    Motion Detector
    213 Posts 38 Posters 569.4k Views 39 Watching
      alexyak @cowboysdude
      @cowboysdude this is what I had suspected. What kind of camera do you have? Web camera over usb?
      • T Offline
        trividar
        I use the pi NoIR camera V1. Sorry for the bad image!
        • strawberry 3.141S Offline
          this sounds that your cam is not getting recognized as a valid webcam
          • cowboysdudeC Offline
            cowboysdude Module Developer @strawberry 3.141
            @strawberry-3.141 said in Motion Detector:
            I am using the NOIR Picamera that’s interesting because outside the module the camera works fine LOL
            Hummmmmmm…
              can you guys try sudo modprobe bcm2835-v4l2 in the console before starting the mirror
              • T Offline
                trividar
                I got this error:
                  strange this is the driver for the camera module
                  do you have enabled the camera module?
                  • T Offline
                    trividar
                    Yes I have… And the camera works, i can take picutres abd see live pictures.
                      then it’s really strange that you can’t find the driver, did you wrote v412 or v4l2 ?
                      looks like you typed 1 but it should be a lowercase L
                      • T Offline
                        trividar
                        • T Offline
                          trividar
                          Now It works… juhuuuuuuuuuuu;o) My monitor turn off… and recognize motion and turns on. In dev Mode i see now also motions!
                            hopefully this works for @cowboysdude as well
                              I just typed in the sudo modprobe bcm2835-v4l2 and it returned nothing so I’m guessing that’s a good thing LOL
                                So this is what I’ve done and it solved it…
                                I took your sudo modprobe bcm2835-v4l2 and entered before I started the mirror and no more error so I started the mirror in dev and it was registering movement…Great!
                                So I closed the mirror and restarted… same error, driver not loaded…
                                so I did this in case of a power out,e tc…in a terminal window:
                                sudo crontab -e
                                Enter this on the last line:
                                @reboot sudo modprobe bcm2835-v4l2
                                Saved and exited.
                                Reboot
                                Restart mirror in dev mode
                                NO error and tracks movement
                                close mirror and restart in dev
                                NO error and tracks movement.
                                PROBLEM SOLVED!! Thank you guys for being patient!! It’s working.
                                • T Offline
                                  trividar
                                  Thank you guys! you are amazing!
                                    sero
                                    Same here, works like a charm!
                                    Thanks guys :)
                                      alexyak
                                      Huge thank you to @strawberry-3-141 for helping to troubleshoot this issue and suggesting the solution! While I know all kinds of dev languages and tools, I am pretty new RPI and Linux.
                                      • T Offline
                                        trividar
                                        Hi guys,
                                        I have a problem. My MM do not turn on the display in the morning. I is possible that my pi camera is in a kind of sleepmode or standby? I have to restart with pm2 stop mm and start again an than it works fine.
                                          cowboysdude Module Developer @trividar
                                          @trividar said in Motion Detector:
                                          Hi guys,
                                          I have encountered that MANY times… don’t exactly know why myself… It’s not just this module it happens with most of them… I believe once it sleeps long enough the PI doesn’t want to wake up LOL
                                            cpramhofer
                                            Hi Guys,
                                            had exactly the same problem with mit Raspi NOIR Cam V2.1.
                                            the sudo modprobe bcm2835-v4l2 command solved my problem.
                                            maybe you should add this Tipp in your Readme as many people out there have the same problem.
                                            greets
                                            Christoph
                                            • 10
                                            • 11
                                            • 3 / 11
