    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 53.1k Views 10 Watching
      chef
      Perhaps try stopping all instances of electron and node.
      Stop pm2
      Then try the install again.
      Reboot the Pi.
      C 1 Reply Last reply
      • MichMichM
        MichMich
        Could everyone state what version of node you are running? (And if it works or not).
        H 1 Reply Last reply
        • H
          Harry @MichMich
          @MichMich said in So ... to update MagicMirror I would ... ??:
          Mine is v6.12.3
          Not working…
            Richard238
            Node version = v6.9.5
              Cyberwrights
              v6.12.3
              Not working
              btw that command if anyone else needs to look it up is just
              $ node -v
              MMM-GoogleAssistant
              MMM-Hue
              MMM-MyCommute
              MMM-Formula1
              MMM-SystemStats
              MMM-moon-phases
                Charley Module Developer
                I am on v6.12.3
                And not working when I update npm install
                MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
                  Cyberwrights @chef
                  @chef said in So ... to update MagicMirror I would ... ??:
                  Stop pm2
                  Reboot the Pi.
                  Tried this, same result. Blank mirror although pm2 reports it is online.
                  MMM-GoogleAssistant
                  MMM-Hue
                  MMM-MyCommute
                  MMM-Formula1
                  MMM-SystemStats
                  MMM-moon-phases
                    chef
                    Working on node version 6.13.1
                    I think I can see where this is going… The blank screen is the mirror running, but there could be an issue with loading the page data? …
                      chef @Cyberwrights
                      @Cyberwrights said in So ... to update MagicMirror I would ... ??:
                      v6.12.3
                      Not working
                      $ node -v
                      @Cyberwrights thanks for that … I just used ‘dpkg -l | grep ii | less’, and that took forever to find node … lol
                      • MichMichM
                        MichMich
                        My first thought there is an issue with electron. Looking into it.
                        • MichMichM
                          MichMich
                          Could someone try the following in the MagicMirror folder:
                          npm install electron@1.4.15
                          If this works, please state your Node version as well. (node -v)
                          • H
                            Harry @MichMich
                            pi@ham-raspi:~/MagicMirror $ npm install electron@1.4.15
                            electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                            node install.js
                            • @types/node@8.10.1 node_modules/@types/node
                              magicmirror@2.3.0 /home/pi/MagicMirror
                              └── electron@1.4.15 invalid
                            Node v6.12.3
                            • MichMichM
                              MichMich
                              Uhhmm… thats odd. It’s just a command to downgrade electron.
                              • MichMichM
                                MichMich
                                It seems to fix the issue for others. Not sure why you are unable to downgrade electron.
                                https://github.com/MichMich/MagicMirror/issues/1243
                                Could you reboot and try again @harry?
                                H C 2 Replies Last reply
                                • H
                                  Harry @MichMich
                                  Yep. Reboot helped.
                                  Rebooted, stopped MagicMirror and then the downgrade worked.
                                  MagicMirror is up and running again!
                                  Thanks a lot!
                                    chef @MichMich
                                    @MichMich well-done.
                                      Montanaro
                                      Solution in this thread https://github.com/MichMich/MagicMirror/issues/1243
                                      in MagicMirror Folder
                                      • E
                                        E3V3A @NoNameRo
                                        @NoNameRo
                                        You guys should probaly do pm2 stop mm; pm2 kill to make sure it’s not running in the background.
                                        Also, AFAIK, I think if you do git reset --hard you’d loose all your old config settings and other changes you’ve made?
                                        “Everything I do (here) is for free – altruism is the way!”
                                        MichMichM 1 Reply Last reply
                                        • MichMichM
                                          MichMich @E3V3A
                                          @E3V3A The Config & Modules folder are not part of the Git repro. All other changes are overwritten.
                                          Reply Quote 2
                                          • MichMichM
                                            MichMich
                                            I’ve released an update: https://github.com/MichMich/MagicMirror/releases/tag/v2.3.1
                                            • 2 / 3
