    MMM-NOAA
    68 Posts 15 Posters 58.4k Views 13 Watching
    • idoodlerI
      idoodler Module Developer @tadeus1975
      @tadeus1975 You need to add this module in your config.js file. It is located in the config folder in your MagicMirrors root folder. Just add the JSON Object and replace the keys with your keys.
      • T
        tadeus1975 @idoodler
        @idoodler said in MMM-NOAA:
        JSON Object
        Thank you for your help @idoodler , I am an absolute beginner, after the installation I have this folder in modules, I know how to modify the file config.js, but you could tell me how to add the JSON Object, or where I find its syntax.0_1527506312996_20180528_130609.jpg
        Thank you
        idoodlerI 2 Replies Last reply Reply Quote 0
        • HrierebH
          Hriereb @cowboysdude
          @cowboysdude
          How to change the default language?
          I’ve seen a translation folder with some .json files so I created an it.json file to enable the italian translation. After that I added some lined to the MMM-NOAA.js file but it doesn’t work. Where’s my mistake? Thanks.
          /* Magic Mirror
           * Module: MMM-NOAA
           * By cowboysdude and tbbear
                  modified by barnosch
          var c = 0;
          var l = 1;
          var loco = "";
          "use strict";
          Module.register("MMM-NOAA", {
              // Module config defaults.
              defaults: {
                  updateInterval: 70 * 60 * 1000, // every 10 minutes
                  animationSpeed: 0,
                  initialLoadDelay: 8000,
                  rotateInterval: 20 * 1000,
                  maxWidth: "100%",
                  apiKey: "",
                  airKey: "",
          	loco1: "xxx",
          	loco2: "xxx",
          	loco3: "xxx",
          	pws: "XXX",
          	pws1: "xxx",
          	pws2: "xxx",
          	pws3: "xxx",
          	   langFile: {
                      "en": "en-US",
                      "de": "de-DE",
                      "sv": "sv-SE",
                      "es": "es-ES",
                      "fr": "fr-FR",
                      "zh_cn": "zh-CN",
                      "da": "da",
                      "nl": "nl-NL",
                      "nb": "nb-NO",
                      "it": "it-IT"
                  langTrans: {
                      "en": "EN",
                      "de": "DL",
                      "sv": "SW",
                      "es": "SP",
                      "fr": "FR",
                      "zh_cn": "CN",
                      "da": "DK",
                      "nl": "NL",
                      "nb": "NO",
                      "it": "IT",
          	levelTrans: {
                  "1":"green",
          		"2":"yellow",
          		"3":"orange",
          		"4":"red",
              getTranslations: function() {
                  return {
                      en: "translations/en.json",
                      da: "translations/da.json",
                      sv: "translations/sv.json",
                      de: "translations/de.json",
                      es: "translations/es.json",
                      fr: "translations/fr.json",
                      zh_cn: "translations/zh_cn.json",
                      nl: "translations/nl.json",
                      nb: "translations/nb.json",
                      it: "translations/it.json",
          /* Magic Mirror Config Sample
           * MIT Licensed.
          var config = {
          	port: 8080,
          	language: "it",
          	timeFormat: 24,
          	units: "metric",
          			module: "alert",
                                  module: 'MMM-NOAA',
                                  position : "top_right",
                                  language: "it",
                                          apiKey: "xxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
          	                        airKey: "xxxxxxx"    // IF you want Air Quality Index
          HrierebH Mykle1M 2 Replies Last reply Reply Quote 0
          • cowboysdudeC
            cowboysdude Module Developer @tadeus1975
            @tadeus1975 Please read the readme file ;)
            There is no longer any PWS just enter your apiKey and airKey…that’s all.
            • idoodlerI
              @tadeus1975 Please check out the Readme. You need to add this object to to /home/pi/MagicMirror/config/config.js
              • idoodlerI
                @tadeus1975 I assume you have never added any module, you can post your config if this is the case and I may be able to send you the correct config.js
                • HrierebH
                  Hriereb
                  Any suggestion about changing the default language and using the Italian?
                  idoodlerI 1 Reply Last reply Reply Quote 0
                  • idoodlerI
                    idoodler Module Developer @Hriereb
                    @hriereb As far I see Italian is not supported. You can contribute by adding the italian translation for MMM-NOAA.
