    MMM-NOAA
    68 Posts 15 Posters 59.2k Views 13 Watching
    • idoodlerI
      idoodler Module Developer @tadeus1975
      @tadeus1975 Please check out the Readme. You need to add this object to to /home/pi/MagicMirror/config/config.js
      • idoodlerI
        @tadeus1975 I assume you have never added any module, you can post your config if this is the case and I may be able to send you the correct config.js
        • HrierebH
          Hriereb
          Any suggestion about changing the default language and using the Italian?
          idoodlerI 1 Reply Last reply
          • idoodlerI
            idoodler Module Developer @Hriereb
            @hriereb As far I see Italian is not supported. You can contribute by adding the italian translation for MMM-NOAA.
            • HrierebH
              Hriereb @Hriereb
              JS@hriereb said in MMM-NOAA:
              @cowboysdude
              How to change the default language?
              I’ve seen a translation folder with some .json files so I created an it.json file to enable the italian translation. After that I added some lined to the MMM-NOAA.js file but it doesn’t work. Where’s my mistake? Thanks.
              /* Magic Mirror
               * Module: MMM-NOAA
               * By cowboysdude and tbbear
                      modified by barnosch
              var c = 0;
              var l = 1;
              var loco = "";
              "use strict";
              Module.register("MMM-NOAA", {
                  // Module config defaults.
                  defaults: {
                      updateInterval: 70 * 60 * 1000, // every 10 minutes
                      animationSpeed: 0,
                      initialLoadDelay: 8000,
                      rotateInterval: 20 * 1000,
                      maxWidth: "100%",
                      apiKey: "",
                      airKey: "",
              	loco1: "xxx",
              	loco2: "xxx",
              	loco3: "xxx",
              	pws: "XXX",
              	pws1: "xxx",
              	pws2: "xxx",
              	pws3: "xxx",
              	   langFile: {
                          "en": "en-US",
                          "de": "de-DE",
                          "sv": "sv-SE",
                          "es": "es-ES",
                          "fr": "fr-FR",
                          "zh_cn": "zh-CN",
                          "da": "da",
                          "nl": "nl-NL",
                          "nb": "nb-NO",
                          "it": "it-IT"
                      langTrans: {
                          "en": "EN",
                          "de": "DL",
                          "sv": "SW",
                          "es": "SP",
                          "fr": "FR",
                          "zh_cn": "CN",
                          "da": "DK",
                          "nl": "NL",
                          "nb": "NO",
                          "it": "IT",
              	levelTrans: {
                      "1":"green",
              		"2":"yellow",
              		"3":"orange",
              		"4":"red",
                  getTranslations: function() {
                      return {
                          en: "translations/en.json",
                          da: "translations/da.json",
                          sv: "translations/sv.json",
                          de: "translations/de.json",
                          es: "translations/es.json",
                          fr: "translations/fr.json",
                          zh_cn: "translations/zh_cn.json",
                          nl: "translations/nl.json",
                          nb: "translations/nb.json",
                          it: "translations/it.json",
              /* Magic Mirror Config Sample
               * MIT Licensed.
              var config = {
              	port: 8080,
              	language: "it",
              	timeFormat: 24,
              	units: "metric",
              			module: "alert",
                                      module: 'MMM-NOAA',
                                      position : "top_right",
                                      language: "it",
                                              apiKey: "xxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
              	                        airKey: "xxxxxxx"    // IF you want Air Quality Index
              As I posted before I made an it.json file and put it in the translation folder. I’ve tried to update the MMM-NOAA.js
              but it doesn’t seem to work. Can you help me finding my mistake?
