    So ... to update MagicMirror I would ... ??
    54 Posts 12 Posters 52.3k Views 10 Watching
      chef
      Working on node version 6.13.1
      I think I can see where this is going… The blank screen is the mirror running, but there could be an issue with loading the page data? …
        chef @Cyberwrights
        @Cyberwrights said in So ... to update MagicMirror I would ... ??:
        v6.12.3
        Not working
        btw that command if anyone else needs to look it up is just
        $ node -v
        @Cyberwrights thanks for that … I just used ‘dpkg -l | grep ii | less’, and that took forever to find node … lol
        • MichMichM
          MichMich
          My first thought there is an issue with electron. Looking into it.
          • MichMichM
            MichMich
            Could someone try the following in the MagicMirror folder:
            npm install electron@1.4.15
            If this works, please state your Node version as well. (node -v)
            • H
              Harry @MichMich
              @MichMich said in So ... to update MagicMirror I would ... ??:
              pi@ham-raspi:~/MagicMirror $ npm install electron@1.4.15
              electron@1.4.15 postinstall /home/pi/MagicMirror/node_modules/electron
              node install.js
              • @types/node@8.10.1 node_modules/@types/node
                magicmirror@2.3.0 /home/pi/MagicMirror
                └── electron@1.4.15 invalid
              Node v6.12.3
              • MichMichM
                MichMich
                Uhhmm… thats odd. It’s just a command to downgrade electron.
                • MichMichM
                  MichMich
                  It seems to fix the issue for others. Not sure why you are unable to downgrade electron.
                  https://github.com/MichMich/MagicMirror/issues/1243
                  Could you reboot and try again @harry?
                  H C 2 Replies Last reply Reply Quote 1
                  • H
                    Harry @MichMich
                    Yep. Reboot helped.
                    Rebooted, stopped MagicMirror and then the downgrade worked.
                    MagicMirror is up and running again!
                    Thanks a lot!
                      chef @MichMich
                      @MichMich well-done.
                        Montanaro
                        Solution in this thread https://github.com/MichMich/MagicMirror/issues/1243
                        in MagicMirror Folder
                        • E
                          E3V3A @NoNameRo
                          @NoNameRo
                          You guys should probaly do pm2 stop mm; pm2 kill to make sure it’s not running in the background.
                          Also, AFAIK, I think if you do git reset --hard you’d loose all your old config settings and other changes you’ve made?
                          “Everything I do (here) is for free – altruism is the way!”
                          MichMichM 1 Reply Last reply Reply Quote 1
                          • MichMichM
                            MichMich @E3V3A
                            @E3V3A The Config & Modules folder are not part of the Git repro. All other changes are overwritten.
                            • MichMichM
                              MichMich
                              I’ve released an update: https://github.com/MichMich/MagicMirror/releases/tag/v2.3.1
                              • E
                                E3V3A
                                Just to say it…
                                It seem that many people having problems, are running something out dated.
                                Either: nodejs, npm, or pm2.
                                Because of the incredible dependency chain involved for node packages, I can only assume that using a newer versions of one package, will also require a newer version of the package depending on it, and possibly vice versa. Of course when things are working, it all beautiful, but it seem very easy that it doesn’t.
                                  Charley Module Developer
                                  Just updated the new repo.
                                  It’s alive again.
                                  Thanks great job
                                  MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
                                    chef @MichMich
                                    @MichMich Thanks very much for the easter gift!
                                      Richard238
                                      Installed MM2.3.1, still got black screen
                                      Installed earlier version electron, still got black screen.
                                      Shutdown and restarted.
                                      Now nothing on :8080 either :(
                                      MichMichM S 2 Replies Last reply Reply Quote 0
                                      • MichMichM
                                        MichMich @Richard238
                                        @Richard238 Please share the steps you took to upgrade and the log files which shows errors.
                                          surger13 Project Sponsor @Richard238
                                          @Richard238 said in So ... to update MagicMirror I would ... ??:
                                          Same with me. I was not at home over Easter, had switched off the raspberry 3 days. Launched yesterday and just a black screen. :(
                                          After that I read this with the new update and executed it, unfortunately without any changes. The downgrade of electron described above also brought no change. Still a black screen and no display via ip:8080.
                                            Richard238 @MichMich
                                            I followed the usual update routine.
                                            I don’t have any logs, as I’ve restored MM from an earlier SD card backup.
                                            MM working OK everywhere, it’s just telling me I’m 150 commits out-of-date.
                                            I’ll live with that until the electron black screen issue is resolved.
                                            MichMichM R 2 Replies Last reply Reply Quote 0
                                            • 2 / 3
