    MMM-NOAA
    68 Posts 15 Posters 58.8k Views 13 Watching
    • HrierebH
      Hriereb
      it returns me a valid json…
      idoodlerI 1 Reply Last reply
      • idoodlerI
        idoodler Module Developer @Hriereb
        @hriereb Well, thats odd then. I assume you did restart your MagicMirror after adding itallian, right?
        • HrierebH
          Hriereb
          How do I restart the mirror? Do I have to do a sudo reboot?
          • idoodlerI
            @hriereb If you are using pm2 you can just enter pm2 restart MagicMirror, a reboot will do the same, but takes longer.
            • HrierebH
              Hriereb
              It works now, thank you so much mate. You’ve been so kind. May I ask you another thing? Everything seems now nicely translated except for the scrolling line under the icon, is there a way to translate it? Where can I find it? Thx again.
              • idoodlerI
                @hriereb I am afraid, but I have no clue, what you mean. You can send me a screenshot, or mark what you mean on the example images on Github and post them here.
                • HrierebH
                  Hriereb
                  I mean above the weather icon I still see overcast clouds and under the field “previsione” there’s the same scrolling phrase.
                  idoodlerI 2 Replies Last reply
                  • idoodlerI
                    @hriereb Oh, I guess, this is the weather description from the Weather API. The developer behind MMM-NOAA is currently reworking the module. You may contact him and request a full translatable config.
                    • HrierebH
                      Hriereb
                      Ok, thanks again mate. I really appreciated your help.
                      • idoodlerI
                        @hriereb Btw. I would love to see an upvote on the post that helped you the most:)
                        • Mykle1M
                          Mykle1 Project Sponsor Module Developer @Hriereb
                          @hriereb said in MMM-NOAA:
                          I added some lined to the MMM-NOAA.js
                          In the future, it might be best to ask for help before you start editing the module files. This is not recommended and makes it more difficult to determine the cause of your issue
                            core
                            Hi everyone,
                            I have problems with regard to the latest version of this module.
                            I updated to the new version, including the updated weather service provider and since then, two of my other modules (MMM-Fuel and MMM-Sonos) are not working any more. The position (bottom_left) is just blank now, wheras the MMM-NOAA (position: top_right) module works. Even a re-install of MMM-NOAA and reboot of my Rpi3 did not fix this issue.
                            When I delete the module from my config, all other modules are working again, so I can clearly assign the problem to the MMM-NOAA module.
                            Until now, I don´ t use this module and all modules are working smoothly. However, I like this module so hopefully, the problems will be fixed soon. Any news about it?
                            Thanks!
                            idoodlerI cowboysdudeC 2 Replies Last reply
                            • idoodlerI
                              idoodler Module Developer @core
                              @core Please provide any log. Execute pm2 log MagicMirror (if you are using pm2), reproduce the issue and post the log here.
                              When posting the log it is recommended to add it in a code block for better readability.
                              :clinking_beer_mugs:
                              • cowboysdudeC
                                cowboysdude Module Developer @core
                                @core run your mirror like this ‘npm start dev’ and tell me what errors you are getting.
                                Apparently there is a conflict on your mirror so lets see what it is and fix it :)
                                @idoodler Thanks for the help!!! :) I’m so busy this time of year I’m not on here much.
                                I’d like a copy of the Italian language file if someone wants to do a pull request on github and upload it that would be great! Thank you
                                • WayneRigleyW
                                  WayneRigley
                                  @cowboysdude Glad to say i have the NOAA Installed and working perfect will say better than any other weather module ive installed as the temps are perfect. my ONLY issue is the module does not seem to be auto-sizing to its position. as you can see its overlaying on top of the bottom bar… anyone have any thoughts or what i should start to attack first . ! Picture would not load so here is a link https://photos.app.goo.gl/VNkNaXwfMWWxyemN7
                                  Wayne R
                                    core
                                    hi,
                                    thanks for the help. I ran npm start dev and here is the log:
                                    1 verbose cli [ ‘/usr/bin/node’, ‘/usr/bin/npm’, ‘start’, ‘dev’ ]
                                    2 info using npm@3.10.10
                                    3 info using node@v6.12.3
                                    4 verbose config Skipping project config: /home/pi/.npmrc. (matches userconfig)
                                    5 verbose stack Error: ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                    5 verbose stack at Error (native)
                                    6 verbose cwd /home/pi
                                    7 error Linux 4.9.53-v7+
                                    8 error argv “/usr/bin/node” “/usr/bin/npm” “start” “dev”
                                    9 error node v6.12.3
                                    10 error npm v3.10.10
                                    11 error path /home/pi/package.json
                                    12 error code ENOENT
                                    13 error errno -2
                                    14 error syscall open
                                    15 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                    16 error enoent ENOENT: no such file or directory, open ‘/home/pi/package.json’
                                    16 error enoent This is most likely not a problem with npm itself
                                    16 error enoent and is related to npm not being able to find a file.
                                    17 verbose exit [ -2, true ]
                                    anz ideas?
                                    • idoodlerI
                                      @core Did you just execute npm start dev in your Raspberry Pi’s home directory?
