MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder
45 Posts 6 Posters 23.7k Views 5 Watching
    AxLed Module Developer
    Here is my first module.
    Description
    A module to connect a rotary encoder to MagicMirror and use it for Navigation inside of MagicMirror I wanted to use interaction to the MagicMirror and decided to use a rotary encoder, which has 3 functions: Clockwise, Counterclockwise and Press. These fucntions where combined to a navigation, so you have some possibilities, f.e.: Page increment/decrement, Newsfeed Article more/less details and actions for notification system. The navigation fades out, if not used.
    Screenshot
    MMM-Navigate
    Download
    [card:Ax-LED/MMM-Navigate]
    Update 06.06.2018
    Version 1.1 is online
    Changelog:
    • added ability to send notifications to MMM-Navigate by other modules
    • added locked mode, so you can put two(2) actions in one(1) navigation link which belong together (like PAGE_INCREMENT and PAGE_DECREMENT). More details see Configuration options (Action).
    • modified css, so locked mode is visual (red frame when locked) in MM
    • added second click confirmation notification’ for the following REMOTE_ACTIONs (SHUTDOWN, RESTART, REBOOT)
    Please let me know what you think.
    AxLED
    Y 1 Reply Last reply May 13, 2018, 8:45 PM Reply Quote 0
    • Y Offline
      yawns Moderator @AxLed
      @axled said in MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder:
      @admins: How can i insert the github card for my module?
      You use this code, just without spaces
      [ card:Ax-LED/MMM-Navigate ]
        Thank you yawns
          Hi to all,
          version 1.1 is online, details see first topic of this thread.
          AxLED
            AgP42 Project Sponsor Module Developer
            I am using your module what is really great and works perfectly fine on my side.
            I configure it to allow some others fonctions, after finding out that the fonctions from the module “MMM-Remote-Control” can be used on your navigation module. I also read part of the “node_helper.js” of this module to try to find out the possibilities avaliable.
            This allow me to add the ability of “refresh” and “monitoroff” and “monitoron” on my navigation menu :
                                    module: "MMM-Navigate",
                                    header: "Navigation",
                                    position: "middle_center",
                                                    Alias: [
                                                            'Changer de Page (Press puis rotation)',
                                                            'Luminosité écran (Press puis rotation)',
                                                            'Afficher adresse Remote',
                                                            'Ecran off/on (Press puis rotation)',
                                                            'Recharger affichage',
                                                            'Redemarrer le MagicMirror',
                                                            'Reboot RPI',
                                                            'Shutdown RPI'
                                                    Action: [
                                                            [{notification:'PAGE_INCREMENT',payload:''},{notification:'PAGE_DECREMENT',payload:''}],//action array, first press locks menu, after this rotation CW/CCW executes, second press release lo$
                                                            [{notification: "REMOTE_ACTION", payload: {action: "BRIGHTNESS&value=100"}},{notification: "REMOTE_ACTION", payload: {action: "BRIGHTNESS&value=50"}}],
                                                            {notification: "SHOW_ALERT", payload: {type:"notification",message:"http://192.168.xx.xx:8080/remote.html"}},//single action, execute on press
                                                            [{notification: "REMOTE_ACTION", payload: {action: "MONITOROFF"}},{notification: "REMOTE_ACTION", payload: {action: "MONITORON"}}],
                                                            {notification: "REMOTE_ACTION", payload: {action: "REFRESH"}},
                                                            {notification: "REMOTE_ACTION", payload: {action: "RESTART"}},
                                                            {notification: "REMOTE_ACTION", payload: {action: "REBOOT"}},
                                                            {notification: "REMOTE_ACTION", payload: {action: "SHUTDOWN"}}
                                                    GPIOPins: [26,20,19]//rotary cw, rotary ccw, rotary press (BCM Numbering)
            But then I tried 2 others improvment that I couln’t fullfill :
            • change the timer value to display the notification : to do so I add the value “timer” for the notification :
             {notification: "SHOW_ALERT", payload: {type:"notification",message:"http://192.168.xx.xx:8080/remote.html",timer: 15}},
            But this had no impact…
            • add the possibility to change the brightness of the screen directly from the navigation menu, to do so I tried :
            but also :
            [{notification: "REMOTE_ACTION", payload: {action: "BRIGHTNESS", value:100}},{notification: "REMOTE_ACTION", payload: {action: "BRIGHTNESS", value:50}}],
            but no way to make it work…
            Would you have any advice how to realize such fonctions ?
            Thank you in advance,
              @AgP42
              thanks for your request, i checked my code and can give you a solution for the brightness issue.
              I found out, that it seems to be a problem with MMM-Remote-Control, node_helper.js
              But there is a workaround:
              Replace line 618
              res.send({"status": "success"});
              through
              if (res) { res.send({"status": "success"}); }
              Thanks to glitch452 who found the error, details see:
              https://github.com/Jopyth/MMM-Remote-Control/issues/76
              Sample code for config.js, Module MMM-Navigate:
              {notification: "REMOTE_ACTION", payload: {action: "BRIGHTNESS", value: "200"}},
              AxLED
                Great ! Thank you so much !
                But as said on the link you gave :
                the line to replace is
                and not
                 self.sendSocketNotification(query.action, query.value);
                Then it is working perfectly !
                  @AgP42
                  You are right, i told you the wrong line, i corrected my thread above.
                  I am glad it is working on your MM as needed.
                  AxLED
                    Hi to all MM Builders,
                    i made an update to my module MMM-Navigate.
                    1.2 Changelog:
                    • tadded lock icon next to navigation alias, if locked
                    • code cleaned
                    Happy navigation.
                    AxLED
                    • E Offline
                      Eisblume
                      i installed this module with the Rotary Encoder KY-040. Scroll through navigation work fine, but nothing happened, when I press the button on the encoder.
                      Test with Url (yourmmip:8080/remote?action=NOTIFICATION&notification=PRESSED) works fine.
                      What could be the problem ??
                      • 1 / 5
