    Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10
    324 Posts 55 Posters 865.0k Views 59 Watching
      Mykle1 Project Sponsor Module Developer @lavolp3
      @lavolp3 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
      Working great on Win 10 Pro 64 bit
      That’s good news! Enjoy your mirror. :-)
      • L Offline
        lancerkid38
        @Mykle1 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
        walkthrough
        I’m a Windows 10 user & your MagicMirror Walkthrough was wonderful. Worked perfectly the first run. I have been on youtube for a month or so watching other with work with MM. I would like to expand on whats was given but this is a great start.
        Thanks for sharing your walkthrough. Incredibly easy to follow!
          Mykle1 Project Sponsor Module Developer @lancerkid38
          @lancerkid38
          You’re quite welcome, my friend. :-)
            djsunrise19 @Mykle1
            @djsunrise19 said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
            I think I’ll create a windows backup and give ubuntu a 3rd chance :-D. Using ubuntu mate shouldn’t be a problem? I like that interface a little bit more
            Personally, I wouldn’t care which version name or number, as long as it’s stable and MM resides there happily.
            Another option for voice would be an alexa skill an module. So I can use alexa for the input trigger.
            Cool. Keep me posted.
            Made it with ubuntu. I didn’t use the java-scripted marquee fx anymore, changed it to CSS3 transitions :) - no problems there. Also the 3rd party option works very well. Now, my realtek soundcard detects my microphone. So I don’t have to use my USB mic (latency is horrible - 4-5seconds!! - with my 3,5mm pawl mic ~0,3seconds). I’m using MMM-voice with your Lucy (slightly modified) ;).
            So thank you very much Mykle1! Any recommendations for a small 3,5mm pawl mic? Actually, I tested it with a headset mic. But it doesn’t recognize me so good, if I’m 0,5m away.
              Excellent. I suspected the drivers were the problem. :-)
              Yes, the whole latency thing was a bother to me. The difference in response time using a USB microphone is horrible, as you found out.
              I purchased this microphone when I was first working on Lucy because it was inexpensive. It works really well in a quiet environment, with a 99% success rate within 50 inches. I haven’t tested it at long distance.
              https://www.amazon.com/gp/product/B07673TQCB/ref=oh_aui_detailpage_o04_s00?ie=UTF8&psc=1
              • H Offline
                hrishim
                Thanks for the walkthrough @Mykle1 I did most of the stuff myself but stumbled at the last step - running MM. There is no sh in Windows and I was thinking I need to install Cygwin or something similar. Then stumbled on this post.
                On a different note - could you suggest pointer on how to get started writing modules? Ideally, where does one begin in trying to understand the technologies that goes into MM?
                • justjim1220J Offline
                  justjim1220 Module Developer @hrishim
                  @hrishim
                  This is a good place to start. I still had problems, but the forums are very helpful. Good Luck!!
                  https://github.com/MichMich/MagicMirror/blob/master/modules/README.md
                  And you should have run-start.sh in the main MagicMirror folder… If not, probably need to First, unhide file extensions, if it’s still not there, the reinstall MM from new.
                  Jim Hallock - 1995
                    arciemaps
                    Hello. Thanks for this guide. I cant seem to run this. I am a complete newbie :).
                    I installed NodeJS and Git for Windows. I follows instructions and repeatedly (about 20x times). I also deleted the npm cache and npm under the AppData as well as other dependencies under “my username” folder. I even tried using a different computer and reformat a new computer and I get the same error every single time.
                    I am using Windows 7, latest patch (whatever that might be as of Juine 24, 2018). For some reason, it looks like it is looking for the a certain file and looking for it in the wrong directory. You may refer to attached screenshot.
                    Sorry if this is too noobie question, any assistance will be appreciated 0_1529891854051_starterror.png
                      justjim1220 Module Developer @arciemaps
                      @arciemaps new version of MagicMirror just came out a few days ago.
                      I would scrap everthing and start over with the instructions for the walkthrough.
                      Only changes I would make is to be sure to get the latest version of everything, ie: nodejs, git for windows, and the MagicMirror.
                      I think when I started to do this, I had a few problems at first, but once I got it to work, then it got a lot easier…
                      Are you using Win & 32-bit or 64-bit???
                      Jim Hallock - 1995
                      • I Offline
                        ionut322
                        Hello guys, newbie here … I did everything by the book on my laptop and it runs fine (I want to build a mirror and Im currently testing the software) but it says hello and nothing more … except the greetings … how do I take pictures ?! … :(
                        ? justjim1220J 2 Replies Last reply Reply Quote 0
                          A Former User @ionut322
                          @ionut322 take a picture? What do you mean?
                            justjim1220 Module Developer @ionut322
                            @ionut322
                            I’m with @Sean, need more info to help you…:winking_face:
                            Jim Hallock - 1995
                              Johans @Mykle1
                              @mykle1
                              Followed your guide to install on my windows 10 - 64 bit machine.
                              Installation went OK, but when I start mirror I just get a black screen.
                              This is the error message
                              Launching application.
                              { Error: listen EADDRINUSE 127.0.0.1:8080
                                  at Object._errnoException (util.js:1024:11)
                                  at _exceptionWithHostPort (util.js:1046:20)
                                  at Server.setupListenHandle [as _listen2] (net.js:1351:14)
                                  at listenInCluster (net.js:1392:12)
                                  at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
                                  at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
                                code: 'EADDRINUSE',
                                errno: 'EADDRINUSE',
                                syscall: 'listen',
                                address: '127.0.0.1',
                                port: 8080 }
                              Hope you can help me out.
                                Mykle1 Project Sponsor Module Developer @Johans
                                @johans said in Complete Walkthrough - Install MagicMirror on a PC - Windows 7/10:
                                This typically means that another application or program is using the port (8080) that MagicMirror uses. You would have to resolve that issue
                                  Johans
                                  @mykle1
                                  Thanks for the info, can’t find out who is using port 8080, but I changed in the config to use another port.
                                  Now all is working. :thumbs_up_light_skin_tone:
                                    @johans
                                    Well done, mate. :thumbsup:
                                      Johans @Mykle1
                                      @mykle1 FYI
                                      Meanwhile I found the problem of port 8080, due to some malware on that PC, the proxi settings where modified, only option was to re-install OS. Lucky I had some backup so that didn’t took so long.
                                      Now proxi settings are no longer hi-jacked and I can run MM normally.
                                      Problem solved!
                                        @johans
                                        Ahh, Windows. I no longer use it for MM. I’m strictly a ubuntu 16.04 LTS guy now.
                                          djniuss
                                          Hi. quick question. the MM work with the basic modules. as soon as i try to install a 3rd party module i have a syntax error. Checked and rechecked the code and there is no error. is there special thing to add code thant im not aware of
                                            sdetweil @djniuss
                                            @djniuss from the MM folder do
                                            npm run config:check
                                            fix errors from top down
                                            • 16
                                            • 17
                                            • 2 / 17
