    MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder
    45 Posts 6 Posters 27.2k Views 5 Watching
      AxLed Module Developer
      @AgP42
      thanks for your request, i checked my code and can give you a solution for the brightness issue.
      I found out, that it seems to be a problem with MMM-Remote-Control, node_helper.js
      But there is a workaround:
      Replace line 618
      res.send({"status": "success"});
      through
      if (res) { res.send({"status": "success"}); }
      Thanks to glitch452 who found the error, details see:
      https://github.com/Jopyth/MMM-Remote-Control/issues/76
      Sample code for config.js, Module MMM-Navigate:
      {notification: "REMOTE_ACTION", payload: {action: "BRIGHTNESS", value: "200"}},
      AxLED
        AgP42 Project Sponsor Module Developer
        Great ! Thank you so much !
        But as said on the link you gave :
        @axled said in MMM-Navigate, Navigation inside MagicMirror with Rotary Encoder:
        the line to replace is
        and not
         self.sendSocketNotification(query.action, query.value);
        Then it is working perfectly !
          @AgP42
          You are right, i told you the wrong line, i corrected my thread above.
          I am glad it is working on your MM as needed.
          AxLED
            Hi to all MM Builders,
            i made an update to my module MMM-Navigate.
            1.2 Changelog:
            • tadded lock icon next to navigation alias, if locked
            • code cleaned
            Happy navigation.
            AxLED
            • E Offline
              Eisblume
              i installed this module with the Rotary Encoder KY-040. Scroll through navigation work fine, but nothing happened, when I press the button on the encoder.
              Test with Url (yourmmip:8080/remote?action=NOTIFICATION&notification=PRESSED) works fine.
              What could be the problem ??
                @Eisblume
                Did you use the right Pin (either in config or on the pi) for the ‘press’ signal of the rotary encoder?
                Is the module MMM-Remote-Control installed and working?
                AxLED
                • E Offline
                  Eisblume
                  yes Pin 19, like you suggested. Everything else works fine, only the press action doesn’t work.
                  MMM-Remote-Control is installed.
                  I ordered a new Rotary Encoder, maybe this one I use has a defect .
                  Eisblume
                    @Eisblume
                    You can also try to put clockwise or counterclockwise signal on pin 19 for testing, so cw or ccw should send the press command. So you can make sure if press switch of your rotary encoder is bad.
                    AxLED
                    • E Offline
                      Eisblume
                      Thx for support !!
                      I will try and report !!
                      • E Offline
                        Eisblume
                        @AxLED
                        I bought some new Rotary Encoders and with each one i had the same result. No press result will send, when i press the button :-( !
                        But when i put cw or cww on pin 19, the press signal will send when i turn cw or cww.
                        I tried other Pins for the press Signal, but it also doesn´t work.
                        I am confused…! Any ideas what i can try to solve my Problem?
                        Greets
                        Eisblume
                          @Eisblume
                          So the pin is correct. Some ideas.
                          Press contains two operations, pressing and release. Did you try press and release in different speeds?
                          How long are your cables between rotary and pi? Could also be a debouncing problem. Which pi are you using? (I tested the module on pi 1 and pi 3).
                          AxLED
                          • E Offline
                            Eisblume
                            @AxLed
                            I use a Raspberry Pi 3 b+. The F2F cables between the rotary and the pi are 20cm long.
                            I tried different speeds for pressing and releasing.
                            When i debug the code, no action arrives when i press the button.
                            Is it possible that there are problem with other modules I use ??
                            Eisblume
                              @Eisblume
                              Conflicts with other modules are possible, but i dont think so, because press on cw/ccw works. You can try to change debounce time in node helper (i think, i am not sure about as i am on the road right now). I will check for the final line in node helper and let you know if i am in front of my computer.
                              AxLED
                                @Eisblume
                                I found the line in node_helper.js, its line 35
                                const C = new Gpio(self.config.GPIOPins[2], 'in', 'both',{debounceTimeout : 20 }); //BCM Pin 19
                                Here you can try to increase/reduce the debounceTimeout between 10 and 50 (in steps of 10) and see if there is a difference for your “pressed” problem.
