    MMM-NOAA
    68 Posts 15 Posters 55.8k Views 13 Watching
    • HrierebH Offline
      Hriereb @cowboysdude
      @cowboysdude
      How to change the default language?
      I’ve seen a translation folder with some .json files so I created an it.json file to enable the italian translation. After that I added some lined to the MMM-NOAA.js file but it doesn’t work. Where’s my mistake? Thanks.
      /* Magic Mirror
       * Module: MMM-NOAA
       * By cowboysdude and tbbear
              modified by barnosch
      var c = 0;
      var l = 1;
      var loco = "";
      "use strict";
      Module.register("MMM-NOAA", {
          // Module config defaults.
          defaults: {
              updateInterval: 70 * 60 * 1000, // every 10 minutes
              animationSpeed: 0,
              initialLoadDelay: 8000,
              rotateInterval: 20 * 1000,
              maxWidth: "100%",
              apiKey: "",
              airKey: "",
      	loco1: "xxx",
      	loco2: "xxx",
      	loco3: "xxx",
      	pws: "XXX",
      	pws1: "xxx",
      	pws2: "xxx",
      	pws3: "xxx",
      	   langFile: {
                  "en": "en-US",
                  "de": "de-DE",
                  "sv": "sv-SE",
                  "es": "es-ES",
                  "fr": "fr-FR",
                  "zh_cn": "zh-CN",
                  "da": "da",
                  "nl": "nl-NL",
                  "nb": "nb-NO",
                  "it": "it-IT"
              langTrans: {
                  "en": "EN",
                  "de": "DL",
                  "sv": "SW",
                  "es": "SP",
                  "fr": "FR",
                  "zh_cn": "CN",
                  "da": "DK",
                  "nl": "NL",
                  "nb": "NO",
                  "it": "IT",
      	levelTrans: {
              "1":"green",
      		"2":"yellow",
      		"3":"orange",
      		"4":"red",
          getTranslations: function() {
              return {
                  en: "translations/en.json",
                  da: "translations/da.json",
                  sv: "translations/sv.json",
                  de: "translations/de.json",
                  es: "translations/es.json",
                  fr: "translations/fr.json",
                  zh_cn: "translations/zh_cn.json",
                  nl: "translations/nl.json",
                  nb: "translations/nb.json",
                  it: "translations/it.json",
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "it",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
                              module: 'MMM-NOAA',
                              position : "top_right",
                              language: "it",
                                      apiKey: "xxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
      	                        airKey: "xxxxxxx"    // IF you want Air Quality Index
      HrierebH Mykle1M 2 Replies Last reply Reply Quote 0
      • cowboysdudeC Offline
        cowboysdude Module Developer @tadeus1975
        @tadeus1975 Please read the readme file ;)
        There is no longer any PWS just enter your apiKey and airKey…that’s all.
        • idoodlerI Offline
          idoodler Module Developer @tadeus1975
          @tadeus1975 Please check out the Readme. You need to add this object to to /home/pi/MagicMirror/config/config.js
          • idoodlerI Offline
            @tadeus1975 I assume you have never added any module, you can post your config if this is the case and I may be able to send you the correct config.js
            • HrierebH Offline
              Hriereb
              Any suggestion about changing the default language and using the Italian?
              idoodlerI 1 Reply Last reply Reply Quote 0
              • idoodlerI Offline
                idoodler Module Developer @Hriereb
                @hriereb As far I see Italian is not supported. You can contribute by adding the italian translation for MMM-NOAA.
                • HrierebH Offline
                  Hriereb @Hriereb
                  JS@hriereb said in MMM-NOAA:
                  @cowboysdude
                  /* Magic Mirror
                   * Module: MMM-NOAA
                  var c = 0;
                  var l = 1;
                  var loco = "";
                  "use strict";
                      defaults: {
                          animationSpeed: 0,
                          maxWidth: "100%",
                          apiKey: "",
                          airKey: "",
                  	loco1: "xxx",
                  	loco2: "xxx",
                  	loco3: "xxx",
                  	pws: "XXX",
                  	pws1: "xxx",
                  	pws2: "xxx",
                  	pws3: "xxx",
                  	   langFile: {
                              "en": "en-US",
                              "de": "de-DE",
                              "sv": "sv-SE",
                              "es": "es-ES",
                              "fr": "fr-FR",
                              "zh_cn": "zh-CN",
                              "da": "da",
                              "nl": "nl-NL",
                              "nb": "nb-NO",
                              "it": "it-IT"
                          langTrans: {
                              "en": "EN",
                              "de": "DL",
                              "sv": "SW",
                              "es": "SP",
                              "fr": "FR",
                              "zh_cn": "CN",
                              "da": "DK",
                              "nl": "NL",
                              "nb": "NO",
                              "it": "IT",
                  	levelTrans: {
                          "1":"green",
                  		"2":"yellow",
                  		"3":"orange",
                  		"4":"red",
                          return {
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: "it",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                                          module: 'MMM-NOAA',
                                          language: "it",
                  As I posted before I made an it.json file and put it in the translation folder. I’ve tried to update the MMM-NOAA.js
                  but it doesn’t seem to work. Can you help me finding my mistake?
