    Two Instances in PM2
    19 Posts 6 Posters 12.5k Views 5 Watching
      Mykle1 Project Sponsor Module Developer @paul.calladine
      @paul.calladine
      pm2 stop mm
      pm2 delete mm
      pm2 save
      rm ~/mm.sh
      Then check your instances again. :-)
      P S 2 Replies Last reply Reply Quote 5
        paul.calladine @Mykle1
        @Mykle1 Worked perfectly, thanks!!
          @paul.calladine
          Cheers, mate! :-)
            AliAS
            Had exactly the same issue. Thought I’d resolved it and then it came back after reboot. Following these instructions worked.
              janth
              Hello:)
              I run it on a Pi ZeroW and I know that’s not the common way. I use PM2 since I could not find any other working solution for Jessie or Stretch. Though it starts MM and chromium and everything looks well, the CPU is at 100 % all the time. When checking the active processes, the “node server only” is listed four times and chromium twice. Each node instance eats up to 20 % of CPU time.
              Any idea how to stop that?
                shazglass @Mykle1
                @mykle1 hi again☺️. Hope u are well. I had this same problem. I ran your suggestions and now I only have MagicMirror and not mm. However. When I pm2 start MagicMirror. It shows it’s “online” yet fails to go onto mirror mode. Please help. I don’t want to start from scratch. Also how do I stop the screen going into sleep mode? Thnx @Mykle1 you have been my MM life support thus far!!!
                  Mykle1 Project Sponsor Module Developer @shazglass
                  @shazglass
                  Hey shaz. I’m well, thanks. How are things down under? :-)
                  Sounds like you might be in node server only mode, perhaps.
                  What happens if you navigate to the MagicMirror folder in your terminal and type npm start? Does the mirror run as expected then?
                  Worst case scenario (I think) is you would have to delete PM2 altogether and re-install using the guide from the MM repo. Unless someone has a better idea. (They usually do) :-)
                  S 2 Replies Last reply Reply Quote 1
                    shazglass @Mykle1
                    @mykle1 hi. So glad to hear you are doing well. Bit chilly here in SA but all good thnx.
                    Ok so I went into the MagicMirror module in terminal as you suggested and ran npm start. It ran a whole bunch of lines then went into Mirror mode. Everything is there. Then to stop it I held control + q to stop. It stops it and puts me back to the terminal I started in. How for demo purposes would I go in and out of the mirror now? How do I get it back to easy access? And what did I do wrong? On install when it asked do u want to use pm2 I said Y. Then is new clean terminal I did pm2 startup. I copied and pasted the line required. I rebooted. Then typed nano mm.sh and added ~/MagicMirror
                    DISPLAY=:0 npm start
                    Saved then typed
                    Chmod +x mm.sh
                    Then typed pm2 save
                    That’s where I get two instances one MagicMirror that won’t respond until ur way
                    And the other is mm which I deleted with your thread instructions.
                    So how do I get easy in and out of mirror mode? Thanx my life saver once again!
                    Also. I can’t disable the screen saver with the new version. How do I stop it now?
                    Thnx. Look forward to hearing from you😉
                      shazglass @Mykle1
                      @mykle1 ok. Don’t worry about screen saver. Sorted that out. But not sure how I did it. LOL!
                        shazglass
                        Hi everyone.
                        Please help. I have two instances of mm starting on boot up. I don’t know what I did wrong. When pi starts the cpu is showing movement but doesn’t boot into mm. I have to type is pi pm2 stop mm. Then pm2 stop MagicMirror to stop the cpu usage. I go into cd MagicMirror and type npm start and my mirror starts. Control q and quits. But this isn’t the right way to do it. How and in what directory do I go into to delete pm2 as I have two instances. Thnx everyone. Appreciate all help.