                                AxLED
                                • E Offline
                                  Eisblume
                                  @AxLed
                                  I tried every very with different press speed. It doesn’t work. No press Signal will be sent :-(
                                  I don´t understand why cw and cww works fine, but not the press - Button?
                                  Edit:
                                  I test the Rotary with this: https://github.com/martinohanlon/KY040
                                  Here the press button works fine.
                                  pi@raspberrypi:~/EncoderTest/KY040/examples $ python python3.py
                                  turned - 0
                                  turned - 0
                                  turned - 1
                                  turned - 1
                                  button pressed
                                  button pressed
                                  button pressed
                                  button pressed
                                  button pressed
                                  button pressed
                                    @Eisblume
                                    Please post your config and make sure your private keys are x-ed. So i can try to copy your setup to my test pi and maybe find out whats the reason. That your rotary encoder generally works is good to know.
                                    AxLED
                                    • E Offline
                                      Eisblume
                                      Ok, thanks @AxLed !!
                                      config.js:
                                      /* Magic Mirror Config Sample
                                       * MIT Licensed.
                                      var config = {
                                      	address: "0.0.0.0", // Address to listen on, can be:
                                      	port: 8080,
                                      	ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1", "::ffff:192.168.1.1/120", "192.168.1.1/24"], // Set [] to allow all IP addresses
                                      	language: "de",
                                      	timeFormat: 24,
                                      	units: "metric",
                                      			module: "alert",
                                      			module: "clock",
                                      			position: "top_left"
                                      			module: "MMM-Navigate",
                                      			header: "Navigation",
                                      					Alias: [
                                      						'Seiten blättern',
                                      						'News (mehr/weniger Details)',
                                      						'Test notification',
                                      						'News - mehr Details',
                                      						'News - weniger Details',
                                      						'Neustart MagicMirror (PM2)',
                                      						'Neustart',
                                      						'Herunterfahren'
                                      					Action: [
                                      						[{notification:'PAGE_INCREMENT',payload:''},{notification:'PAGE_DECREMENT',payload:''}],//action array, first press locks menu, after this rotation CW/CCW executes, second press release lock mode
                                      						[{notification:'ARTICLE_MORE_DETAILS',payload:''},{notification:'ARTICLE_LESS_DETAILS',payload:''}],
                                      						{notification: "SHOW_ALERT", payload: {type:"notification",message:"Dies ist eine Testnachricht"}},//single action, execute on press
                                      						{notification:'ARTICLE_LESS_DETAILS',payload:''},
                                      						{notification: "REMOTE_ACTION", payload: {action: "RESTART"}},
                                      						{notification: "REMOTE_ACTION", payload: {action: "REBOOT"}},
                                      						{notification: "REMOTE_ACTION", payload: {action: "SHUTDOWN"}}
                                      					GPIOPins: [26,20,19]//rotary cw, rotary ccw, rotary press (BCM Numbering)
                                          		module: 'MMM-Remote-Control',
                                          		// , position: 'bottom_left'
                                              		customCommand: {},  // Optional, See "Using Custom Commands" below
                                              		customMenu: "custom_menu.json", // Optional, See "Custom Menu Items" below
                                              		showModuleApiMenu: true, // Optional, Enable the Module Controls menu
                                              		apiKey: ""         // Optional, See API/README.md for details
                                      			module: "updatenotification",
                                      			position: "top_bar"
                                      			header: "Familie Reetz",
                                      						symbol: "calendar-check",
                                      						url: "webcal://pxxxxxxm/xxxxxxxKSw_tdQ8WGeTZVjgr6Vwn1HDxxxxxxx5OuupPnKOIExxxx"
                                      //			module: "compliments",
                                      //			position: "lower_third"
                                      			module: "currentweather",
                                      				locationID: "xxx",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                                      				appid: "xxxxx"
                                      			module: "weatherforecast",
                                      			header: "Wettervorhersage",
                                      				locationID: "xxxx",  //ID from https://openweathermap.org/city
