    MMM-NOAA
    68 Posts 15 Posters 58.4k Views 13 Watching
    • cowboysdudeC
      cowboysdude Module Developer @kbostick88
      @kbostick88 This is what you need :)
           module: 'MMM-NOAA',
      apiKey: "YOUR API KEY",
      airKey: "YOUR API KEY",
      pws1: "KNYELMIR13",
      Don’t need the loco1 ;)
      HrierebH 1 Reply Last reply Reply Quote 1
      • K
        kbostick88
        Thanks! I also wrote postition, instead of position. I got it working now. Thanks, module looks great!
        • T
          tadeus1975 @kbostick88
          @kbostick88
          Hello, I am a beginner in all this and I am trying to install the same module but the documentation is very poor.
          Could you help me with a step-by-step guide?
          I got the module installed by entering the following commands
          cd MagicMirror / modules
          git clone https://github.com/cowboysdude/MMM-NOAA.git
          What’s next after this?
          I’m not sure if I have correctly executed this
          cd MMM-NOAA
          npm install.
          when I open config.js I can not see any of this.
          module: ‘MMM-NOAA’,
          postition: ‘top_left’,
          		apiKey: "4cc3880807c6aaa9",    // https://www.wunderground.com/weather/api  select the middle plan...
          		airKey: "orBbd9wjdyTK6yp5R",    // IF you want Air Quality Index
          		pws1: "KMIWESTL11" ,
                                  loco1: "Detroit/Us",
          Thank you for your help
          idoodlerI cowboysdudeC 2 Replies Last reply Reply Quote 0
          • idoodlerI
            idoodler Module Developer @tadeus1975
            @tadeus1975 You need to add this module in your config.js file. It is located in the config folder in your MagicMirrors root folder. Just add the JSON Object and replace the keys with your keys.
            • T
              tadeus1975 @idoodler
              @idoodler said in MMM-NOAA:
              JSON Object
              Thank you for your help @idoodler , I am an absolute beginner, after the installation I have this folder in modules, I know how to modify the file config.js, but you could tell me how to add the JSON Object, or where I find its syntax.0_1527506312996_20180528_130609.jpg
              Thank you
              idoodlerI 2 Replies Last reply Reply Quote 0
              • HrierebH
                Hriereb @cowboysdude
                @cowboysdude
                How to change the default language?
                I’ve seen a translation folder with some .json files so I created an it.json file to enable the italian translation. After that I added some lined to the MMM-NOAA.js file but it doesn’t work. Where’s my mistake? Thanks.
                /* Magic Mirror
                 * Module: MMM-NOAA
                 * By cowboysdude and tbbear
                        modified by barnosch
                var c = 0;
                var l = 1;
                var loco = "";
                "use strict";
                Module.register("MMM-NOAA", {
                    // Module config defaults.
                    defaults: {
                        updateInterval: 70 * 60 * 1000, // every 10 minutes
                        animationSpeed: 0,
                        initialLoadDelay: 8000,
                        rotateInterval: 20 * 1000,
                        maxWidth: "100%",
                        apiKey: "",
                        airKey: "",
                	loco1: "xxx",
                	loco2: "xxx",
                	loco3: "xxx",
                	pws: "XXX",
                	pws1: "xxx",
                	pws2: "xxx",
                	pws3: "xxx",
                	   langFile: {
                            "en": "en-US",
                            "de": "de-DE",
                            "sv": "sv-SE",
                            "es": "es-ES",
                            "fr": "fr-FR",
                            "zh_cn": "zh-CN",
                            "da": "da",
                            "nl": "nl-NL",
                            "nb": "nb-NO",
                            "it": "it-IT"
                        langTrans: {
                            "en": "EN",
                            "de": "DL",
                            "sv": "SW",
                            "es": "SP",
                            "fr": "FR",
                            "zh_cn": "CN",
                            "da": "DK",
                            "nl": "NL",
                            "nb": "NO",
                            "it": "IT",
                	levelTrans: {
                        "1":"green",
                		"2":"yellow",
                		"3":"orange",
                		"4":"red",
                    getTranslations: function() {
                        return {
                            en: "translations/en.json",
                            da: "translations/da.json",
                            sv: "translations/sv.json",
                            de: "translations/de.json",
                            es: "translations/es.json",
                            fr: "translations/fr.json",
                            zh_cn: "translations/zh_cn.json",
                            nl: "translations/nl.json",
                            nb: "translations/nb.json",
                            it: "translations/it.json",
                /* Magic Mirror Config Sample
                 * MIT Licensed.
                var config = {
                	port: 8080,
                	language: "it",
                	timeFormat: 24,
                	units: "metric",
                			module: "alert",
                                        module: 'MMM-NOAA',
                                        position : "top_right",
                                        language: "it",
                                                apiKey: "xxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
                	                        airKey: "xxxxxxx"    // IF you want Air Quality Index
                HrierebH Mykle1M 2 Replies Last reply Reply Quote 0
                • cowboysdudeC
                  cowboysdude Module Developer @tadeus1975
                  @tadeus1975 Please read the readme file ;)
                  There is no longer any PWS just enter your apiKey and airKey…that’s all.
                  • idoodlerI
                    @tadeus1975 Please check out the Readme. You need to add this object to to /home/pi/MagicMirror/config/config.js
                    • idoodlerI
                      @tadeus1975 I assume you have never added any module, you can post your config if this is the case and I may be able to send you the correct config.js
                      • HrierebH
                        Hriereb
                        Any suggestion about changing the default language and using the Italian?
