    Motion Detector
    213 Posts 38 Posters 584.2k Views 39 Watching
    • cowboysdudeC
      cowboysdude Module Developer @plumcraft
      @plumcraft Yeah there doesn’t seem to be an answer for the blank screen issue…
      • A
        alexyak
        I am sorry to hear about your issues. Trying to think of the best way to troubleshoot that. The module doesn’t do anything fancy. It just executes these in the node_helper to switch on/of the output on HDMI:
        Switch off:
        /opt/vc/bin/tvservice -o
        Switch-on:
        /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
        As a first step, could you please try to execute these commands in the ssh terminal?
        • T
          trividar
          Hi alexyak
          I try it with the commands an it works, it switch off and on.
          • A
            alexyak
            Ok, the next step let’s check whether the off state is detected correctly. After you switched off the monitor with the first command try to execute this in the ssh term:
            /opt/vc/bin/tvservice -s
            and let me know which output you see.
            • T
              trividar
              output is:
              state 0x120002 [TV is off]
              • strawberry 3.141S
                strawberry 3.141 Project Sponsor Module Developer @trividar
                @trividar @cowboysdude paviro is also using the same code lines in his pir sensor module and a user had similar issues, maybe his solution also work for you
                https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/43
                https://forum.magicmirror.builders/topic/208/pir-sensor-put-your-mirror-to-sleep-if-not-used/64
                • cowboysdudeC
                  Thanks everyone I will look into this later today!
                  • T
                    trividar
                    @strawberry-3-141 unfortunately it didn’t work for me;0( but thanks for your input.
                    • strawberry 3.141S
                      @trividar I thought the commands are working for you, as you pointed out 2 hours ago? I was struggling with this myself for a seperate module, it didn’t work in the terminal i had to login at tty6 or with the solution I posted I got weird colors and a zoom effect on my screen, but in the node_helper it worked at least for me.
                      • T
                        trividar
                        @strawberry-3-141 This two things work for me if i put it in the terminal:
                        Switch off:
                        Switch-on:
                        But not the module. I tried to change node_helper, but if I tried to start pm2 start mm.sh i got just a white screen. Sorry I’m not a coder, I just start to learn.
                        • strawberry 3.141S
                          @trividar can you post your pm2 logs
                          • T
                            trividar
                            I will… I will be in one hour at home and I will post it.
                            • T
                              trividar
                              my logs without any changes:
                              If I put in the therminal:
                              my monitor turn on and my mirror work…
                              • A
                                alexyak
                                Was your monitor on when you were starting the magic mirror?
                                • cowboysdudeC
                                  cowboysdude Module Developer @alexyak
                                  @alexyak Yes these both work via ssh
                                  Switch off:
                                  Switch-on:
                                  When I do this:
                                  I get this:
                                  state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
                                  But when I start the mirror with the normal npm start and it runs until the motion sensor time then the screen goes out and won’t come back on…
                                  A 1 Reply Last reply
                                  • A
                                    alexyak @cowboysdude
                                    @cowboysdude could you please run the magic mirror from the terminal until it switches off and doesn’t switch back on, bring the monitor back with the command and post your screenshot of the terminal?
                                    • cowboysdudeC
                                      @alexyak Do you mean SSH or shell on the mirror?
                                      • A
                                        alexyak
                                        Could you also run the /opt/vc/bin/tvservice -s when your monitor is on?
                                        • cowboysdudeC
                                          @alexyak I did … I posted it above LOL
                                          I get this:
                                          • A
                                            @cowboysdude on the RPI.
                                            • 10
                                            • 11
                                            • 2 / 11
