    MMM-NOAA
    68 Posts 15 Posters 59.3k Views 13 Watching
    • HrierebH
      Hriereb @Hriereb
      JS@hriereb said in MMM-NOAA:
      @cowboysdude
      How to change the default language?
      I’ve seen a translation folder with some .json files so I created an it.json file to enable the italian translation. After that I added some lined to the MMM-NOAA.js file but it doesn’t work. Where’s my mistake? Thanks.
      /* Magic Mirror
       * Module: MMM-NOAA
       * By cowboysdude and tbbear
              modified by barnosch
      var c = 0;
      var l = 1;
      var loco = "";
      "use strict";
      Module.register("MMM-NOAA", {
          // Module config defaults.
          defaults: {
              updateInterval: 70 * 60 * 1000, // every 10 minutes
              animationSpeed: 0,
              initialLoadDelay: 8000,
              rotateInterval: 20 * 1000,
              maxWidth: "100%",
              apiKey: "",
              airKey: "",
      	loco1: "xxx",
      	loco2: "xxx",
      	loco3: "xxx",
      	pws: "XXX",
      	pws1: "xxx",
      	pws2: "xxx",
      	pws3: "xxx",
      	   langFile: {
                  "en": "en-US",
                  "de": "de-DE",
                  "sv": "sv-SE",
                  "es": "es-ES",
                  "fr": "fr-FR",
                  "zh_cn": "zh-CN",
                  "da": "da",
                  "nl": "nl-NL",
                  "nb": "nb-NO",
                  "it": "it-IT"
              langTrans: {
                  "en": "EN",
                  "de": "DL",
                  "sv": "SW",
                  "es": "SP",
                  "fr": "FR",
                  "zh_cn": "CN",
                  "da": "DK",
                  "nl": "NL",
                  "nb": "NO",
                  "it": "IT",
      	levelTrans: {
              "1":"green",
      		"2":"yellow",
      		"3":"orange",
      		"4":"red",
          getTranslations: function() {
              return {
                  en: "translations/en.json",
                  da: "translations/da.json",
                  sv: "translations/sv.json",
                  de: "translations/de.json",
                  es: "translations/es.json",
                  fr: "translations/fr.json",
                  zh_cn: "translations/zh_cn.json",
                  nl: "translations/nl.json",
                  nb: "translations/nb.json",
                  it: "translations/it.json",
      /* Magic Mirror Config Sample
       * MIT Licensed.
      var config = {
      	port: 8080,
      	language: "it",
      	timeFormat: 24,
      	units: "metric",
      			module: "alert",
                              module: 'MMM-NOAA',
                              position : "top_right",
                              language: "it",
                                      apiKey: "xxxxxx",    // https://www.wunderground.com/weather/api  select the middle plan...
      	                        airKey: "xxxxxxx"    // IF you want Air Quality Index
      As I posted before I made an it.json file and put it in the translation folder. I’ve tried to update the MMM-NOAA.js
      but it doesn’t seem to work. Can you help me finding my mistake?
      idoodlerI 1 Reply Last reply
      • idoodlerI
        idoodler Module Developer @Hriereb
        @hriereb May you please also post your it.json
        HrierebH 1 Reply Last reply
        • HrierebH
          Hriereb @idoodler
          @idoodler
          “Atmospheric Conditions” : “Condizioni Atmosferiche”,
          “Sunrise/Sunset”:“Alba/Tramonto”,
          “AQI/UV/Wind”:“AQI/UV/Vento”,
          “4 Day Forecast”:"Previsioni su quattro giorni ",
          “Monday”: “Lunedì”,
          “Tuesday”: “Martedì”,
          “Wednesday”: "Mercoledì ",
          “Thursday”: “Giovedì”,
          “Friday”: “Venerdì”,
          “Saturday”: “Sabato”,
          “Sunday”: “Domenica”,
          “Hours of Light”:“Ore di luce”,
          “Last Updated”: “Ultimo aggiornamento”,
          “Today”:“Oggi”,
          “Mon”:“Lun”,
          “Tue”:“Mar”,
          “Wed”:“Mer”,
          “Thu”:“Giov”,
          “Fri”:“Ven”,
          “Sat”:“Sab”,
          “Sun”:“Dom”,
          “Forecast”:“Previsioni”,
          “Weather warning”:“Allerta meteo”,
          “Night”: “Notte”
          • idoodlerI
            @hriereb This is an invalide JSON, please replace “ with ".