              • idoodlerI
                @hriereb May you please also post your it.json
                HrierebH 1 Reply Last reply
                • HrierebH
                  Hriereb @idoodler
                  @idoodler
                  “Atmospheric Conditions” : “Condizioni Atmosferiche”,
                  “Sunrise/Sunset”:“Alba/Tramonto”,
                  “AQI/UV/Wind”:“AQI/UV/Vento”,
                  “4 Day Forecast”:"Previsioni su quattro giorni ",
                  “Monday”: “Lunedì”,
                  “Tuesday”: “Martedì”,
                  “Wednesday”: "Mercoledì ",
                  “Thursday”: “Giovedì”,
                  “Friday”: “Venerdì”,
                  “Saturday”: “Sabato”,
                  “Sunday”: “Domenica”,
                  “Hours of Light”:“Ore di luce”,
                  “Last Updated”: “Ultimo aggiornamento”,
                  “Today”:“Oggi”,
                  “Mon”:“Lun”,
                  “Tue”:“Mar”,
                  “Wed”:“Mer”,
                  “Thu”:“Giov”,
                  “Fri”:“Ven”,
                  “Sat”:“Sab”,
                  “Sun”:“Dom”,
                  “Forecast”:“Previsioni”,
                  “Weather warning”:“Allerta meteo”,
                  “Night”: “Notte”
                  • idoodlerI
                    @hriereb This is an invalide JSON, please replace “ with ".
                    • HrierebH
                      Hriereb @idoodler
                      @idoodler
                      Sorry,
                      I’m an absolute beginner, what do I have to replace?
                      • idoodlerI
                        @hriereb As I already mentioned previously (but only halve correct) replace the characters “ (Left Double Quotation Mark) and ” (Right Double Quotation Mark) with " (Quotation Mark).
                        NOTE: The characters you used are slightly tilted (italic).
                          "Atmospheric Conditions" : "Condizioni Atmosferiche",
                          "Sunrise/Sunset":"Alba/Tramonto",
                          "AQI/UV/Wind":"AQI/UV/Vento",
                          "4 Day Forecast":"Previsioni su quattro giorni ",
                          "Monday": "Lunedì",
                          "Tuesday": "Martedì",
                          "Wednesday": "Mercoledì ",
                          "Thursday": "Giovedì",
                          "Friday": "Venerdì",
                          "Saturday": "Sabato",
                          "Sunday": "Domenica",
                          "Hours of Light":"Ore di luce",
                          "Last Updated": "Ultimo aggiornamento",
                          "Today":"Oggi",
                          "Mon":"Lun",
                          "Tue":"Mar",
                          "Wed":"Mer",
                          "Thu":"Giov",
                          "Fri":"Ven",
                          "Sat":"Sab",
                          "Sun":"Dom",
                          "Forecast":"Previsioni",
                          "Weather warning":"Allerta meteo",
                          "Night": "Notte"
                        • HrierebH
                          Hriereb @idoodler
                          @idoodler
                          Ah ok, my tablet wrote a wrong character but I have the right version in my translation folder. What’s wrong with that?
                          • idoodlerI
                            @hriereb You may try to lint your JSON then -> https://jsonlint.com/
                            • HrierebH
                              Hriereb
                              it returns me a valid json…
                              • idoodlerI
                                @hriereb Well, thats odd then. I assume you did restart your MagicMirror after adding itallian, right?
                                • HrierebH
                                  Hriereb
                                  How do I restart the mirror? Do I have to do a sudo reboot?
                                  • idoodlerI
                                    @hriereb If you are using pm2 you can just enter pm2 restart MagicMirror, a reboot will do the same, but takes longer.
                                    • HrierebH
                                      Hriereb
                                      It works now, thank you so much mate. You’ve been so kind. May I ask you another thing? Everything seems now nicely translated except for the scrolling line under the icon, is there a way to translate it? Where can I find it? Thx again.
                                      • idoodlerI
                                        @hriereb I am afraid, but I have no clue, what you mean. You can send me a screenshot, or mark what you mean on the example images on Github and post them here.
                                        • HrierebH
                                          Hriereb
                                          I mean above the weather icon I still see overcast clouds and under the field “previsione” there’s the same scrolling phrase.
                                          idoodlerI 2 Replies Last reply
                                          • idoodlerI
                                            @hriereb Oh, I guess, this is the weather description from the Weather API. The developer behind MMM-NOAA is currently reworking the module. You may contact him and request a full translatable config.
                                            • 1 / 4
