    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 47.7k Views 10 Watching
      Richard238
      Node version = v6.9.5
        Cyberwrights
        v6.12.3
        Not working
        btw that command if anyone else needs to look it up is just
        $ node -v
        MMM-GoogleAssistant
        MMM-Hue
        MMM-MyCommute
        MMM-Formula1
        MMM-SystemStats
        MMM-moon-phases
          Charley Module Developer
          I am on v6.12.3
          And not working when I update npm install
          MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
            Cyberwrights @chef
            @chef said in So ... to update MagicMirror I would ... ??:
            Perhaps try stopping all instances of electron and node.
            Stop pm2
            Then try the install again.
            Reboot the Pi.
            Tried this, same result. Blank mirror although pm2 reports it is online.
            MMM-GoogleAssistant
            MMM-Hue
            MMM-MyCommute
            MMM-Formula1
            MMM-SystemStats
            MMM-moon-phases
              chef
              Working on node version 6.13.1
              I think I can see where this is going… The blank screen is the mirror running, but there could be an issue with loading the page data? …
                chef @Cyberwrights
                @Cyberwrights said in So ... to update MagicMirror I would ... ??:
                v6.12.3
                Not working
                $ node -v
                @Cyberwrights thanks for that … I just used ‘dpkg -l | grep ii | less’, and that took forever to find node … lol
                • MichMichM Offline
                  MichMich
                  My first thought there is an issue with electron. Looking into it.
                  • MichMichM Offline
                    MichMich
                    Could someone try the following in the MagicMirror folder:
                    npm install electron@1.4.15
                    If this works, please state your Node version as well. (node -v)
                    • H Offline
                      Harry @MichMich
                      @MichMich said in So ... to update MagicMirror I would ... ??:
                      pi@ham-raspi:~/MagicMirror $ npm install electron@1.4.15
                      electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
                      node install.js
                      • @types/node@8.10.1 node_modules/@types/node
                        magicmirror@2.3.0 /home/pi/MagicMirror
                        └── electron@1.4.15 invalid
                      Node v6.12.3
                      • MichMichM Offline
                        MichMich
                        Uhhmm… thats odd. It’s just a command to downgrade electron.
                        • MichMichM Offline
                          MichMich
                          It seems to fix the issue for others. Not sure why you are unable to downgrade electron.
                          https://github.com/MichMich/MagicMirror/issues/1243
                          Could you reboot and try again @harry?
                          H C 2 Replies Last reply Reply Quote 1
                          • H Offline
                            Harry @MichMich
                            Yep. Reboot helped.
                            Rebooted, stopped MagicMirror and then the downgrade worked.
                            MagicMirror is up and running again!
                            Thanks a lot!
                              chef @MichMich
                              @MichMich well-done.
                                Montanaro
                                Solution in this thread https://github.com/MichMich/MagicMirror/issues/1243
                                in MagicMirror Folder
                                • E Offline
                                  E3V3A @NoNameRo
                                  @NoNameRo
                                  You guys should probaly do pm2 stop mm; pm2 kill to make sure it’s not running in the background.
                                  Also, AFAIK, I think if you do git reset --hard you’d loose all your old config settings and other changes you’ve made?
                                  "Everything I do (here) is for free – altruism is the way!"
                                  MichMichM 1 Reply Last reply Reply Quote 1
                                  • MichMichM Offline
                                    MichMich @E3V3A
                                    @E3V3A The Config & Modules folder are not part of the Git repro. All other changes are overwritten.
                                    • MichMichM Offline
                                      MichMich
                                      I’ve released an update: https://github.com/MichMich/MagicMirror/releases/tag/v2.3.1
                                      • E Offline
                                        E3V3A
                                        Just to say it…
                                        It seem that many people having problems, are running something out dated.
                                        Either: nodejs, npm, or pm2.
                                        Because of the incredible dependency chain involved for node packages, I can only assume that using a newer versions of one package, will also require a newer version of the package depending on it, and possibly vice versa. Of course when things are working, it all beautiful, but it seem very easy that it doesn’t.
                                          Just updated the new repo.
                                          It’s alive again.
                                          Thanks great job
                                            chef @MichMich
                                            @MichMich Thanks very much for the easter gift!
                                            • 2 / 3