                  • idoodlerI Offline
                    @hriereb May you please also post your it.json
                    HrierebH 1 Reply Last reply Reply Quote 0
                    • HrierebH Offline
                      Hriereb @idoodler
                      @idoodler
                      “Atmospheric Conditions” : “Condizioni Atmosferiche”,
                      “Sunrise/Sunset”:“Alba/Tramonto”,
                      “AQI/UV/Wind”:“AQI/UV/Vento”,
                      “4 Day Forecast”:"Previsioni su quattro giorni ",
                      “Monday”: “Lunedì”,
                      “Tuesday”: “Martedì”,
                      “Wednesday”: "Mercoledì ",
                      “Thursday”: “Giovedì”,
                      “Friday”: “Venerdì”,
                      “Saturday”: “Sabato”,
                      “Sunday”: “Domenica”,
                      “Hours of Light”:“Ore di luce”,
                      “Last Updated”: “Ultimo aggiornamento”,
                      “Today”:“Oggi”,
                      “Mon”:“Lun”,
                      “Tue”:“Mar”,
                      “Wed”:“Mer”,
                      “Thu”:“Giov”,
                      “Fri”:“Ven”,
                      “Sat”:“Sab”,
                      “Sun”:“Dom”,
                      “Forecast”:“Previsioni”,
                      “Weather warning”:“Allerta meteo”,
                      “Night”: “Notte”
                      • idoodlerI Offline
                        @hriereb This is an invalide JSON, please replace “ with ".
                        • HrierebH Offline
                          Hriereb @idoodler
                          @idoodler
                          Sorry,
                          I’m an absolute beginner, what do I have to replace?
                          • idoodlerI Offline
                            @hriereb As I already mentioned previously (but only halve correct) replace the characters “ (Left Double Quotation Mark) and ” (Right Double Quotation Mark) with " (Quotation Mark).
                            NOTE: The characters you used are slightly tilted (italic).
                              "Atmospheric Conditions" : "Condizioni Atmosferiche",
                              "Sunrise/Sunset":"Alba/Tramonto",
                              "AQI/UV/Wind":"AQI/UV/Vento",
                              "4 Day Forecast":"Previsioni su quattro giorni ",
                              "Monday": "Lunedì",
                              "Tuesday": "Martedì",
                              "Wednesday": "Mercoledì ",
                              "Thursday": "Giovedì",
                              "Friday": "Venerdì",
                              "Saturday": "Sabato",
                              "Sunday": "Domenica",
                              "Hours of Light":"Ore di luce",
                              "Last Updated": "Ultimo aggiornamento",
                              "Today":"Oggi",
                              "Mon":"Lun",
                              "Tue":"Mar",
                              "Wed":"Mer",
                              "Thu":"Giov",
                              "Fri":"Ven",
                              "Sat":"Sab",
                              "Sun":"Dom",
                              "Forecast":"Previsioni",
                              "Weather warning":"Allerta meteo",
                              "Night": "Notte"
                            • HrierebH Offline
                              Hriereb @idoodler
                              @idoodler
                              Ah ok, my tablet wrote a wrong character but I have the right version in my translation folder. What’s wrong with that?
                              • idoodlerI Offline
                                @hriereb You may try to lint your JSON then -> https://jsonlint.com/
                                • HrierebH Offline
                                  Hriereb
                                  it returns me a valid json…
                                  • idoodlerI Offline
                                    @hriereb Well, thats odd then. I assume you did restart your MagicMirror after adding itallian, right?
                                    • HrierebH Offline
                                      Hriereb
                                      How do I restart the mirror? Do I have to do a sudo reboot?
                                      • idoodlerI Offline
                                        @hriereb If you are using pm2 you can just enter pm2 restart MagicMirror, a reboot will do the same, but takes longer.
                                        • HrierebH Offline
                                          Hriereb
                                          It works now, thank you so much mate. You’ve been so kind. May I ask you another thing? Everything seems now nicely translated except for the scrolling line under the icon, is there a way to translate it? Where can I find it? Thx again.
                                          • idoodlerI Offline
                                            @hriereb I am afraid, but I have no clue, what you mean. You can send me a screenshot, or mark what you mean on the example images on Github and post them here.
                                            • 1 / 4
