    MMM-NOAA
    68 Posts 15 Posters 48.6k Views 13 Watching
    • K Offline
      kbostick88
      Hey everyone, I am kind of new to this, but think i get the basics
      I got the module installed by entering the following commands
      cd MagicMirror/modules
      git clone https://github.com/cowboysdude/MMM-NOAA.git
      cd MMM-NOAA
      npm install
      I then did the config as follows
      Yet when it loads I dont see anything on my mirror
      		module: 'MMM-NOAA',
      		postition: 'top_left',
      			apiKey: "4cc3880807c6aaa9",    // https://www.wunderground.com/weather/api  select the middle plan...
      			airKey: "orBbd9wjdyTK6yp5R",    // IF you want Air Quality Index
      			pws1: "KMIWESTL11" ,
                                  loco1: "Detroit/Us",
      cowboysdudeC T 2 Replies Last reply Reply Quote 0
      • cowboysdudeC Offline
        cowboysdude Module Developer @kbostick88
        @kbostick88 This is what you need :)
             module: 'MMM-NOAA',
        apiKey: "YOUR API KEY",
        airKey: "YOUR API KEY",
        pws1: "KNYELMIR13",
        Don’t need the loco1 ;)
        HrierebH 1 Reply Last reply Reply Quote 1
        • K Offline
          kbostick88
          Thanks! I also wrote postition, instead of position. I got it working now. Thanks, module looks great!
          • T Offline
            tadeus1975 @kbostick88
            @kbostick88
            Hello, I am a beginner in all this and I am trying to install the same module but the documentation is very poor.
            Could you help me with a step-by-step guide?
            cd MagicMirror / modules
            What’s next after this?
            I’m not sure if I have correctly executed this
            cd MMM-NOAA
            npm install.
            when I open config.js I can not see any of this.
            module: ‘MMM-NOAA’,
            postition: ‘top_left’,
            Thank you for your help
            idoodlerI cowboysdudeC 2 Replies Last reply Reply Quote 0
            • idoodlerI Offline
              idoodler Module Developer @tadeus1975
              @tadeus1975 You need to add this module in your config.js file. It is located in the config folder in your MagicMirrors root folder. Just add the JSON Object and replace the keys with your keys.
              • T Offline
                tadeus1975 @idoodler
                @idoodler said in MMM-NOAA:
                JSON Object
                Thank you for your help @idoodler , I am an absolute beginner, after the installation I have this folder in modules, I know how to modify the file config.js, but you could tell me how to add the JSON Object, or where I find its syntax.0_1527506312996_20180528_130609.jpg
                Thank you
                idoodlerI 2 Replies Last reply Reply Quote 0
                • HrierebH Offline
                  Hriereb @cowboysdude
                  @cowboysdude
                  How to change the default language?
                  I’ve seen a translation folder with some .json files so I created an it.json file to enable the italian translation. After that I added some lined to the MMM-NOAA.js file but it doesn’t work. Where’s my mistake? Thanks.
                  /* Magic Mirror
                   * Module: MMM-NOAA
                   * By cowboysdude and tbbear
                          modified by barnosch
                  var c = 0;
                  var l = 1;
                  var loco = "";
                  "use strict";
                  Module.register("MMM-NOAA", {
                      // Module config defaults.
                      defaults: {
                          updateInterval: 70 * 60 * 1000, // every 10 minutes
                          animationSpeed: 0,
                          initialLoadDelay: 8000,
                          rotateInterval: 20 * 1000,
                          maxWidth: "100%",
                          apiKey: "",
                          airKey: "",
                  	loco1: "xxx",
                  	loco2: "xxx",
                  	loco3: "xxx",
                  	pws: "XXX",
                  	pws1: "xxx",
                  	pws2: "xxx",
                  	pws3: "xxx",
                  	   langFile: {
                              "en": "en-US",
                              "de": "de-DE",
                              "sv": "sv-SE",
                              "es": "es-ES",
                              "fr": "fr-FR",
                              "zh_cn": "zh-CN",
                              "da": "da",
                              "nl": "nl-NL",
                              "nb": "nb-NO",
                              "it": "it-IT"
                          langTrans: {
                              "en": "EN",
                              "de": "DL",
                              "sv": "SW",
                              "es": "SP",
                              "fr": "FR",
                              "zh_cn": "CN",
                              "da": "DK",
                              "nl": "NL",
                              "nb": "NO",
                              "it": "IT",
                  	levelTrans: {
                          "1":"green",
                  		"2":"yellow",
                  		"3":"orange",
                  		"4":"red",
                      getTranslations: function() {
                          return {
                              en: "translations/en.json",
                              da: "translations/da.json",
                              sv: "translations/sv.json",
                              de: "translations/de.json",
                              es: "translations/es.json",
                              fr: "translations/fr.json",
                              zh_cn: "translations/zh_cn.json",
                              nl: "translations/nl.json",
                              nb: "translations/nb.json",
                              it: "translations/it.json",
                  /* Magic Mirror Config Sample
                   * MIT Licensed.
                  var config = {
                  	port: 8080,
                  	language: "it",
                  	timeFormat: 24,
                  	units: "metric",
                  			module: "alert",
                                          module: 'MMM-NOAA',
                                          position : "top_right",
                                          language: "it",
                                                  apiKey: "xxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
                  	                        airKey: "xxxxxxx"    // IF you want Air Quality Index
                  HrierebH Mykle1M 2 Replies Last reply Reply Quote 0
                    cowboysdude Module Developer @tadeus1975
                    @tadeus1975 Please read the readme file ;)
                    There is no longer any PWS just enter your apiKey and airKey…that’s all.
                    • idoodlerI Offline
                      @tadeus1975 Please check out the Readme. You need to add this object to to /home/pi/MagicMirror/config/config.js
                      • idoodlerI Offline
                        @tadeus1975 I assume you have never added any module, you can post your config if this is the case and I may be able to send you the correct config.js
                        • 1 / 7
