    MMM-NOAA
    68 Posts 15 Posters 57.1k Views 13 Watching
    • idoodlerI Offline
      idoodler Module Developer @Hriereb
      @hriereb As I already mentioned previously (but only halve correct) replace the characters “ (Left Double Quotation Mark) and ” (Right Double Quotation Mark) with " (Quotation Mark).
      NOTE: The characters you used are slightly tilted (italic).
        "Atmospheric Conditions" : "Condizioni Atmosferiche",
        "Sunrise/Sunset":"Alba/Tramonto",
        "AQI/UV/Wind":"AQI/UV/Vento",
        "4 Day Forecast":"Previsioni su quattro giorni ",
        "Monday": "Lunedì",
        "Tuesday": "Martedì",
        "Wednesday": "Mercoledì ",
        "Thursday": "Giovedì",
        "Friday": "Venerdì",
        "Saturday": "Sabato",
        "Sunday": "Domenica",
        "Hours of Light":"Ore di luce",
        "Last Updated": "Ultimo aggiornamento",
        "Today":"Oggi",
        "Mon":"Lun",
        "Tue":"Mar",
        "Wed":"Mer",
        "Thu":"Giov",
        "Fri":"Ven",
        "Sat":"Sab",
        "Sun":"Dom",
        "Forecast":"Previsioni",
        "Weather warning":"Allerta meteo",
        "Night": "Notte"
      HrierebH 1 Reply Last reply Reply Quote 0
      • HrierebH Offline
        Hriereb @idoodler
        @idoodler
        Ah ok, my tablet wrote a wrong character but I have the right version in my translation folder. What’s wrong with that?
        idoodlerI 1 Reply Last reply Reply Quote 0
        • idoodlerI Offline
          @hriereb You may try to lint your JSON then -> https://jsonlint.com/
          • HrierebH Offline
            Hriereb
            it returns me a valid json…
            • idoodlerI Offline
              @hriereb Well, thats odd then. I assume you did restart your MagicMirror after adding itallian, right?
              • HrierebH Offline
                Hriereb
                How do I restart the mirror? Do I have to do a sudo reboot?
                • idoodlerI Offline
                  @hriereb If you are using pm2 you can just enter pm2 restart MagicMirror, a reboot will do the same, but takes longer.
                  • HrierebH Offline
                    Hriereb
                    It works now, thank you so much mate. You’ve been so kind. May I ask you another thing? Everything seems now nicely translated except for the scrolling line under the icon, is there a way to translate it? Where can I find it? Thx again.
                    • idoodlerI Offline
                      @hriereb I am afraid, but I have no clue, what you mean. You can send me a screenshot, or mark what you mean on the example images on Github and post them here.
                      • HrierebH Offline
                        Hriereb
                        I mean above the weather icon I still see overcast clouds and under the field “previsione” there’s the same scrolling phrase.
                        idoodlerI 2 Replies Last reply Reply Quote 0
                        • idoodlerI Offline
                          @hriereb Oh, I guess, this is the weather description from the Weather API. The developer behind MMM-NOAA is currently reworking the module. You may contact him and request a full translatable config.
                          • HrierebH Offline
                            Hriereb
                            Ok, thanks again mate. I really appreciated your help.
                            • idoodlerI Offline
                              @hriereb Btw. I would love to see an upvote on the post that helped you the most:)
                                Mykle1 Project Sponsor Module Developer @Hriereb
                                @hriereb said in MMM-NOAA:
                                I added some lined to the MMM-NOAA.js
                                In the future, it might be best to ask for help before you start editing the module files. This is not recommended and makes it more difficult to determine the cause of your issue
                                  core
                                  Hi everyone,
                                  I have problems with regard to the latest version of this module.
                                  I updated to the new version, including the updated weather service provider and since then, two of my other modules (MMM-Fuel and MMM-Sonos) are not working any more. The position (bottom_left) is just blank now, wheras the MMM-NOAA (position: top_right) module works. Even a re-install of MMM-NOAA and reboot of my Rpi3 did not fix this issue.
                                  When I delete the module from my config, all other modules are working again, so I can clearly assign the problem to the MMM-NOAA module.
                                  Until now, I don´ t use this module and all modules are working smoothly. However, I like this module so hopefully, the problems will be fixed soon. Any news about it?
                                  Thanks!
                                  idoodlerI cowboysdudeC 2 Replies Last reply Reply Quote 0
                                  • idoodlerI Offline
                                    idoodler Module Developer @core
                                    @core Please provide any log. Execute pm2 log MagicMirror (if you are using pm2), reproduce the issue and post the log here.
                                    When posting the log it is recommended to add it in a code block for better readability.
                                    :clinking_beer_mugs:
                                    • cowboysdudeC Offline
                                      cowboysdude Module Developer @core
                                      @core run your mirror like this ‘npm start dev’ and tell me what errors you are getting.
                                      Apparently there is a conflict on your mirror so lets see what it is and fix it :)
                                      @idoodler Thanks for the help!!! :) I’m so busy this time of year I’m not on here much.
                                      I’d like a copy of the Italian language file if someone wants to do a pull request on github and upload it that would be great! Thank you
                                      • WayneRigleyW Offline
                                        WayneRigley
                                        @cowboysdude Glad to say i have the NOAA Installed and working perfect will say better than any other weather module ive installed as the temps are perfect. my ONLY issue is the module does not seem to be auto-sizing to its position. as you can see its overlaying on top of the bottom bar… anyone have any thoughts or what i should start to attack first . ! Picture would not load so here is a link https://photos.app.goo.gl/VNkNaXwfMWWxyemN7
                                        Wayne R
                                          core
                                          hi,
                                          thanks for the help. I ran npm start dev and here is the log:
                                          1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
                                          2 info using npm@3.10.10
                                          3 info using node@v6.12.3
                                          4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
                                          5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                          5 verbose stack at Error (native)
                                          6 verbose cwd /home/pi
                                          7 error Linux 4.9.53-v7+
                                          8 error argv “/usr/bin/node” “/usr/bin/npm” “start” “dev”
                                          9 error node v6.12.3
                                          10 error npm v3.10.10
                                          11 error path /home/pi/package.json
                                          12 error code ENOENT
                                          13 error errno -2
                                          14 error syscall open
                                          15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                          16 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                          16 error enoent This is most likely not a problem with npm itself
                                          16 error enoent and is related to npm not being able to find a file.
                                          17 verbose exit [ -2, true ]
                                          anz ideas?
                                          • idoodlerI Offline
                                            @core Did you just execute npm start dev in your Raspberry Pi’s home directory?
                                            Follow the steps to successfully execute the command:
                                            • Stop any instance of MagicMirror (pm2 stop MagicMirror if you use pm2)
                                            • cd MagicMirror -> You need to go into the MagicMirror directory
                                            • Start MagicMirror with Dev Tools
                                              • If you are connected via SSH: DISPLAY=:0 nohup npm start dev &
                                              • If you are directly on your Raspberry Pi: npm start dev
                                            • 2 / 4
