Whitescreen after Reboot
7 Posts 3 Posters 4.2k Views 1 Watching
    Bangee Module Developer
    After rebooting my R PI 3 i got a whitescreen and a problem with electron:
    Error log:
    pi@raspberrypi:~/MagicMirror $ tail -f  /home/pi/.pm2/logs/mm-error-0.log
    npm verb cli [ '/usr/local/bin/node', '/usr/local/bin/npm', 'start' ]
    npm info using npm@3.8.3
    npm info using node@v5.10.1
    npm verb run-script [ 'prestart', 'start', 'poststart' ]
    npm info lifecycle magicmirror@2.0.0~prestart: magicmirror@2.0.0
    npm sill lifecycle magicmirror@2.0.0~prestart: no script for prestart, continuing
    npm info lifecycle magicmirror@2.0.0~start: magicmirror@2.0.0
    WARNING! Could not find config. Please create one.
    App threw an error when running [ReferenceError: Log is not defined]
    Note from admin: Please use Markdown for your code/shell snippets so it is easier to read!
      MichMich Admin
      There is something wrong with your installation. Since it can’t find your config file.
      And, somehow you’re using a module that uses the Log.log function in a node_helper. Log.log is only available in the frowned default modules.
      K 1 Reply Last reply May 10, 2016, 5:42 PM Reply Quote 1
        MichMich Admin
        Btw, thats weird. Since it has no config. it should only load the hello world module. Which doesn’t use Log. :-/
          Thx, i got it.
          This module was using the log.log function
          https://github.com/SamLewis0602/MMM-Traffic?files=1
          • K Offline
            KirAsh4 Moderator @MichMich
            @MichMich, uh, een momentje, but what are 'frowned modules' ?
            M 1 Reply Last reply May 10, 2016, 5:47 PM Reply Quote 0
              MichMich Admin @KirAsh4
              @KirAsh4 Lol … those are modules that are modified by my auto correct… ;)
              K 1 Reply Last reply May 10, 2016, 5:50 PM Reply Quote 0
              • K Offline
                @MichMich, oooooh. I was about to start a new topic and demand access to those 'frowned' modules! :)