                                      				appid: "xxxxx"
                                      			module: "newsfeed",
                                      			position: "bottom_bar",
                                      				feeds: [
                                      						title: "Tagesschau",
                                      						url: "http://www.tagesschau.de/xml/rss2"
                                      						//url: "http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml"
                                      				showSourceTitle: true,
                                      				showPublishDate: true
                                          		module: "MMM-Fuel",
                                          		position: "bottom_left",
                                              			api_key: "xxxxx",
                                              			lat: 123456,
                                              			lng: 654321,
                                              			types: ["diesel"],
                                              			radius: 15,
                                              			max: 3
                                      	        module: 'MMM-Dreambox',
                                      			header: 'Vu+ Ultimo4K powered by VTi',
                                      			position: 'bottom_right',
                                      				apiBase: 'http://192.168.1.50:90',
                                      				//omxargs: ' --vol -6000 --win 0,625,590,957 --live ',
                                      				omxargs: ' --win 600,60,1490,940 -o both ',
                                      				refreshInterval: 1000 * 30, //refresh every 30 seconds
                                      				apibouquet: 0, //bouquet, if there is more than one under apiservices (/web/getallservices),
                                      				apiRecordingsID: 0, //which recording folder should be listed
                                      				listmax: 10,
                                      				apiabout: '/web/about',
                                      				apiservices: '/web/getallservices',
                                      				apiepgnow: '/web/epgnow?bRef=',
                                      				apizap: '/web/zap?sRef=',
                                      				apiTimerlist: '/web/timerlist',
                                      				apiServicelistplayable: '/web/servicelistplayable?sRef=',
                                      				apiLocations: '/web/getlocations', //where are the recording folders listed
                                      				apiMovielist: '/web/movielist?dirname=' //link for opening recording folder and list recordings
                                        @Eisblume
                                        I tested wih modules of your config.
                                        My testconfiguration:
                                        • Raspberry Pi 1
                                        • MagicMirror v2.7.1
                                        • npm v6.8.0
                                        • node v8.9.0
                                        • no electron (as i dont run/installable on Pi 1), i run node serveronly
                                        • display: Webbrowser
                                        My rotary encoder works as follows:
                                        • Seite blättern (press works and gives a red frame an a lock sign, cw an ccw dont work, as MMM-Pages isnt part of your config)
                                        • News (mehr/weniger Details) (press works and gives a red frame an a lock sign, cw an ccw works)
                                        • Test notification (press works, no cw or ccw functionality by design)
                                        • News - mehr Details (press works, no cw or ccw functionality by design)
                                        • News - weniger Details (press works, no cw or ccw functionality by design)
                                        • Neustart MagicMirror (PM2) (dont work in my testconfiguration, as i dont use PM on RPI1)
                                        • Neustart (press works, there is a pop up notification to press twice for reeboot, requires MMM-Remote-Control)
                                        • Herunterfahren (press works, there is a pop up notification to press twice for shutdown, requires MMM-Remote-Control)
                                        Two ideas:
                                        • wrong cabeling, here are the 3 pins for CW, CW and PRESS of your config.js (GPIOPins: [26,20,19])
                                        • messed up setup, try to save your config and reinstall raspian an MM
                                        Greets
                                        AxLED
                                        • E Offline
                                          Eisblume
                                          Thank you so much for your help. But It still doesn’t work.
                                          The cabeling is correct I checked it many times ;-)
                                          The crazy thing is, when I remove ground, the press button works, but not the cw and cww.
                                          I think, I will try a clean reinstall on my RPi3.
                                          • E Offline
                                            Eisblume
                                            @AxLed
                                            Also after clean install with nothing more, the default modules and MMM-Navigate and MMM-Remote-Controll it doesn’t work.
                                            Here you can see: https://youtu.be/G2eRoPxRPjU
                                            Only when I remove ground, the press action works. But then, the cw and cww doesn’t work…
