    Getting started tutorial
    usage
    10 Posts 6 Posters 7.5k Views 6 Watching
    • ltkortL Offline
      ltkort
      I just bought a Raspberry Pi 3, I have no experience with this device. But I do have some coding experience and i’m always interested in learning new things.
      Is there a tutorial on installing Magic mirror v2? What OS should my pi be running? I tried it and had issues with a full storage… Can someone help me with this?
      • paviroP Offline
        paviro
        For the storage problem (provided its not a hardware problem) execute sudo raspi-config somewhere in the menus is a resize filesystem button or something similar (if you use Raspbian not sure on other systems).
        For the rest have a look at the README.
        – The Doctor
        • MichMichM Offline
          MichMich
          Also check out the MM Wiki on GitHub. It has some usefull tips.
          • 0 Offline
            00conman
            How many gigs do you have on your micro SD because the operating system alone (for the pi) takes about 3.4 gigs?
            ltkortL 1 Reply Last reply Reply Quote 0
            • ltkortL Offline
              ltkort @00conman
              @00conman 32gb ;)
              @paviro @MichMich As soon as i’m home i will try to install everything again, from scratch and post where I’m stuck
              • 0 Offline
                00conman
                try using the automatic installer
                https://github.com/MichMich/MagicMirror/blob/v2-beta/README.md
                I’d also recommend a wipe before you try anything furthermore you should be more that fine with 32 gigs because mine is running on 16 gigs.
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  I have a default Raspbian installation on an 8Gb card, with some of the bloat removed (such as LibreOffice, wolfram-engine, and others). With MM installed, plus some other stuff that I put on, this is the current storage:
                  pi@magicmirror:~ $ df -h
                  Filesystem      Size  Used Avail Use% Mounted on
                  /dev/root       7.2G  3.4G  3.5G  50% /
                  devtmpfs        459M     0  459M   0% /dev
                  tmpfs           463M  5.6M  458M   2% /dev/shm
                  tmpfs           463M  6.8M  457M   2% /run
                  tmpfs           5.0M  4.0K  5.0M   1% /run/lock
                  tmpfs           463M     0  463M   0% /sys/fs/cgroup
                  /dev/mmcblk0p1   60M   20M   41M  34% /boot
                  tmpfs            93M     0   93M   0% /run/user/1000
                    standby30
                    I there anyone that has a detailed MM2 config file That Could give to me ? so I could just fill in with my info. I just can’t figure out JavaScript. thanks in advance
                    • KirAsh4K Offline
                      KirAsh4 Moderator
                      The config.js.sample file that comes with it gives you all the examples you need. If you rename it to config.js and start your mirror, you will see the modules pop up. Use that as your starting point.
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        Taking this topic back to the storage question above, I did a fresh install on another rPi-3 and captured some info. One a stock Raspbian Jessie, running on an 8G card, with all apps updated, nothing removed, once you have MM up and running, you’re looking at the following for storage:
                        Now, since you’re likely to only use this for MM and nothing else, there’s no sense in leaving all of the other apps on it that are pre-installed. So, I removed some of the big ones:
                        wolfram-engine
                        scratch
                        nu-scratch
                        sonic-pi
                        idle3
                        smartsim
                        penguinspuzzle
                        java-common
                        minecraft-pi
                        python-minecraftpi
                        python3-minecraftpi
                        libreoffice*
                        And after running autoremove as well, which cleared even more space removing other unneeded apps, you’re down to this:
                        That’s 1.3G worth of storage that I just cleared up. So unless you need a larger SD card for other stuff, an 8G works just fine. Potentially even a 4G. You’ll still have plenty of room left after you clean up the installation.
                        Another option is to start with Raspbian Jessie-lite on a 4G card, but then you have to install the X server, desktop environment, and a login manager yourself. Assuming you get it all done correctly, you’ll end up with a very light weight installation of the OS, taking up only 53% of storage (remember, 4G card), with MM running lean and clean on top of that. I did try that as well but ran into issues with electron.js and for the time involved, knowing I wasn’t going to run it on there, it wasn’t worth continuing. I will leave that as an exercise to the brave.
