    npm install not installing
    6 Posts 3 Posters 2.5k Views 3 Watching
      Dennis27
      Hi everyone,
      I need some help. I was trying to install the weather module MMM-NOAA but I was getting the following error while installing npm in the MMM-NOAA directory.
      pi@raspberrypi:~/MagicMirror/modules/MMM-NOAA $ npm install
      npm WARN grunt-stylelint@0.10.0 requires a peer of stylelint@^9.0.0 but none was installed.
      npm WARN stylelint-config-recommended@2.1.0 requires a peer of stylelint@^8.3.0 || ^9.0.0 but none was installed.
      npm WARN stylelint-config-standard@18.2.0 requires a peer of stylelint@^8.3.0 || ^9.0.0 but none was installed.
      Just before I tried to install MMM-NOAA I updated to MagicMirror² v2.3.1. I don’t know if this is part of the problem.
      any suggestions? Many thanks in advanced.
      • E Offline
        E3V3A
        Ask @cowboysdude
        "Everything I do (here) is for free – altruism is the way!"
          Mykle1 Project Sponsor Module Developer @Dennis27
          @Dennis27
          Have you tried running the module? Those warnings should not affect the operation of MM or that module.
            Dennis27
            Thank you @Mykle1, it is now working, I had a syntax error in the config file.
              @Dennis27 said in npm install not installing:
              I hate when that happens. :-)
                Dennis27 @Mykle1
                @Mykle1
                yep, classic mistake…