                                      Follow the steps to successfully execute the command:
                                      • Stop any instance of MagicMirror (pm2 stop MagicMirror if you use pm2)
                                      • cd MagicMirror -> You need to go into the MagicMirror directory
                                      • Start MagicMirror with Dev Tools
                                        • If you are connected via SSH: DISPLAY=:0 nohup npm start dev &
                                        • If you are directly on your Raspberry Pi: npm start dev
                                        core
                                        first, thanks again for helping!
                                        here is the log after executing npm start dev in cd MagicMirror
                                        Starting MagicMirror: v2.1.3
                                        Loading config …
                                        Loading module helpers …
                                        No helper found for module: calendar_monthly.
                                        Module helper loaded: MMM-temp-ds18b20
                                        Module helper loaded: MMM-NOAA
                                        Module helper loaded: MMM-Sonos
                                        Module helper loaded: MMM-Fuel
                                        Module helper loaded: MMM-SystemStats
                                        All module helpers loaded.
                                        Starting server on port 8080 …
                                        Server started …
                                        Connecting socket for: MMM-temp-ds18b20
                                        Connecting socket for: MMM-NOAA
                                        Starting module: MMM-NOAA
                                        Connecting socket for: MMM-Sonos
                                        Sonos helper started …
                                        Connecting socket for: MMM-Fuel
                                        Starting module helper: MMM-Fuel
                                        Connecting socket for: MMM-SystemStats
                                        Starting module: newsfeed
                                        Sockets connected & modules started …
                                        Launching application.
                                        SONOS_UPDATE
                                        Create new news fetcher for url: http://rss.kicker.de/news/aktuell - Interval: 300000
                                        Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                                        SONOS_UPDATE
                                        And here is my config file for MMM-NOAA:
                                        		disabled: false,
                                        		module: 'MMM-NOAA',
                                        			position: 'top_right',
                                        			config:
                                        			apiKey: "xxx",
                                        			useAir: true,
                                        			airKey: "xxx",
                                        			pws: "ISCHIFFE4",
                                        			showClock: false,
                                        			dformat: false,
                                        			format: "24",
                                        			ampm: true,
                                        			showGreet: false,
                                        			name: "",                  // Your name
                                        			showWind: true,
                                        			showDate: false,
                                        			showForecast: true,         //show bottom 3 day forecast
                                        			flash: true                 //Today in forecast flashes halo
                                        With this config of the Module, the following modules are shown on screen and running:
                                        MMM-NOAA
                                        Calendar_monthly
                                        MMM-temp-ds
                                        clock
                                        When I delete MMM-NOAA from the config, the following modules are shown on screen and running:
                                        Calendar_monthly
                                        clock
                                        MMM-temp-ds
                                        newsfeed
                                        MMM-Fuel
                                        MMM-Sonos
                                        MMM-SystemStats
                                        Thanks again for help!!
                                          core
                                          ok in addition I ran pm2 logs mm with regard to the issue.
                                          Here is the log:
                                          pi@magicpi:~ $ pm2 logs mm
                                          [TAILING] Tailing last 15 lines for [mm] process (change the value with --lines option)
                                          /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
                                          0|mm | at ClientRequest.emit (events.js:191:7)
                                          0|mm | at Socket.socketErrorListener (_http_client.js:358:9)
                                          0|mm | at emitOne (events.js:96:13)
                                          0|mm | TypeError: Cannot read property ‘statusCode’ of undefined
                                          0|mm | at Request.request [as _callback] (/home/pi/MagicMirror/modules/MMM-Fuel/apis/tankerkoenig.js:115:29)
                                          0|mm | at self.callback (/home/pi/MagicMirror/modules/MMM-Fuel/node_modules/request/request.js:186:22)
                                          0|mm | at Request.emit (events.js:191:7)
                                          0|mm | at Request.onRequestError (/home/pi/MagicMirror/modules/MMM-Fuel/node_modules/request/request.js:878:8)
                                          0|mm | at TLSSocket.socketErrorListener (_http_client.js:358:9)
                                          0|mm | at TLSSocket.emit (events.js:191:7)
                                          0|mm | Failure: null
                                          /home/pi/.pm2/logs/mm-out-0.log last 15 lines:
                                          0|mm | Sonos helper started …
                                          0|mm | Connecting socket for: MMM-Fuel
                                          0|mm | Starting module helper: MMM-Fuel
                                          0|mm | Connecting socket for: MMM-SystemStats
                                          0|mm | Connecting socket for: newsfeed
                                          0|mm | Starting module: newsfeed
                                          0|mm | Sockets connected & modules started …
                                          0|mm | Launching application.
                                          0|mm | SONOS_UPDATE
                                          0|mm | Create new news fetcher for url: http://rss.kicker.de/news/aktuell - Interval: 300000
                                          0|mm | Create new news fetcher for url: http://www.n-tv.de/rss - Interval: 300000
                                          0|mm |
                                          0|mm | > magicmirror@2.1.3 start /home/pi/MagicMirror
                                          0|mm | > sh run-start.sh
                                          0|mm |
                                          • idoodlerI
                                            • 2 / 4
