me I’m 150 commits out-of-date.
                                          I’ll live with that until the electron black screen issue is resolved.
                                          MichMichM R 2 Replies Last reply Reply Quote 0
                                          • MichMichM Offline
                                            It is resolved in V2.3.1
                                            • 2 / 3
