    Motion Detector
    213 Posts 38 Posters 549.5k Views 39 Watching
    • cowboysdudeC Offline
      Thanks everyone I will look into this later today!
      • T Offline
        trividar
        @strawberry-3-141 unfortunately it didn’t work for me;0( but thanks for your input.
        • strawberry 3.141S Offline
          strawberry 3.141 Project Sponsor Module Developer @trividar
          @trividar I thought the commands are working for you, as you pointed out 2 hours ago? I was struggling with this myself for a seperate module, it didn’t work in the terminal i had to login at tty6 or with the solution I posted I got weird colors and a zoom effect on my screen, but in the node_helper it worked at least for me.
          • T Offline
            trividar
            @strawberry-3-141 This two things work for me if i put it in the terminal:
            Switch off:
            /opt/vc/bin/tvservice -o
            Switch-on:
            /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
            But not the module. I tried to change node_helper, but if I tried to start pm2 start mm.sh i got just a white screen. Sorry I’m not a coder, I just start to learn.
              @trividar can you post your pm2 logs
              • T Offline
                trividar
                I will… I will be in one hour at home and I will post it.
                • T Offline
                  trividar
                  my logs without any changes:
                  If I put in the therminal:
                  my monitor turn on and my mirror work…
                    alexyak
                    Was your monitor on when you were starting the magic mirror?
                      cowboysdude Module Developer @alexyak
                      @alexyak Yes these both work via ssh
                      Switch off:
                      Switch-on:
                      When I do this:
                      /opt/vc/bin/tvservice -s
                      I get this:
                      state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
                      But when I start the mirror with the normal npm start and it runs until the motion sensor time then the screen goes out and won’t come back on…
                        alexyak @cowboysdude
                        @cowboysdude could you please run the magic mirror from the terminal until it switches off and doesn’t switch back on, bring the monitor back with the command and post your screenshot of the terminal?
                          @alexyak Do you mean SSH or shell on the mirror?
                            alexyak
                            Could you also run the /opt/vc/bin/tvservice -s when your monitor is on?
                              @alexyak I did … I posted it above LOL
                              I get this:
                                @cowboysdude on the RPI.
                                  @alexyak /opt/vc/bin/tvservice -s
                                  I get this:
                                  That’s where I was running it from and I still get the above
                                    @cowboysdude so just to confirm, when you run the status command on the RPI you get this output, right?
                                      @alexyak Yes that is correct
                                        Is it logging anywhere that we may be able to see what it’s doing exactly?
                                          alexyak
                                          It’s logging in the terminal window that you use to start the mirror with npm start. You can also start the mirror with “npm start dev” with dev tools and there will be the output from the chromium.
                                            • 10
                                            • 11
                                            • 2 / 11
