    disable NO signal message
    22 Posts 9 Posters 25.0k Views 8 Watching
      bibi @strawberry 3.141
      @strawberry-3.141 i am not using it yet but will def. check that :) thx
      can i have also your opinion regarding my 1st query pls?
      strawberry 3.141S L 2 Replies Last reply Reply Quote 0
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @bibi
        @bibi my monitor shows also no signal
        • L
          lolobyte @bibi
          @bibi
          You cam manage boot options in raspi-config if you don’t have install jessi light.
          execute following command.
          sudo raspi-config
          chose menu point
          3 Boot Options
          3B Splash Screen
          and activate it wit “YES”
          save and reboot with
          sudo reboot
          Next topic:
          My screen show me a message with no signal for approx. 5 sec.
          After that, the screen is complete black and off.
            bibi @lolobyte
            @lolobyte many thx for this how to! :))
              Deniz @broberg
              @broberg thx for the reply.
              Are you satisfied with the monitor you are using?
              Could you tell me the model number?
              • L
                lolobyte @Deniz
                @Deniz
                Hi, the screen i used, is a old monitor from a Lenovo G670 and one from a Pacard Bell PEW96
                I use for each one a controller from eBay to to use them with the raspi.
                HDMI+DVI+VGA+Audio LCD Controller Kit for 15.6" B156XW02 V.2 LED Panel 1366x768
                HDMI+DVI+VGA+Audio Controller Board Driver Kit for LTN156AT05 LTN156AT02
                • Y
                  yawns Moderator @lolobyte
                  @lolobyte
                  Are you happy with these 3rd party video controllers? I intend to buy one for my screen as well
                  • L
                    lolobyte @yawns
                    @yawns
                    They work and do whats the must.
                    You can adjust the volume, brightness, contrast and so on.
                    The raspi recognize the right resolution and the depth of your mirror is very small.
                    A result you have a very thin MagicMirror. Approx. the thickness of a raspi.
                    • A
                      aboulezz
                      I faced the same problem with my LG screen but found a work around.
                      Step 1) I used wiringpi.com and modified the simple blink example to send out just one impulse:
                      #include
                      int main (void)
                      wiringPiSetup () ;
                      pinMode (0, OUTPUT) ;
                      digitalWrite (0, HIGH) ; delay (200) ;
                      digitalWrite (0, LOW) ;
                      return 0 ;
                      Step 2) I modified the PIR modules’ node_helper.js so within the functions activate / deactivate don’t enable/disable the HDMI output but execute my compiled ‘blink’ command.
                      Step 3) I hard - wired the singal pin to the (with resistor / transistor) to the screens power-button.
                      done :-)
                        Desertswing
                        Is there new info about this situation…?
                        Really want to use my 47’ Philips tv (older version)
                        Hope someone replies!
                          bhepler Module Developer @Desertswing
                          @desertswing What I do with my mirror is that I power the monitor and the pi with a switch. So when I’m done, I just flip the power off and the monitor & Pi snap to black.
                          On boot, the Pi is usually up & booting before the monitor is done with its splash screen. The latest version of Magic Mirror includes a splash screen that replaces the Pi’s boot messages. It’s definitely slick.
                            Desertswing @bhepler
                            @bhepler , But when i want to keep my raspberry always online i have to do something about this situation, it is possible to put new firmware on the TV but i can`t find any modding software thats easier then Hexa codes to configure…
                            with an LG tv its possible because u can get the firmware software download on a USB drive from the TV, but i want to use a tv that i don`t use anymore.(Recycle project).
                              Desertswing @aboulezz
                              @aboulezz said in disable NO signal message:
                              #include
                              int main (void)
                              wiringPiSetup () ;
                              return 0 ;
                              done :-)
                              Can`t i use this instead and make my raspberry a longer time to get the HDMI port visible to the TV, ore do i get the message still when giving the HDMI port a command to show himself. (If u know what i mean).