                    • HrierebH
                      Hriereb @Hriereb
                      JS@hriereb said in MMM-NOAA:
                      @cowboysdude
                      /* Magic Mirror
                       * Module: MMM-NOAA
                      var c = 0;
                      var l = 1;
                      var loco = "";
                      "use strict";
                          defaults: {
                              animationSpeed: 0,
                              maxWidth: "100%",
                              apiKey: "",
                              airKey: "",
                      	loco1: "xxx",
                      	loco2: "xxx",
                      	loco3: "xxx",
                      	pws: "XXX",
                      	pws1: "xxx",
                      	pws2: "xxx",
                      	pws3: "xxx",
                      	   langFile: {
                                  "en": "en-US",
                                  "de": "de-DE",
                                  "sv": "sv-SE",
                                  "es": "es-ES",
                                  "fr": "fr-FR",
                                  "zh_cn": "zh-CN",
                                  "da": "da",
                                  "nl": "nl-NL",
                                  "nb": "nb-NO",
                                  "it": "it-IT"
                              langTrans: {
                                  "en": "EN",
                                  "de": "DL",
                                  "sv": "SW",
                                  "es": "SP",
                                  "fr": "FR",
                                  "zh_cn": "CN",
                                  "da": "DK",
                                  "nl": "NL",
                                  "nb": "NO",
                                  "it": "IT",
                      	levelTrans: {
                              "1":"green",
                      		"2":"yellow",
                      		"3":"orange",
                      		"4":"red",
                              return {
                       * MIT Licensed.
                      var config = {
                      	port: 8080,
                      	language: "it",
                      	timeFormat: 24,
                      	units: "metric",
                      			module: "alert",
                                              module: 'MMM-NOAA',
                                              language: "it",
                      As I posted before I made an it.json file and put it in the translation folder. I’ve tried to update the MMM-NOAA.js
                      but it doesn’t seem to work. Can you help me finding my mistake?
                      • idoodlerI
                        @hriereb May you please also post your it.json
                        HrierebH 1 Reply Last reply Reply Quote 0
                        • HrierebH
                          Hriereb @idoodler
                          @idoodler
                          “Atmospheric Conditions” : “Condizioni Atmosferiche”,
                          “Sunrise/Sunset”:“Alba/Tramonto”,
                          “AQI/UV/Wind”:“AQI/UV/Vento”,
                          “4 Day Forecast”:"Previsioni su quattro giorni ",
                          “Monday”: “Lunedì”,
                          “Tuesday”: “Martedì”,
                          “Wednesday”: "Mercoledì ",
                          “Thursday”: “Giovedì”,
                          “Friday”: “Venerdì”,
                          “Saturday”: “Sabato”,
                          “Sunday”: “Domenica”,
                          “Hours of Light”:“Ore di luce”,
                          “Last Updated”: “Ultimo aggiornamento”,
                          “Today”:“Oggi”,
                          “Mon”:“Lun”,
                          “Tue”:“Mar”,
                          “Wed”:“Mer”,
                          “Thu”:“Giov”,
                          “Fri”:“Ven”,
                          “Sat”:“Sab”,
                          “Sun”:“Dom”,
                          “Forecast”:“Previsioni”,
                          “Weather warning”:“Allerta meteo”,
                          “Night”: “Notte”
                          • idoodlerI
                            @hriereb This is an invalide JSON, please replace “ with ".
                            • HrierebH
                              Hriereb @idoodler
                              @idoodler
                              Sorry,
                              I’m an absolute beginner, what do I have to replace?
                              • idoodlerI
                                @hriereb As I already mentioned previously (but only halve correct) replace the characters “ (Left Double Quotation Mark) and ” (Right Double Quotation Mark) with " (Quotation Mark).
                                NOTE: The characters you used are slightly tilted (italic).
                                  "Atmospheric Conditions" : "Condizioni Atmosferiche",
                                  "Sunrise/Sunset":"Alba/Tramonto",
                                  "AQI/UV/Wind":"AQI/UV/Vento",
                                  "4 Day Forecast":"Previsioni su quattro giorni ",
                                  "Monday": "Lunedì",
                                  "Tuesday": "Martedì",
                                  "Wednesday": "Mercoledì ",
                                  "Thursday": "Giovedì",
                                  "Friday": "Venerdì",
                                  "Saturday": "Sabato",
                                  "Sunday": "Domenica",
                                  "Hours of Light":"Ore di luce",
                                  "Last Updated": "Ultimo aggiornamento",
                                  "Today":"Oggi",
                                  "Mon":"Lun",
                                  "Tue":"Mar",
                                  "Wed":"Mer",
                                  "Thu":"Giov",
                                  "Fri":"Ven",
                                  "Sat":"Sab",
                                  "Sun":"Dom",
                                  "Forecast":"Previsioni",
                                  "Weather warning":"Allerta meteo",
                                  "Night": "Notte"
                                • HrierebH
                                  Hriereb @idoodler
                                  @idoodler
                                  Ah ok, my tablet wrote a wrong character but I have the right version in my translation folder. What’s wrong with that?
                                  • idoodlerI
                                    @hriereb You may try to lint your JSON then -> https://jsonlint.com/
                                    • HrierebH
                                      Hriereb
                                      it returns me a valid json…
                                      • idoodlerI
                                        @hriereb Well, thats odd then. I assume you did restart your MagicMirror after adding itallian, right?
                                        • HrierebH
                                          Hriereb
                                          How do I restart the mirror? Do I have to do a sudo reboot?
                                          • idoodlerI
                                            @hriereb If you are using pm2 you can just enter pm2 restart MagicMirror, a reboot will do the same, but takes longer.
                                            • 1 / 4
