    I cant seem to insall 3rd party modules correctly, what am i doing wrong?
    7 Posts 6 Posters 5.1k Views 6 Watching
      Mykle1 Project Sponsor Module Developer @jiggly
      @jiggly said in I cant seem to insall 3rd party modules correctly, what am i doing wrong?:
      Would the clock problem have anything to do with the fact that i keep getting undervoltage warning??
      Sure. The under-voltage issue is likely because of your power supply for the Pi being inadequate. I would get the proper power for your Pi.
      Have you tried adding a module other than the MMM-CoinMarketCap module? If another successfully loads then your problem lies with MMM-CoinMarketCap.
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @jiggly
        @jiggly the picture of your file tree shows that your module folder is called MMM-Coinmarketcap instead of MMM-CoinMarketCap. You should change that otherwise magicmirror can’t find the module
        • idoodlerI Offline
          idoodler Module Developer @jiggly
          @jiggly I have had the same undervoltage issue when trying to access 5V from the monitors power supply, which just supplied to less power. Switching to a 2A 5V power supply solved the issue
            shazglass
            I am NO expert and I could be 100% incorrect, but in your pic of your modules you dont have a return wrapper. you need this }, and you just have this }
              cyberphox
              @strawberry-3-141 said in I cant seem to insall 3rd party modules correctly, what am i doing wrong?:
              This should definitely fix it!
                jiggly
                You guys are amazing! I did two things to get the module to work. I changed the name of the Module to CoinMarketCap instead of Coinmarketcap and also i added a comma at the end of } the wrapper. New to all this raspberry pi and coding so i wanted to say thanks to all of you people!
