    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 53.1k Views 10 Watching
    • N
      NoNameRo
      I do not know if it is absolutely necessary to stop the service, for me it was obvious to do it
      E 1 Reply Last reply
        chef
        Perhaps try stopping all instances of electron and node.
        Stop pm2
        Then try the install again.
        Reboot the Pi.
        C 1 Reply Last reply
        • MichMichM
          MichMich
          Could everyone state what version of node you are running? (And if it works or not).
          H 1 Reply Last reply
          • H
            Harry @MichMich
            @MichMich said in So ... to update MagicMirror I would ... ??:
            Mine is v6.12.3
            Not working…
              Richard238
              Node version = v6.9.5
                Cyberwrights
                v6.12.3
                Not working
                btw that command if anyone else needs to look it up is just
                $ node -v
                MMM-GoogleAssistant
                MMM-Hue
                MMM-MyCommute
                MMM-Formula1
                MMM-SystemStats
                MMM-moon-phases
                  Charley Module Developer
                  I am on v6.12.3
                  And not working when I update npm install
                  MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
                    Cyberwrights @chef
                    @chef said in So ... to update MagicMirror I would ... ??:
                    Stop pm2
                    Reboot the Pi.
                    Tried this, same result. Blank mirror although pm2 reports it is online.
                    MMM-GoogleAssistant
                    MMM-Hue
                    MMM-MyCommute
                    MMM-Formula1
                    MMM-SystemStats
                    MMM-moon-phases
                      chef
                      Working on node version 6.13.1
                      I think I can see where this is going… The blank screen is the mirror running, but there could be an issue with loading the page data? …
                        chef @Cyberwrights
                        @Cyberwrights said in So ... to update MagicMirror I would ... ??:
                        v6.12.3
                        Not working
                        $ node -v
                        @Cyberwrights thanks for that … I just used ‘dpkg -l | grep ii | less’, and that took forever to find node … lol
                        • MichMichM
                          MichMich
                          My first thought there is an issue with electron. Looking into it.
                          • MichMichM
                            MichMich
                            Could someone try the following in the MagicMirror folder:
                            npm install electron@1.4.15
                            If this works, please state your Node version as well. (node -v)
                            • H
                              Harry @MichMich
                              pi@ham-raspi:~/MagicMirror $ npm install electron@1.4.15
                              electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                              node install.js
                              • @types/node@8.10.1 node_modules/@types/node
                                magicmirror@2.3.0 /home/pi/MagicMirror
                                └── electron@1.4.15 invalid
                              Node v6.12.3
                              • MichMichM
                                MichMich
                                Uhhmm… thats odd. It’s just a command to downgrade electron.
                                • MichMichM
                                  MichMich
                                  It seems to fix the issue for others. Not sure why you are unable to downgrade electron.
                                  https://github.com/MichMich/MagicMirror/issues/1243
                                  Could you reboot and try again @harry?
                                  H C 2 Replies Last reply
                                  • H
                                    Harry @MichMich
                                    Yep. Reboot helped.
                                    Rebooted, stopped MagicMirror and then the downgrade worked.
                                    MagicMirror is up and running again!
                                    Thanks a lot!
                                      chef @MichMich
                                      @MichMich well-done.
                                        Montanaro
                                        Solution in this thread https://github.com/MichMich/MagicMirror/issues/1243
                                        in MagicMirror Folder
                                        • E
                                          E3V3A @NoNameRo
                                          @NoNameRo
                                          You guys should probaly do pm2 stop mm; pm2 kill to make sure it’s not running in the background.
                                          Also, AFAIK, I think if you do git reset --hard you’d loose all your old config settings and other changes you’ve made?
                                          “Everything I do (here) is for free – altruism is the way!”
                                          MichMichM 1 Reply Last reply
                                          • MichMichM
                                            MichMich @E3V3A
                                            @E3V3A The Config & Modules folder are not part of the Git repro. All other changes are overwritten.
                                            Reply Quote 2
                                            • 2 / 3
