    Should I Customise the Modules or?
    11 Posts 4 Posters 3.8k Views 4 Watching
      AussieRob
      Thanks Sean,
      I’m not scared to mess around a bit, at worst I’d have to start over. I’m a qualified mechanic, mechanical engineer and network admin and spent some time with html. Did learn Linux about 18 years ago but have forgotten most of it through lack of use.
      Are the default module text or files available anywhere? Best I walk before I run I think.
      Cheers,
      Rob
        A Former User @AussieRob
        @aussierob
        You’d better to start here;
        https://github.com/MichMich/MagicMirror/blob/master/modules/README.md
        And reverse engineering about researching how modules work by adding some log methods into modules will help. Good luck!
          AussieRob
          Thanks again Sean,
          That looks like a good read. There’s so much comes up in a Google search it can be hard to sift through.
          Cheers,
          Rob
            AussieRob
            I decided the easy course of action for me would be to start over. I removed the MM software but neither of the two auto install bash scripts I found would work. (Including the one I successfully used initially.)
            Thanks to Mykle1 and his post (link below) I’m back running again. Later today I’ll modify the config.js file and report back as it may help somebody else in the same situation.
            Mykle1’s Manual install how to post is here : https://forum.magicmirror.builders/topic/5274/how-to-manually-install-mm-on-your-pi-for-absolute-beginners
            Cheers,
            Rob
              AussieRob
              All sorted now thanks, found and added the relevant text to the Config.js file to display Aussie weather, holidays and news feed. No module fiddling required.
              Now to buy a Zero W to do it all again and actually build the mirror itself.
              Thanks for the help, direct or otherwise. If anyone needs help to swap to Aussie displayed info, by all means ask.
              Cheers,
              Rob
                Mykle1 Project Sponsor Module Developer @AussieRob
                @aussierob said in Should I Customise the Modules or?:
                Now to buy a Zero W
                If you can manage to get a Pi 3B instead, you won’t be disappointed. It has twice the RAM and a CPU that is a bit more robust.
                My $0.02USD
                  AussieRob
                  Thanks Mykle,
                  I have a 3B+ that I was using for this test flight, I was just trying to keep the costs down.
                  A 3B in Oz is RRP $A52.36 vs the Zero W at $A14.96
                  Do I need the extra RAM and CPU power for the Magic Mirror?
                  Thanks for your advice and especially your guide for the manual install, it worked flawlessly.
                  Cheers,
                  Rob
                  • justjim1220J Offline
                    justjim1220 Module Developer @AussieRob
                    @aussierob
                    It just depends on the modules or how many modules you are planning to use…
                    The modules that rely on pics and images, or video, or music, or streaming will need all the RAM and CPU you can get!
                    "Life's Too Short To Dance With Ugly People"
                    Jim Hallock - 1995
                      AussieRob
                      Thanks Jim,
                      I’m just building the basic, text only MM so the Zero should be fine. If not it’ll make a good weather station and I’ll swap it with a Pi 3.
                      Cheers,
                      Rob