            • HrierebH
              Hriereb @idoodler
              @idoodler
              Sorry,
              I’m an absolute beginner, what do I have to replace?
              • idoodlerI
                @hriereb As I already mentioned previously (but only halve correct) replace the characters “ (Left Double Quotation Mark) and ” (Right Double Quotation Mark) with " (Quotation Mark).
                NOTE: The characters you used are slightly tilted (italic).
                  "Atmospheric Conditions" : "Condizioni Atmosferiche",
                  "Sunrise/Sunset":"Alba/Tramonto",
                  "AQI/UV/Wind":"AQI/UV/Vento",
                  "4 Day Forecast":"Previsioni su quattro giorni ",
                  "Monday": "Lunedì",
                  "Tuesday": "Martedì",
                  "Wednesday": "Mercoledì ",
                  "Thursday": "Giovedì",
                  "Friday": "Venerdì",
                  "Saturday": "Sabato",
                  "Sunday": "Domenica",
                  "Hours of Light":"Ore di luce",
                  "Last Updated": "Ultimo aggiornamento",
                  "Today":"Oggi",
                  "Mon":"Lun",
                  "Tue":"Mar",
                  "Wed":"Mer",
                  "Thu":"Giov",
                  "Fri":"Ven",
                  "Sat":"Sab",
                  "Sun":"Dom",
                  "Forecast":"Previsioni",
                  "Weather warning":"Allerta meteo",
                  "Night": "Notte"
                • HrierebH
                  Hriereb @idoodler
                  @idoodler
                  Ah ok, my tablet wrote a wrong character but I have the right version in my translation folder. What’s wrong with that?
                  • idoodlerI
                    @hriereb You may try to lint your JSON then -> https://jsonlint.com/
                    • HrierebH
                      Hriereb
                      it returns me a valid json…
                      • idoodlerI
                        @hriereb Well, thats odd then. I assume you did restart your MagicMirror after adding itallian, right?
                        • HrierebH
                          Hriereb
                          How do I restart the mirror? Do I have to do a sudo reboot?
                          • idoodlerI
                            @hriereb If you are using pm2 you can just enter pm2 restart MagicMirror, a reboot will do the same, but takes longer.
                            • HrierebH
                              Hriereb
                              It works now, thank you so much mate. You’ve been so kind. May I ask you another thing? Everything seems now nicely translated except for the scrolling line under the icon, is there a way to translate it? Where can I find it? Thx again.
                              • idoodlerI
                                @hriereb I am afraid, but I have no clue, what you mean. You can send me a screenshot, or mark what you mean on the example images on Github and post them here.
                                • HrierebH
                                  Hriereb
                                  I mean above the weather icon I still see overcast clouds and under the field “previsione” there’s the same scrolling phrase.
                                  idoodlerI 2 Replies Last reply
                                  • idoodlerI
                                    @hriereb Oh, I guess, this is the weather description from the Weather API. The developer behind MMM-NOAA is currently reworking the module. You may contact him and request a full translatable config.
                                    • HrierebH
                                      Hriereb
                                      Ok, thanks again mate. I really appreciated your help.
                                      • idoodlerI
                                        @hriereb Btw. I would love to see an upvote on the post that helped you the most:)
                                        • Mykle1M
                                          Mykle1 Project Sponsor Module Developer @Hriereb
                                          In the future, it might be best to ask for help before you start editing the module files. This is not recommended and makes it more difficult to determine the cause of your issue
                                            core
                                            Hi everyone,
                                            I have problems with regard to the latest version of this module.
                                            I updated to the new version, including the updated weather service provider and since then, two of my other modules (MMM-Fuel and MMM-Sonos) are not working any more. The position (bottom_left) is just blank now, wheras the MMM-NOAA (position: top_right) module works. Even a re-install of MMM-NOAA and reboot of my Rpi3 did not fix this issue.
                                            When I delete the module from my config, all other modules are working again, so I can clearly assign the problem to the MMM-NOAA module.
                                            Until now, I don´ t use this module and all modules are working smoothly. However, I like this module so hopefully, the problems will be fixed soon. Any news about it?
                                            Thanks!
                                            idoodlerI cowboysdudeC 2 Replies Last reply
                                            • 2 / 4
