    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 874.0k Views 59 Watching
    • Mykle1M
      Mykle1 Project Sponsor Module Developer @lancerkid38
      @lancerkid38
      You’re quite welcome, my friend. :-)
        djsunrise19 @Mykle1
        @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
        @djsunrise19 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
        I think I’ll create a windows backup and give ubuntu a 3rd chance :-D. Using ubuntu mate shouldn’t be a problem? I like that interface a little bit more
        Personally, I wouldn’t care which version name or number, as long as it’s stable and MM resides there happily.
        Another option for voice would be an alexa skill an module. So I can use alexa for the input trigger.
        Cool. Keep me posted.
        Made it with ubuntu. I didn’t use the java-scripted marquee fx anymore, changed it to CSS3 transitions :) - no problems there. Also the 3rd party option works very well. Now, my realtek soundcard detects my microphone. So I don’t have to use my USB mic (latency is horrible - 4-5seconds!! - with my 3,5mm pawl mic ~0,3seconds). I’m using MMM-voice with your Lucy (slightly modified) ;).
        So thank you very much Mykle1! Any recommendations for a small 3,5mm pawl mic? Actually, I tested it with a headset mic. But it doesn’t recognize me so good, if I’m 0,5m away.
        • Mykle1M
          Excellent. I suspected the drivers were the problem. :-)
          Yes, the whole latency thing was a bother to me. The difference in response time using a USB microphone is horrible, as you found out.
          I purchased this microphone when I was first working on Lucy because it was inexpensive. It works really well in a quiet environment, with a 99% success rate within 50 inches. I haven’t tested it at long distance.
          https://www.amazon.com/gp/product/B07673TQCB/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
          • H
            hrishim
            Thanks for the walkthrough @Mykle1 I did most of the stuff myself but stumbled at the last step - running MM. There is no sh in Windows and I was thinking I need to install Cygwin or something similar. Then stumbled on this post.
            On a different note - could you suggest pointer on how to get started writing modules? Ideally, where does one begin in trying to understand the technologies that goes into MM?
            • justjim1220J
              justjim1220 Module Developer @hrishim
              @hrishim
              This is a good place to start. I still had problems, but the forums are very helpful. Good Luck!!
              https://github.com/MichMich/MagicMirror/blob/master/modules/README.md
              And you should have run-start.sh in the main MagicMirror folder… If not, probably need to First, unhide file extensions, if it’s still not there, the reinstall MM from new.
              Jim Hallock - 1995
              • A
                arciemaps
                Hello. Thanks for this guide. I cant seem to run this. I am a complete newbie :).
                I installed NodeJS and Git for Windows. I follows instructions and repeatedly (about 20x times). I also deleted the npm cache and npm under the AppData as well as other dependencies under “my username” folder. I even tried using a different computer and reformat a new computer and I get the same error every single time.
                I am using Windows 7, latest patch (whatever that might be as of Juine 24, 2018). For some reason, it looks like it is looking for the a certain file and looking for it in the wrong directory. You may refer to attached screenshot.
                Sorry if this is too noobie question, any assistance will be appreciated 0_1529891854051_starterror.png
                • justjim1220J
                  justjim1220 Module Developer @arciemaps
                  @arciemaps new version of MagicMirror just came out a few days ago.
                  I would scrap everthing and start over with the instructions for the walkthrough.
                  Only changes I would make is to be sure to get the latest version of everything, ie: nodejs, git for windows, and the MagicMirror.
                  I think when I started to do this, I had a few problems at first, but once I got it to work, then it got a lot easier…
                  Are you using Win & 32-bit or 64-bit???
                  Jim Hallock - 1995
                  • I
                    ionut322
                    Hello guys, newbie here … I did everything by the book on my laptop and it runs fine (I want to build a mirror and Im currently testing the software) but it says hello and nothing more … except the greetings … how do I take pictures ?! … :(
                    ? justjim1220J 2 Replies Last reply Reply Quote 0
                      A Former User @ionut322
                      @ionut322 take a picture? What do you mean?
                      • justjim1220J
                        justjim1220 Module Developer @ionut322
                        @ionut322
                        I’m with @Sean, need more info to help you…:winking_face:
                        Jim Hallock - 1995
                          Johans @Mykle1
                          @mykle1
                          Followed your guide to install on my windows 10 - 64 bit machine.
                          Installation went OK, but when I start mirror I just get a black screen.
                          This is the error message
                          Launching application.
                          { Error: listen EADDRINUSE 127.0.0.1:8080
                              at Object._errnoException (util.js:1024:11)
                              at _exceptionWithHostPort (util.js:1046:20)
                              at Server.setupListenHandle [as _listen2] (net.js:1351:14)
                              at listenInCluster (net.js:1392:12)
                              at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
                              at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
                            code: 'EADDRINUSE',
                            errno: 'EADDRINUSE',
                            syscall: 'listen',
                            address: '127.0.0.1',
                            port: 8080 }
                          Hope you can help me out.
                          • Mykle1M
                            Mykle1 Project Sponsor Module Developer @Johans
                            @johans said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                            This typically means that another application or program is using the port (8080) that MagicMirror uses. You would have to resolve that issue
                              Johans
                              @mykle1
                              Thanks for the info, can’t find out who is using port 8080, but I changed in the config to use another port.
                              Now all is working. :thumbs_up_light_skin_tone:
                              • Mykle1M
                                @johans
                                Well done, mate. :thumbsup:
                                  Johans @Mykle1
                                  @mykle1 FYI
                                  Meanwhile I found the problem of port 8080, due to some malware on that PC, the proxi settings where modified, only option was to re-install OS. Lucky I had some backup so that didn’t took so long.
                                  Now proxi settings are no longer hi-jacked and I can run MM normally.
                                  Problem solved!
                                  • Mykle1M
                                    @johans
                                    Ahh, Windows. I no longer use it for MM. I’m strictly a ubuntu 16.04 LTS guy now.
                                      djniuss
                                      Hi. quick question. the MM work with the basic modules. as soon as i try to install a 3rd party module i have a syntax error. Checked and rechecked the code and there is no error. is there special thing to add code thant im not aware of
                                        sdetweil @djniuss
                                        @djniuss from the MM folder do
                                        npm run config:check
                                        fix errors from top down
                                          djniuss @sdetweil
                                          @sdetweil Thank you sir. All is good now.
                                            djniuss
                                            Other question.
                                            is there a way to acces to mirror server from another device ( like the rpi does)
                                            i have withelisted all ip. and cant seem to connect. i have created rules in the windows firewall and router and still nothing.
                                            instead og localhost if i enter 0.0.0.0 i only have a black screen.
                                            is this possible . im building a smaller mirror and would like to connnect to the mirror that i already have running.
                                            D Mykle1M 2 Replies Last reply Reply Quote 0
                                            • 16
                                            • 17
                                            • 3 / 17
