    Motion Detector
    213 Posts 38 Posters 569.4k Views 39 Watching
    • T Offline
      trividar
      my logs without any changes:
      If I put in the therminal:
      /opt/vc/bin/tvservice --preferred && sudo chvt 6 && sudo chvt 7
      my monitor turn on and my mirror work…
        alexyak
        Was your monitor on when you were starting the magic mirror?
        • cowboysdudeC Offline
          cowboysdude Module Developer @alexyak
          @alexyak Yes these both work via ssh
          Switch off:
          /opt/vc/bin/tvservice -o
          Switch-on:
          When I do this:
          /opt/vc/bin/tvservice -s
          I get this:
          state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 60.00Hz, progressive
          But when I start the mirror with the normal npm start and it runs until the motion sensor time then the screen goes out and won’t come back on…
            alexyak @cowboysdude
            @cowboysdude could you please run the magic mirror from the terminal until it switches off and doesn’t switch back on, bring the monitor back with the command and post your screenshot of the terminal?
              @alexyak Do you mean SSH or shell on the mirror?
                alexyak
                Could you also run the /opt/vc/bin/tvservice -s when your monitor is on?
                  @alexyak I did … I posted it above LOL
                  I get this:
                    @cowboysdude on the RPI.
                      @alexyak /opt/vc/bin/tvservice -s
                      I get this:
                      That’s where I was running it from and I still get the above
                        @cowboysdude so just to confirm, when you run the status command on the RPI you get this output, right?
                          @alexyak Yes that is correct
                            Is it logging anywhere that we may be able to see what it’s doing exactly?
                              alexyak
                              It’s logging in the terminal window that you use to start the mirror with npm start. You can also start the mirror with “npm start dev” with dev tools and there will be the output from the chromium.
                                  /home/pi$ /opt/vc/bin/tvservice -o
                                  Powering off HDMI
                                  /home/pi$ /opt/vc/bin/tvservice -s
                                  state 0x120002 [TV is off]
                                  That is off
                                  Turns it back on… no problem…this is the tvservice -s when it’s on…
                                  So somewhere it’s broken in the module itself… it does turn it off [even if you’re standing in front of it moving…which means to me it’s not taping into the camera looking for motion] but not back on… I know the camera is working I’ve taken pictures with it…
                                  So what is getting lost after it turns off? And how or where can I look to see what it’s loggin? I can’t look at the terminal window when it’s off because to do that you’d have to turn it back on… and you can’t.
                                  • strawberry 3.141S Offline
                                    strawberry 3.141 Project Sponsor Module Developer @alexyak
                                    @alexyak the logs from @trividar show only state hdmi on never hdmi off, so maybe the check for on off is not correct in the module, as an idea create a dev branch where you don’t check with tvservice -s, just set a variable hdmi true/false after you running a command and starting with true in the start method of the nodehelper and let them checkout this branch
                                    A 1 Reply Last reply Reply Quote 1
                                      alexyak @strawberry 3.141
                                      @strawberry-3.141 I have a feeling that the camera is not properly captured from the client side js code. I am going to create a dev branch with a lot more logging soon.
                                      • T Offline
                                        trividar
                                        Thank you guys for having a look!!
                                          alexyak @trividar
                                          @trividar before I spend some time creating a dev branch, could you please run the magic mirror from the terminal on RPI with the following command line:
                                          npm start dev
                                          The magic mirror will be started with dev tools enabled. Switch to the 'Console" tab in the dev tools and you should be able to see the following output:
                                          “compare result=Infinity,Infinity;0,0” when there’s no movement before your camera and something like “compare result=49,44;31,47” when there’s some movement.
                                          Also if you could also look for errors in this console as well (red colored lines).
                                            For me the I get the compare result=Infinity,Infinity:0,0 but it’s not sensing any movement… so it’s the camera that’s the problem here…
                                            I did get an error its says:
                                            NavigatorUserMediaError {name: "DeviceNotFoundError", message "", constaintName: ""}
                                            That tells me it can’t access the camera…
                                            How does one fix that?
                                            • 10
                                            • 11
                                            • 2 / 11