                        idoodlerI 1 Reply Last reply Reply Quote 0
                        • idoodlerI
                          idoodler Module Developer @Hriereb
                          @hriereb As far I see Italian is not supported. You can contribute by adding the italian translation for MMM-NOAA.
                          • HrierebH
                            Hriereb @Hriereb
                            JS@hriereb said in MMM-NOAA:
                            @cowboysdude
                            /* Magic Mirror
                             * Module: MMM-NOAA
                            var c = 0;
                            var l = 1;
                            var loco = "";
                            "use strict";
                                defaults: {
                                    animationSpeed: 0,
                                    maxWidth: "100%",
                                    apiKey: "",
                                    airKey: "",
                            	loco1: "xxx",
                            	loco2: "xxx",
                            	loco3: "xxx",
                            	pws: "XXX",
                            	pws1: "xxx",
                            	pws2: "xxx",
                            	pws3: "xxx",
                            	   langFile: {
                                        "en": "en-US",
                                        "de": "de-DE",
                                        "sv": "sv-SE",
                                        "es": "es-ES",
                                        "fr": "fr-FR",
                                        "zh_cn": "zh-CN",
                                        "da": "da",
                                        "nl": "nl-NL",
                                        "nb": "nb-NO",
                                        "it": "it-IT"
                                    langTrans: {
                                        "en": "EN",
                                        "de": "DL",
                                        "sv": "SW",
                                        "es": "SP",
                                        "fr": "FR",
                                        "zh_cn": "CN",
                                        "da": "DK",
                                        "nl": "NL",
                                        "nb": "NO",
                                        "it": "IT",
                            	levelTrans: {
                                    "1":"green",
                            		"2":"yellow",
                            		"3":"orange",
                            		"4":"red",
                                    return {
                             * MIT Licensed.
                            var config = {
                            	port: 8080,
                            	language: "it",
                            	timeFormat: 24,
                            	units: "metric",
                            			module: "alert",
                                                    module: 'MMM-NOAA',
                                                    language: "it",
                            As I posted before I made an it.json file and put it in the translation folder. I’ve tried to update the MMM-NOAA.js
                            but it doesn’t seem to work. Can you help me finding my mistake?
                            • idoodlerI
                              @hriereb May you please also post your it.json
                              HrierebH 1 Reply Last reply Reply Quote 0
                              • HrierebH
                                Hriereb @idoodler
                                @idoodler
                                “Atmospheric Conditions” : “Condizioni Atmosferiche”,
                                “Sunrise/Sunset”:“Alba/Tramonto”,
                                “AQI/UV/Wind”:“AQI/UV/Vento”,
                                “4 Day Forecast”:"Previsioni su quattro giorni ",
                                “Monday”: “Lunedì”,
                                “Tuesday”: “Martedì”,
                                “Wednesday”: "Mercoledì ",
                                “Thursday”: “Giovedì”,
                                “Friday”: “Venerdì”,
                                “Saturday”: “Sabato”,
                                “Sunday”: “Domenica”,
                                “Hours of Light”:“Ore di luce”,
                                “Last Updated”: “Ultimo aggiornamento”,
                                “Today”:“Oggi”,
                                “Mon”:“Lun”,
                                “Tue”:“Mar”,
                                “Wed”:“Mer”,
                                “Thu”:“Giov”,
                                “Fri”:“Ven”,
                                “Sat”:“Sab”,
                                “Sun”:“Dom”,
                                “Forecast”:“Previsioni”,
                                “Weather warning”:“Allerta meteo”,
                                “Night”: “Notte”
                                • idoodlerI
                                  @hriereb This is an invalide JSON, please replace “ with ".
                                  • HrierebH
                                    Hriereb @idoodler
                                    @idoodler
                                    Sorry,
                                    I’m an absolute beginner, what do I have to replace?
                                    • idoodlerI
                                      @hriereb As I already mentioned previously (but only halve correct) replace the characters “ (Left Double Quotation Mark) and ” (Right Double Quotation Mark) with " (Quotation Mark).
                                      NOTE: The characters you used are slightly tilted (italic).
                                        "Atmospheric Conditions" : "Condizioni Atmosferiche",
                                        "Sunrise/Sunset":"Alba/Tramonto",
                                        "AQI/UV/Wind":"AQI/UV/Vento",
                                        "4 Day Forecast":"Previsioni su quattro giorni ",
                                        "Monday": "Lunedì",
                                        "Tuesday": "Martedì",
                                        "Wednesday": "Mercoledì ",
                                        "Thursday": "Giovedì",
                                        "Friday": "Venerdì",
                                        "Saturday": "Sabato",
                                        "Sunday": "Domenica",
                                        "Hours of Light":"Ore di luce",
                                        "Last Updated": "Ultimo aggiornamento",
                                        "Today":"Oggi",
                                        "Mon":"Lun",
                                        "Tue":"Mar",
                                        "Wed":"Mer",
                                        "Thu":"Giov",
                                        "Fri":"Ven",
                                        "Sat":"Sab",
                                        "Sun":"Dom",
                                        "Forecast":"Previsioni",
                                        "Weather warning":"Allerta meteo",
                                        "Night": "Notte"
                                      • HrierebH
                                        Hriereb @idoodler
                                        @idoodler
                                        Ah ok, my tablet wrote a wrong character but I have the right version in my translation folder. What’s wrong with that?
                                        • idoodlerI
                                          @hriereb You may try to lint your JSON then -> https://jsonlint.com/
                                          • HrierebH
                                            Hriereb
                                            it returns me a valid json…
                                            • 1 / 4
