    MMM-GooglePhotos
    294 Posts 56 Posters 339.6k Views 59 Watching
    • K Offline
      kapsolas Module Developer @Guest
      @sean Thanks!
      Another question… If i have an album which I’ve shared, images from that party are not showing up.
      Actually, after adding some debugging in the node_helper file, the body (freehanded the response as I don’t have the exact body handy) from the API
      Status code: 400
      Message: “The media item is not in the user’s library it was contributed by another user to…”
      Basically, their was an unhandled exception being thrown where your case statement is for: time, reverse, random.
      Any idea how to configure the album to allow the API to pull all images regardless of who uploaded them?
        A Former User @kapsolas
        @kapsolas
        The picture was not created by you, right?
        I’ll research and try to fix it.
        • K Offline
          Correct.
          The setup is as follows:
          1. I created a shared album
          2. Invited my wife to it
          3. I uploaded photos
          4. My wife uploaded photos
          When I tried to set up the plugin, I discovered it was failing. I modified the code to print the body to the console and saw the message from the Google Photos API.
          The response is:
          error:
          { code: 400,
          message: ‘The media item is not in the user's library. It was contributed by another user to a shared album that this user joined to.’
          status: ’ INVALID_ARGUMENT’ }
          If we could get this to work, it would be a nice way to use GooglePhotos act like an online digital photo frame. Anyone with access to the shared album can upload photos.
            @kapsolas
            I guess the reason is the scope rule. “readonly” is set for the scope of API using. I’ll change it to “https://www.googleapis.com/auth/photoslibrary.sharing”, but it’s just guessing. Test will be needed.
            After fixing, I’ll tell you.
            (Today, I purchased my new MBP and am migrating, so I’m not ready to develop something, so it’ll take somewhat time.)
              @kapsolas
              Fixed. (I think). Try it. (just git pull, no need to npm install)
              mediaItem:search API could access photos shared from others, but mediaItem/ID API couldn’t. It looks so weird. Anyway, I changed it to use mediaItem:search. The only risk is expiration of temporary image URL, so you’d better keep scanInterval under 1 hour.
              • K Offline
                Awesome! That worked and solved it!
                I’ll need to pay around a bit with the sizes in the config (hopefully not the code) to see if I can get the images to display in the screen fully.
                For now the images are being cropped as they are larger than the display area on the screen.
                Again thank you!
                  @kapsolas set the mode to cover or contain. cover will be fit your entire region as large as possible but cropped, contain will show the entire image but has some black tape around top and bottom or left and right by the ratio of photo width/height like movie film.
                  • K Offline
                    kivlow
                    Hello i use node auth_and_test.js but i dont have any album ID in terminal only info : auth_and_test started.
                    What to do to get album ID ??
                    • K Offline
                      If you don’t see any response, it may be because an error is being returned by Google. Errors in the script are suppressed now.
                      If you are familiar with updating the code, you can add a console.log(body) message to see the error.
                      • K Offline
                        kivlow
                        @kapsolas said in MMM-GooglePhotos:
                        console.log(body)
                        in auth_andtes is console log error and i dont have any just info in console:
                        so i dont have i thing any error but no album ID :/
                        • 29
                        • 30
                        • 1 / 30
