    Voice/motion control
    utility
    72 Posts 15 Posters 106.9k Views 14 Watching
    • MichMichM
      MichMich
      Yes, I looked into that. It seems it doesn’t work with Electron on the Raspberry Pi and has an API limit.
      Give it a try, and if it does work, let me know and I’ll build a module.
        coolbotic
        Oh right hmmmm what about this https://github.com/thomascullen/voicebox As you can tell i’m really not sure what I am looking for haha XD
        MichMichM 1 Reply Last reply
        • MichMichM
          MichMich @coolbotic
          @coolbotic not sure if that ine runs on the RasPi. Give it a try.
            coolbotic
            Okay will do waiting on a new SD card, if it work should I tell you? 8-D
            • MichMichM
              MichMich @coolbotic
              @coolbotic Please do!
                coolbotic
                Hope it works now haha !
                  Simon
                  Hi
                  i haven’t put voice control into my mirror but have played around with it for a kitchen based recipe generator. (Say Baked Alaska and the display pulled a recipe off BBC food website and displayed it. )
                  Basically voice recognition is fairly simple. What is difficult is getting it to start listening.
                  The easiest way of doing it is to use the google api Here is a good source. http://stevenhickson.blogspot.co.uk/2013/06/voice-command-v30-for-raspberry-pi.html
                  The problem I had when I played with this is that. It records what you say and sends it to google for recognition. If you want a system that is always listening then you would end up sending recordings to google 24/7. . You could try using http://cmusphinx.sourceforge.net/ to recognize an initial key word then turn on google recognition. But I couldn’t really get a great response from that. However I have a strong Irish accent which doesn’t help :)
                  So you might have more luck. Also a good microphone will make your life easier.
                  • MichMichM
                    MichMich @Simon
                    @Simon Hi Simon. Do you know if the google API is supported under Electron?
                      PtrBld Module Developer
                      It seems that Google has removed this feature for electron, however when you use chromium together with MM² it may works… See this stackoverflow question.
                        Simon
                        Don’t know. I coded with it in python. To tell you the truth I have only heard of Electron about 10 minutes ago :) My magic mirror is coded in python (far more hacky and inelegant then your solution) but it entertained me for a while. :)
                        C 1 Reply Last reply
                        • paviroP
                          paviro
                          electron-speech, alexa-voice-service & pocketsphinx might be worth a look :)
                          – The Doctor
                            coolbotic @Simon
                            @Simon Have you posted you code anywhere would love to see it!!!
                              Simon @coolbotic
                              @coolbotic No it’s not very pretty :) I’ll see what I can do
                              • matt08M
                                matt08
                                What do you think about using wit.ai to voice control MM?
                                Free, unlimited API that could be implemented
                                • mochmanM
                                  mochman Module Developer
                                  @coolbotic I just made a motion control module. It’s no where near as intricate as leapmotion though. It just detects hand movements, using 2 ultrasonic sensors and give you a swipe left, right, and press notification. If you have any ideas on how to improve it, please let me know.
                                  Reply Quote 2
                                  • MitchfarinoM
                                    Mitchfarino Module Developer @MichMich
                                    @MichMich This guy has done it, using your MM2
                                    https://howchoo.com/g/yti5mmq0ntu/add-voice-controls-to-your-raspberry-pi-using-jasper
                                    • T
                                      tyho
                                      @MichMich Well what about annyang. i got it working on my rpi3. See https://github.com/TalAter/annyang-electron-demo. I tried to make a module with the use of your readme file but it didn’t work. (I am not rly (rly not) good at coding).
                                      The demo needs some extra dependencies so it’s not simple to write a module. Can you maybe give it a try?
                                      What about the demo. i didn’t get the actual response in my browser but when i opened the console i saw he recognized my words really clear and fast. (and that for a dutch guy ^^)
                                      I think if you get this running with basic setup (hello, show map, show picture), it could even be expanded to run shells with your voice to turn on and off your monitor. (and other crazy ideas :P)
                                      • MichMichM
                                        MichMich
                                        You can just install extra dependencies using npm install. The problem of using annoying is that it has an API limit afaik. So you can’t use it indefinitely.
                                        T 1 Reply Last reply
                                        • T
                                          tyho @MichMich
                                          @MichMich is it possible to restart annyang when the onend event is called?
                                          • MichMichM
                                            MichMich @tyho
                                            @tyho It probably is. I did not look into the Annyang API.
                                            • 1 / 4
